I got caught out....
Discussion in 'Gen 3 Prius Fuel Economy' started by GrumpyCabbie, Oct 27, 2012.
  1. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    But there would have to be a temperature differential of ~100F in order to see a 6 PSI change in the tires.
  2. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    In the case of an accident the police check condition of tyres and pressures, they may also at there stop a vehicle at any time for a roadside safety check.
  3. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    I kept my Michelin Energy Saver AS tires (195.65.15) at max sidewall pressure in all
    4 tires, 44 PSI. Got nearly 70,000 miles on those tires and they wore perfectly even,
    they are only rated at 65,000 miles.
  4. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Usually don't bother you unless your tyre is quite visibly low (too high is hard to tell visibly) and then would probably just inform you (no ticket), but if you have a serious and/or fatal accident you can guarantee they will check your tyre pressures. If they're too high and it could be construed that they were a contibuting factor, then expect serious penalties; fine and licence points if you're lucky and prison if you're not.
  5. Codyroo
    1,826
    515
    Pleasanton, Ca
    I wonder if they have the science behind the "recommended" tire pressure to back up the 10% over/under requirement.
    Anyhow, I'm sure that you keep your tires within legal specs.
