I Guess It's Broken In Now
Discussion in 'Gen 3 Prius Main Forum' started by jabecker, May 19, 2012.
  1. jabecker
    jabecker driver of Prii since 2005
    448
    78
    Portland, Oregon
    Came out of PetCo this afternoon to find this in my Rosie's beautiful Sea Glass Pearl finish. :eek: The odd, but good, thing is there's no dent. Whatever did this just peeled the paint.
    If it was a scratch, I'd curse and sigh and that would be it. But this looks like it's right down to the bare metal. The main portion is about the size of a pencil eraser.
    What's the best way to deal with this? Should I get some touch-up paint and try that? Or ???
  2. 32kcolors
    32kcolors Senior Member
    5,683
    952
    124
    Redondo Beach, CA
    Where is it located? For example, if it's on the bumper, it's not metal.
    Looks like Sea Glass uses tan primer. Never seen that. I've only seen white or black primer.
  3. ES44AC
    ES44AC C.A.U.S
    319
    76
    When I look at your photo I see fingers on the upper and lower part of the object with the mark on it.
    I can't for the life of me imagine what part you appear to be holding.
  4. swg
    swg 12 Prius / 13 Volt
    78
    Atlanta
    The camera. :)
    iPad 3 ? HD
  5. jabecker
    448
    78
    Portland, Oregon
    It's located on the rear passenger-side door. It's about level with the door handle, and slightly to the right of center as you face the door.
    I believe you are seeing the reflection in the paint of me holding my iPhone, which I used to take this picture. My phone has a green case on it.
    Sorry I was not more specific about location.
  6. swg
    78
    Atlanta
    Dr Colorchip might help, seems to have some good comments in the forum. If you decide to try it an after picture would be nice.
    Good luck, we love our SGP.
    iPad 3 ? HD
  7. Rebound
    Rebound Senior Member
    3,961
    2,609
    Portland, OR
    Fill it with touch up paint. Take a long, long time. Fill in with barely any paint and let it dry at least 30 mins before the next coat. You should apply so little that there's no chance of paint drip. You can do it over a period of days if you want. Be patient.
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Dang that sucks. Can't imagine what did that. Personally I would have it professionally fixed.
  9. jabecker
    448
    78
    Portland, Oregon
    I think it was a shopping cart. :mad:
  10. co_prius_3
    co_prius_3 Member
    174
    32
    Colorado, USA
    I left my Prius at the airport long-term parking over the weekend last month. Someone had folded in the passenger side mirror. Prius rage? I can't imagine why else someone would do that. Otherwise didn't notice any damage.
  11. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    That truly bites! You can try touch up paint or the Dr. Colorchip product, but the repair would still be noticeable on such an exposed area.
  12. Big Steve
    Big Steve ramblin wreck
    402
    39
    Richmond VA
    Folded in as in you just had to fold it back out? Could it be as it folded in as someone squeezed lbetween you Prius and next car?
  13. ES44AC
    ES44AC C.A.U.S
    319
    76
    Hi and no worries! I'd be upset too if I found a mark like that or any mark on my car. I think is might be too deep for Dr. Colorchip to be of use I have only seen videos of it being used on small road rash marks on the paint.
    If you really want a first rate job I'd be off to a body shop and let them look at it. Shouldn't cost anything for an estimate.
    Hope you get it fixed to your satisfaction :D
  14. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    It's caused by morons. They're everywhere. The folded mirror is also caused by morons squeezing between your car and the next one. Many of those ones are overweight. No damage from folding the mirror though.
    Your options are:
    1. Ignore it. The body is plated in zinc and doesn't seem to rust when the paint is chipped off.
    2. Get a tube of "touchup" paint from the dealer. It's a two part paint, colour and clearcoat, in the same tube, usually. One end has the colour and the other the clearcoat. Apply as directed above in the excellent post, slowly and in many layers. Use masking tape to help control where you put the paint. Once you are satisfied with the thickness, put the clearcoat on top. Be aware, this paint is water based, so while painting keep it dry. You will never completely hide the mark using this method, unfortunately.
    3. Have a body shop fix it. They will sand down around it and "blend" the repair paint into the rest. If they're good you won't be able to see it. It will however cost over $200.
    Just be happy you didn't see the moron do it. Murder is considered a serious offense. ;)
    2 people like this.
  15. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    +1, do this, or use this method with Dr Colorchip. Only you will notice it.
  16. jabecker
    448
    78
    Portland, Oregon
    There are times, however, that it's justified! :D
    Thanks to everyone who responded for your suggestions and commiseration. I'm going to get a quote from a body shop and see what they say. If it seems way high, I might try some of the DIY suggestions. But I am leaning towards a professional fix. I only have 1000 miles on the car! If it were older, I might feel differently.
  17. massparanoia
    massparanoia Active Member
    697
    467
    Virginia
    If you are not too anal, you could use touch up paint and it probably will come out ok. You will probably be the only one who will know it is there.
    If you are anal, and being the only one who see's the imperfection will drive you mad, then the best route will be to have the door refinished. Since it is a brand new car, and the paint hasn't had time to fade, it will look good as new when its done.
    I had this happen to my car 2 weeks after driving it off the lot. Took it to the Toyota body shop and you can't even tell anything happened.
  18. ChipL
    ChipL Active Member
    585
    85
    Reston, Va
    Could have been a courtesy from the person that had parked next to you...
  19. ChipL
    ChipL Active Member
    585
    85
    Reston, Va
    Real bummer folks have little regard for others property these days. :(
  20. 32kcolors
    5,683
    952
    124
    Redondo Beach, CA
    I've seen shopping carts roll into cars by accident. Best to practice defensive parking.
