I had to jump my 12v battery today - How do I maintain a healthy battery?
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Resilient, Apr 3, 2024.
Tags:
  1. tovli
    tovli 2023 Prius Prime replaced 09 Prius
    352
    274
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    First I see what they say about the battery condition on Friday.
    If they say the battery is good, that is "first lemon law criteria",
    Next I let it sit for a week, if it dies, I take it in a second time.
    If they say the battery is good, that is "second lemon law criteria",
    If they get to "three service did not fix the problem before 24 months", I apply for arbitration under the Florida Lemon Law. Toyota can either buy the car back or replace it.
    Perhaps a much bigger hassle than a hooking the $27 Noco charger every time I park and (hopefully) remembering to unplug the charger every time I go to use the vehicle, but if letting a $40k car sit for a week is not a normal use case for this Prius, my "Toyota Fan Boy" ticket is is going to be canceled. (I haven't had a 2nd choice vehicle for over 20 years, and after buying my 2009 Prius for under MSRP during the market crash, I didn't want a new car until the Gen5 Prius was revealed and then I had to have it. I still don't have a 2nd choice even with the warts, but "dies if you park it for a week" would really rock my world.)
    bisco and Mendel Leisk like this.
    52,284
    all my gen2 and 3 prius sat unused for up to 3 months every winter in an unheated detached garage without problem
    tovli likes this.
  3. Mr.Vanvandenburg
    1,357
    578
    2020 Prius Prime
    You assume an arbitration verdict will be won on a 12 volt battery though. I was trickle charging my gen 2, but not like I should have been. I put several batteries in it, wasn’t happy about it.
    Today my 20 Prime charged the 12 volt to 100%, it was colder. i trickle charge it often, have a battery monitor to know when, and yes twice I drove with the charger connected. Just a few feet the noise starts. It helps to keep the mind more focused next time, which is more important as we age and start going zombie.
    Get one of these, it is the best idea I got from this forum. My screen looks like the picture with two cars monitored. It also keeps a record for 5 days, very helpful to see what is actually going on overnight etc. Link not showing search battery monitor on Amazon, there is an Ancell for $24.
    #43 Mr.Vanvandenburg, Dec 19, 2024
    tovli likes this.
  4. chris johnson 2
    chris johnson 2 New Member
    29
    Netherlands
    2024 Prius Prime
    I should not need to understand this trickle charge stuff on a new state-of-the art car from the market leader and champion of reliability! Somewhere on this site is a poll where approx half of Prius 23 owners have problems with the 12V battery including me. Toyota ought to be taking an interest and making some proposals and otherwise someone will be sufficiently irritated to start legal proceedings and I might well contribute depending whether I EVER have to use my newly acquired Lithium Jump Start. This is not why I chose Toyota.
    AndersOne, Bill Norton and tovli like this.
  5. Mendel Leisk
    41,824
    If you had a third gen you'd have much more stuff you "shouldn't have to do", lol. If the car companies were honorable, I'd agree with you.
    tovli likes this.
  6. Mr.Vanvandenburg
    1,357
    578
    2020 Prius Prime
    It’s not just the Prius, other makes car forums are riled up about their 12 volts. I think we all know jumper cables are common now and in the past. In the past you could hear the starter motor start to turn slower as your battery aged or wasn’t getting enough charge during the winter especially. Then one morning it doesn’t start and you are looking for a jump. With a hybrid the idea is the same but no slow starter motor, it just doesn’t turn on one morning.
  7. Mendel Leisk
    41,824
    If you've got plain-Jane, old-school jumper cables, here a thought I've had, to keep yourself out of trouble:
    Pull the two cables completely apart. Leave the black cable well out of reach.
    Connect the red (pos) cable, at both ends. Make real sure both ends are on the batteries' positive posts.
    Then go looking for the black (neg) cable, hook it up to the two negative battery posts.
    (I'll always remember this one Scotty Kilmer episode, he's connected both pos and neg cable clamps to the donor battery, and he's wandering around with the other ends, pos clamp in one hand, neg in the other...)
  8. Winston Smith
    Winston Smith Active Member
    387
    261
    OH
    2024 Prius
    LE AWD-e
    I thought only the negative post on the donor battery was supposed to be connected, but I've never done it.
    When you're late for work or peeved because you are having a bad time trying to figure the problem, trying to remember the right dance for a jump seems like a formula for a sad error. I'm dopey enough that I'd want to have the instructions with me if I were to try it.
    Those little battery jump boxes seem like a neat idea. I don't know how people would remember to keep them charged for when they are needed though.
    The only time you should have to remember that your car has a battery is when your mechanic says "Your battery is five years old and you are at 90,000 miles. Might be time for a new one.", and you say "Sure. Do it."
    chris johnson 2 and Mendel Leisk like this.
  9. Mendel Leisk
    41,824
    Technically yes, it’s safer to “connect” to the dead battery’s negative post remotely, via a ground, to avoid a spark right at the battery, where there may be vented hydrogen. Sometimes, if it’s impractical to connect elsewhere, I’ll just blow across the top of the battery, hopefully dispel any hydrogen. For example, with my battery tester it stipulates both clamps need to be on the posts.
    the main point I was trying to make, is to do all the positive connections first, and then the negative, much less risk of shorting, basically providing a zero resistance path between pos and neg.
  10. rjparker
    rjparker Tu Humilde Sirviente
    10,410
    6,521
    Texas Hill Country
    Using jumper cables at all is not recommended these days for various reasons starting with incorrect polarity. However most of us routinely jumped the Scotty way back in the day. It is far better than using two people, one at each end.
    The lithium jump packs normally will hold a charge for years. On a hybrid where the 12v battery is not ruined by age or a months long discharge, most lithium jump packs will separately jump start five or more times on the same charge. The big plus is reverse polarity checking and minimum voltage verification prior to actually supplying external jump voltage.
    One newer issue on some Toyotas when using the underhood jump point is burned out ecus if you chose to use the ecu frame for the negative connection.
    #50 rjparker, Dec 26, 2024
  11. Hammersmith
    Hammersmith Senior Member
    2,315
    2,359
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Unless they get really cold, as I discovered the other week. I've got a NOCO GB40 Boost Plus(1000A). The thing was fully charged just a week or so before. It sat in the car which got down to -10F for a few days. The thing couldn't even start the car once, much less multiple times. Thankfully I was at home and not in a rush, so I was able to bring it inside, warm it up, and recharge it.
    Just putting the info out there for those of us that live in extreme conditions.
  12. Ankacy
    Ankacy New Member
    Raleigh
    2024 Prius
    2024 Prius that just had to be jumped off after sitting less than a day and half. It has an appointment at the dealership tomorrow. Brand new car with brand new battery shouldn’t have to be jumped off.
  13. bisco
    52,284
    'shouldn't' is not in toyota engineers lexicon
  14. Steve Leffert
    Steve Leffert New Member
    Lake Balboa, CA
    2023 Prius Prime
    XSE
    I have now had three incident where my 2023 Prime XSE won't start. The 12V battery is the culprit. The first time to the dealer "checked it out" and found nothing wrong. I had navigation problem (get world view map and "Exceeds max trip distance" when going to a previous destination 15 miles away. Dealer ordered a new radio/nav. 1-20-25 when I was trying to set nav destination the evening before going to a new location I had the power on for about 15 minutes while sitting in the car. Because of the faulty system I had to enter is 3-4 times to get it right. I shut off the car. The next morning we got in the car to go to the appointment and it wouldn't start. Lights flashed, dash said NOT READY, etc. I check the voltage at the 12V battery in the "trunk" and it was 8 V. I tried my instant jumper and it didn't do the trick. I ended up putting it on my regular charger and borrowed my neighbors car for the appointment. When I returned I took off the charger and the car started fine. I used it the next few days with no incidents. Thursday afternoon I got the call from the dealer that the radio/nav had arrived and I made an appointment for 2PM for installation. I spent about 20 minutes with the car on to check and take photos of all my settings and radio station presets on my screen and empty personal stuff out of the car. I then wanted to make a run to the grocery store, but the car wouldn't start. Same as 3 days before. Battery voltage was 11. The service writer I spoke with on Tuesday had said not to jump start it, but have it towed in. Sounded like a great idea. That way they could see why the battery was dead.
    Here's the new problem. The car was in my garage and would have to be rolled out to get hooked to the tow truck. Neither the tow truck guy or I could figure out how to get the car in Neutral with out it starting. Does anyone know how to get the news version of Prius Prime out of Park without it being turned on??? We ended up having to jump start it and back it out of the garage. It was towed to the Dealer.
    The radio/nav was replaced and the dealer couldn't find any problem with the battery, but is keeping the car overnight. I will request they turn on the car, leave it for 20 minutes, turn it off, wait 2 minutes and try to start it again. I believe the battery is one of the defective batch that only take a surface charge and if it is on for more than 15 minutes without driving it the battery voltage drops too low.
  15. Mendel Leisk
    41,824
    Or it’s the victim? Of excessive phantom draw? You can check the quiescent amperage; anything over 50 milliamperes is excessive, more typical is 20<25?
  16. Trollbait
    12,653
    You say you had the car on; was it in Ready or Accessory?
    The dealer warned me to have the Subaru actually started when messing around with the infotainment system, and it has a beefier battery than what's in a hybrid. These systems are high draw devices compared to the basic radios from decades ago.. The industry was thinking of moving to 48V systems when they first started showing up.
  17. ChapmanF
    18,454
    The one I've got instructs me to "CHARGE IMMEDIATELY AFTER PURCHASE, AFTER EACH USE AND EVERY 3–6 MONTHS".
    I set one of the custom maintenance reminders in the car's MFD to remind me. The jump pack has 12V accessory and USB outputs as well as the jump output; if the reminder comes around and I haven't used it for anything and it's still showing 100%, I'll charge a phone with it or something, and then recharge it.
    In my experience it doesn't always take a "months long discharge" to make things challenging for the jump pack. I picked one of the smaller ones (about 38 watthours), which is plenty to make a Prius go READY, except that all 38 watthours can disappear really quick into a deeply discharged Prius battery. You know that happened if you checked the jump pack and it said 100% and you clamped it on, then in the time it took you to duck into the cabin and try to push the power button the jump pack is reading 0% before you even got a chance to try.
    In my gen 3 there is an easy-to-disconnect cable in the fuse box that I can pull so the hungry discharged battery is out of the picture, then jump the car, and once it's READY, connect the battery again and let the car charge it.
    If you are out in the boondocks and really counting on the jump pack you have to get you going with no challenges, it may also make sense to pull fuses or relays for the brake pressure pump first, then also put those back after the car is READY. Probably will give you some brake warning codes, but eliminates one more place where a bunch of the charge can go when you only want it to go to making the car READY.
    If I'm in conditions like that, I'll be very likely to use all the cheats I know, as above, so the jumper charge really gets used for starting the car, and not charging the battery or pumping the brakes.
    You give the 1000A figure for the NOCO, but I'd emphasize paying more attention to the capacity figure (watthours) instead. Those thousand-odd-amp current ratings are impressive on the package but don't mean so much really; it takes only a small fraction of that to READY a Prius.
    m.wynn, chris johnson 2, MAX2 and 2 others like this.
  18. th27000
    th27000 New Member
    Toronto
    2023 Prius Prime
    Hi
    I have a 2023 Prius Prime and I decided to permanently hookup a Noco Genius 2D charger to the 12V battery in the rear trunk. I am not really confident with electronics so I posted a photo of my battery with proposed hookup points of the eyelets (positive to positive, negative to negative) to what I assume is the correct terminal? Can someone confirm? Also the Noco manual says that the negative eyelet should be connected to ground. Is it safe to connect the negative eyelet to the battery? IMG_6889.jpg
  19. thompsam
    thompsam Junior Member
    Raleigh
    I just had a similar problem with my 5 month old 2025 Prius. It was left in the garage while I was out of town for 10 days and the battery was dead. In addition to moving the key fob away from the car (it was inside the house by in a drawer in a room adjacent to the garage) does anyone have a feel for how much the digital key service/feature drains the battery. I like the notification feature for some things like "passenger door is open", but with the car off, I'm thinking the 12v battery must be used as the source of power to allow the car's computers to detect alertable conditions as well as communicate with Toyota's systems to generate the alert out to her phone.
    I don't have a battery voltage meter to check this myself and didn't see anything in this discussion about the "digital key" service's use/drain of the 12v battery so I thought I'd ask if anyone has this service and if so, have you've investigated its effect.
  20. bisco
    52,284
    it's not the key, it's the design. too much draw on the battery to leave it for a long time. take it to toyota for testing, they might replace the battery
