I have an idea...
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Paul Gregory, Sep 21, 2025.
  1. bisco
    52,891
    did you get a jump pack with a dead battery override switch?
    the battery has to close relays as well as boot computers. idk how much current is needed.
  2. ChapmanF
    19,056
    It's easy to overlook a lot of the draws on the 12-volt battery in the process of going READY.
    The process starts out the same as IG ON, with power to all the car equipment that gets power in IG ON. That includes a couple dozen computers, the instrument panel, some pumps, and so on, also extra things like the wipers or seat heaters if they were left on when the car was shut off.
    As soon as the HV control ECU has completed its checklist and decided it's ok to close the battery relays, the DC/DC converter comes online and takes over supporting those loads, but they were all on the 12-volt battery for the second or so before that happens.
    The battery relays aren't an especially significant part of that load, just another small part of the total.
    In my generation, the brake accumulator pump can be one of the larger loads active during that time. But I'm not positive gen 5 does the brakes the same way.
    52,891
    that must be why my 12 had auto off seat heaters
  4. ChapmanF
    19,056
    oh, they changed that? in my '10 the seat heater switches are plain mechanical switches. on is on.
  5. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I never use seat heaters. They make my butt itch.
  6. Hayslayer
    Hayslayer Active Member
    539
    331
    How many people need to tell you that YATAH before you believe it?
    Blackat likes this.
  7. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    It seems that draining the battery intentionally is not so easy. I left the ACC on, but when I came back an hour later it was turned off and the battery was at 12.6 volts. The booster however, came on when I plugged it in, as indicated by a green light.
  8. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I'll believe evidence. Even a consensus can be wrong.
  9. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I have a DC current meter, so I could measure it if I want, but I know it isn't much because it's not running a starter motor, and all the times I've boosted the car, it never showed any signs of passing high current. At any rate, I'm sure the starter demands of the Prius are well within the capacity of any booster pack.
    Having said that, it depends on the amount of charge left in the 12V battery. It's never been dead flat; it's always somewhere between 6V and 11.6.
  10. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I'm only here to share and acquire ideas about my Prius, and share my past experience. But I never counted on the level of trolling that I've seen here. All forums have some trolling of course, and it can usually be dealt with by ignoring, but this stuff is on a whole new level.
    You get judged on things you never said, so it's impossible to ignore. Unfortunately it looks to the mod that I am the troublemaker. Like I said, trolling on a whole new level.
  11. bisco
    52,891
    they must have. was 12 a refresh?
  12. bisco
    52,891
    i'd love to see pics of your setup. right now my pack is in the hatch, under the floor. probably a mistake since i'd have to crawl back there, try to lift the floor from the opposite end, and fish around for it.
  13. ETC(SS)
    7,576
    Generally speaking, it's a one troll per bridge limit.
    If you think everybody else in the thread are the trolls?
    Um......you probably have it the other way around. ;)
    Go outside and touch some grass and stop giving so many people the power to irritate you.
    It sounds like you've mitigated whatever happened to your electrical system that's causing your problem.
    #53 ETC(SS), Sep 23, 2025
  14. ChapmanF
    19,056
    It was. Also, didn't you have a PiP? Didn't that get seat heat switches with hi and lo settings? Mine are just on/off.
    I'm pretty sure I looked up the PiP seat heater wiring diagram once upon a time for a thread around here. Maybe it's still around. I don't remember seeing anything about them being auto-off (but I guess that could have been an internal feature of the switch not explicitly shown in the diagram).
  15. bisco
    52,891
    yes, hi/lo. just a rocker as i recall, and went off when you powered down.
  16. Hammersmith
    Hammersmith Senior Member
    2,497
    2,562
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Gen5 seat heaters are 4-stage(Off - Low - Med - High), and they keep their status between power cycles(unless you use custom climate settings in the app when doing an app remote start).
  17. bisco
    52,891
    i don't like that at all. i would continually forget to turn them off
  18. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    It doesn't look like much. It's just a jump pack with a lighter plug connected to where the alligator clips used to be.
    I originally thought to mount it somewhere, but that's not necessary.
  19. bisco
    52,891
    right, you have the always on socket, i do not.
  20. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Right. I had the live socket installed for things I wanted to stay on.
