I have an idea...
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Paul Gregory, Sep 21, 2025.
  1. bisco
    52,819
    sometimes i can think of a good use for one, but installation would be above my pay grade.
    50 years ago, i would have jumped right into it.
  2. Hammersmith
    Hammersmith Senior Member
    2,477
    2,536
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I'm just curious, but why? On the gen5, the lights for the seat heaters are very visible as they're part of the climate control panel. Plus you'd feel it.
    Here's a picture of a HEV Limited with the driver seat heater on low and the passenger on medium.
  3. Paul Gregory
    Paul Gregory Senior Member
    2,339
    614
    Alberta
    2024 Prius Prime
    XSE
    I just pay someone to do it.
    #63 Paul Gregory, Sep 23, 2025
    52,819
    it is helpful to have the indicators, i'm old, i'm confused. maybe i don't want to feel it next time.
  5. VelvetFoot
    VelvetFoot Senior Member
    1,407
    545
    New York State
    2026 Prius
    I've got a DL on order, ie, no heated seats or steering wheel.
    I really got used to them on my current MINI; it'll be an adjustment.
    I installed seat heat in my 2000 VW TDI Beetle. It had carbon impregnated cloth-no wires to kneel on and subsequently burn a hole in your posterior. Removing the upholstery and reinstalling was not fun, as I recall-my introduction to 'hog ring' pliers. Luckily nothing bad ever happened, electrically, or for that matter, airbag, speaking.
    The MINI was my first car with a heated steering wheel, and that is very very nice.
    I don't think I'll be attempting anything with the Prius.
  6. Paul Gregory
    2,339
    614
    Alberta
    2024 Prius Prime
    XSE
    For less than a hundred bucks, you can buy a seat cushion with a built-in heater.
    Mine has a massager, but I never use the heater.
    VelvetFoot likes this.
  7. VelvetFoot
    1,407
    545
    New York State
    2026 Prius
    Didn't know that, thanks.
  8. bisco
    52,819
    love the heated steering wheel on my bolt, and cooled seating! will be difficult to give those up in the future.
  9. Hammersmith
    2,477
    2,536
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    For what it's worth, the gen5 doesn't use hog rings. It uses a plastic track in the cushions and plastic arrow-shaped long tabs in the seat covers. Takes a little bit of practice with a thin flat-bladed screwdriver, but once you get used to it you can fly. I did a complete seat cover swap(all seats), and by the end I could remove or replace a cover in about 5 min or less.
    (Since my LTD is red, I wanted the red-trimmed seats from a Prime. I bought the seats from a wrecked XSE, but I had to swap covers because my LTD has ventilated seats and the XSE seats didn't.)
  10. VelvetFoot
    1,407
    545
    New York State
    2026 Prius
    That's awesome.
    I do have to admit that the VW TDI was the one car that I was really into 'modding'. And it was all fed by a web forum, lol.
    I put in bigger injectors, and revised programming, and don't you know, the clutch starting slipping, so in goes a VR6 clutch, lol. Then there were the gauges....
    I'm more into keeping a car stock nowadays, mostly. Although I've been studying the spare tire scene, DCM, and the noisemaker. :)
  11. Hammersmith
    2,477
    2,536
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I've done a ton of mods to my Prius, but everything has remained stock/OEM except the hood struts I picked up from Amazon. Everything else has been taking things from other Priuses and putting them on mine. Or OEM accessories meant for the Prius. The biggest projects have been the interior conversion(seat covers, steering wheel, gear shift knob, dash trim), power folding mirrors with turn signals, and the complete spare tire conversion. I've also added the Toyota/Lexus premium horns, GR door stiffeners, GR performance dampers, door sill protectors, dash cam, rear footwell lights, and JDM rear headrests. My (hopefully)final project is adding front cross traffic sensors, but I'm having problems getting them programmed.
