I jumpstarted a car and my 2010 prius wont start
Discussion in 'Gen 3 Prius Technical Discussion' started by priusnation, Mar 16, 2012.
  1. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    I think another factor is what brought the other vehicle down. If the battery was healthy but they left the headlights on all day, the battery may actually recover given an hour of "rest" to make a good starting effort. Boosting a car like that can probably work pretty well. If the other car's battery is old or compromised (internal short, say) or if the starter's binding any jumper start will be a challenge.
  2. richard schumacher
    7,664
    1,045
    United States
    Read the Owner's Manual. It's filled with info that will help you avoid other inconvenient and/or expensive mistakes.
  3. Former Member 68813
    3,524
    983
    US
    Too bad OP didn't come back to provide his follow up. So far the feedback is one way.
  4. priusnation
    priusnation New Member
    ca
    Thanks for all the feed back... I took my car into the dealer and they said the switch connecting to the battery was turned off. I'm not sure what that means, but I just had to pay $100 for the diagnostic feed, and my cars running fine now.
    cheap price to pay... never going to do it again!!
  5. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    If you must charge the battery in another car, take the other owne'rs keys. If he tries to start his car with the cables hooked up, it can cost $4000, and he is not going to pay it. Once it is charged, unhook all the cables and give him the keys back.
    But seriously, just don't jumpstart with a Prius.
  6. tumbleweed
    tumbleweed Senior Member
    4,067
    691
    Eastern Oregon
    As others have said it is best not to use your Prius to jump start other cars. But if you must, in an emergency, remove one of the Prius battery cables first. Then the only thing at risk is your 12V battery, it may need to be recharged because it is only about 35 AH, it probably won't be damaged however. Also if you do disconnect a battery cable you will loose your audio presets.
  7. movingforward
    movingforward Member
    169
    The Great White North
    So it sounds like Toyota engineers install a kill switch when a burst of voltage goes through the system? I thought that is what the fuse is for? Sounds like the dealership just changed the fuse and that's it. The rest is testing and diagnostics.
    Thanks to the Prius community for the idea of just simply unplugging the negative terminal from the battery directly and do a boost with the system isolated instead.
  8. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    I've said it before and I'll say it again. DO NOT use the Prius battery to start a car! It's not a "starting" battery. It's designed for float operation, not high current discharge. It will work, but it will dramatically shorten the life of the battery.
    But if you're wanting an Optima I guess using the stock battery to start another car will hasten the replacement. ;)
  9. movingforward
    169
    ^^^Do you know what the specs, are like CCA rating and others are, for our stock OEM Gen3 battery?
  10. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    just my .02... i jump start people all the time. car fully on... jumpers connected to the battery (i also have a civic battery and not a prius battery... though i jumped people just as much with the prius battery.... much larger vehicles actually)
    if someone has to jump... keep the prius in Ready mode... connect up to the 12v... if your screen or interior lights flicker out.. you overloaded or semi shorted the system, at that point do not jump that vehicle as it has a short.
    bit key point here.. do not jump a vehicle that has a short... (just act like i repeated that 4 times)
    anyway... connect up the cars.. let the other one sit for at least a minute (act like you're getting ready)... have the other person try to start. no longer than 2-3 seconds per start.. and give it a good 30 seconds or a few minutes between attempts.
  11. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I don't mean this as an indictment of the OP.
    But IMO, with any modern car? And especially with a Prius? I simply would not agree to jumpstart someone elses vehicle.
    I know it's unfriendly, and you could risk a friendship...but IMO with Prius or any vehicle the number of systems that can potentially be damaged if something is handled wrong, makes being a good-samaritan too risky.
    I hate to say it, but I kind of feel like, sorry...call AAA, or a friend with an older car, or buy a portable jump start system.
    But I'm not going to risk my $20,000+ vehicle to start your $600 van.
    Does that make me a bad person? I'd love to be a nice guy, but I think vehicles and electrical systems and ECU's have significantly changed since the 70's, 80's and even 90's when basically all you were doing were connecting two batteries.
    I think especially if I owned a Prius, I'd just have to tell friends and people, Don't ask....because Prius don't jump start...
    2 people like this.
  12. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    Normally there is no switch, just a fuse. Some owners and some dealers install a switch to protect the battery during long storage, such as parking at the airport. Some of these are battery-minder type switches which automatically disconnect in the event of low voltage. Presumably the OP's Prius was outfitted in this manner.
    Tom
    2 people like this.
  13. priusnation
    ca
    The dealer said it wasn't a fuse, but the switch by the battery in the trunk that was turned off. Like I said, I don't know what they means but I'm just glad my Prius is running again.:rockon:
  14. priusnation
    ca
    The dealer probably knew just by looking at me that I wasn't going to read the manual and do something stupid like jump start someones car and installed the switch for me... or I'm really lucky :p
  15. movingforward
    169
    It's a good lesson learned and I'm glad you post it here.
  16. RRxing
    RRxing Senior Member
    2,539
    1,813
    NEPA
    Maybe the HV battery relay? I can't see the service plug coming undone in this situation. Anyone else care to comment on what "switch" was turned off?
  17. V8Cobrakid
    3,790
    152
    i want more info about this "switch" too... pics?
  18. David Beale
    5,963
    1,988
    Edmonton Alberta
    The dealer saw the OP was really worried (we are probably partially responsible for that) and in the line of keeping your customers happy, replaced the fuse no charge, telling the owner it was a switch to instill confidence in the car. At least that's my theory.
    If true, that dealer deserves kudos from us and from Toyota Corporate.
  19. TonyK51
    TonyK51 Junior Member
    44
    East Tennessee, USA
    I have a jumper battery I keep in our Prius. The only time I've used it is to charge or power something during a power outage but it is there too for jumping cars. :)
    That reminds me, I need to charge it again.
  20. qbee42
    18,058
    3,079
    Northern Michigan
    I already commented: Some Prius have a battery saver switch that automatically opens when battery voltage falls below a preset level. This device is installed between the 12V battery and the rest of the car. If you leave a light on, or something like that, the automatic switch will kick off and keep the battery from going completely flat.
    Presumably, the OP's 12V level dropped below the trigger voltage during the jump, causing the automatic switch to trigger.
    These devices are third party, installed by the dealer or owner. Here is an example:
    12 Volt Battery Saver Auto Disconnect Switch
    Tom
