I just a 2005 prius that was running on Hydrogan / Quantum Technology and need help
Discussion in 'Gen 2 Prius Main Forum' started by ek82, Oct 26, 2011.
  1. ek82
    ek82 New Member
    Torrance, CA
    Like the title say I picked up a 2005 Prius that was converted to run on Hydrogen. This was a project that was worked and licensed by a company called Quantum Technology unfortunately I have no idea if the car runs or not, it was sold "AS IS"!! All I want to do is to converted it back to a Prius that runs on gas!!
    The car at the moment is missing a gas tank, no key, no power, and the small battery in the truck (right side), The engine oil is milky color (I am guessing that the motor is bad)... I know this is a big project and I am in no way a mechanic but I have a good feeling that this is not that bad of a project to piece back together!!
    I have called the company and of course they said sorry we can not give you any information on our technology and even questioned me how I got the car at the first place.
    After what is said and done can anyone care to advise me on what route I should go next?? BTW.. I have found a junkyard that only works on Prius to convert it back but they cant do it till end of November...
    Thanks in advance!
  2. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    water in oil.. usually a sign of blown head gasket. Could be a result of H2.
    check compression if O'k, change oil/filter (don't bother with synthetics, just the cheapest), get a battery (cheap garden tractor, or if you have to take off other car), change/check spark plugs, then try to start it.
    I'll bet they burned pistons
  3. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Does a hydrogen car even need an ICE or would it need the Prius HSD at all? Does this car still have the fuel cell or what ever else they were using still installed? Can it even be converted back to a regular Prius? Does it still have the traction battery pack? Sorry for all the questions this is interesting.
    48,996
    you can get the small battery in the truck from optima.com.
  5. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
  6. cproaudio
    cproaudio Speedlock Overrider
    2,401
    758
    CA
    hydrogen can be used in 2 ways. fuel cell converting it to electricity like the Honda clarity or use it as straight fuel used in the BMWs 7 series hydrogen. in the BMW the 7 series the engine has been converted to burn hydrogen.
  7. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Can I just ask one question? Why? :rolleyes:
    3 people like this.
  8. a_gray_prius
    2,927
    782
    IL
    You'd think someone here would just Google instead of running their mouths:
    Quantum OEM - Drive Systems - Vehicle Integration - Quantum Technologies
    The car burns hydrogen as fuel.
    Test Drive: Hydrogen Powered Prius Video Clip - Popular Mechanics
  9. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    Some quick notes from the video:
    75 mile range. :(
    $100K to do the conversion. :eek:
    125 H2 fill stations in CA by 2010. :rolleyes:
  10. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
  11. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    Might be that ek82 is just trollin'...
  12. ek82
    ek82 New Member
    Torrance, CA
    I had this project for couple months now just sitting at my mechanic's place and he said he does not know how to fix hybrids.So as in right now I am sure I have to do a motor swap (motor is cheap anyways! $400-500 w 45k) but do you think they changed out or reprogrammed ecu's and what other things do you think I need to swap it back to stock? Also I need someone to cut and program the start key and get a battery ( I believe is a small one on the right truck)
    BTW. I had a quoted by the junkyard to covert it back roughly around 2700 but they can't do it till Nov.
    I dont mind if somebody out there in the greater Los Angeles w/ knowledge to check out the car and give me some advise just PM me!:)
  13. a_gray_prius
    2,927
    782
    IL
    Wasn't directed at you. Replace "someone" with "any of the people who are reading this who claim intelligence"
  14. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    I suggest you put out a Want To Buy in the Private Sales area for the other parts that you need. For example, does your salvage motor have fuel injectors? I recall someone having an extra fuel tank due to having a mis-diagnosed fuel system problem. If you already have someone lined up to do the work for $2700, take it, because I doubt you'll find anyone else nearby willing to do the work, let alone for that cheap.
    The key fob is a tough one. You need to have the immobilizer reset. It is probably cheaper to have your junkyard crew pull an immobilizer and HV ECU from another car, they just need to make sure that they match up on the with or without smart key issue. You may also need the engine computer (ECM) anyway if it had to have some kind of custom fuel map for the hydrogen + turbo system -- or else there is some kind of piggyback computer in it that will have to come out.
    Register your car at Toyota.com/owners to get information specific to it.
  15. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Gottcha thanks you are right it could not have been directed at me you mention intelligence. Have a nice day!
    To the OP good luck with this project I hope you can get her running again.
  16. ek82
    ek82 New Member
    Torrance, CA
    There was some wire harness with a ecu looking unit (I would say it looks like a size of a VCR tape) under the passages seat which I think is not stock??
    Anyhow 2700 is a fair prices but I was hoping to get this project done ASAP since my mechanic is in need for space....
  17. Aerolite
    Aerolite Junior Member
    55
    CA
    Why did you purchase a clunker? Why did you want to convert it back after the 100k it took to get it tot he hydrogen point?
  18. kenmce
    kenmce High Voltage Member
    1,509
    493
    NY
    I think you are looking at a potentially huge project. You have no idea what has been done to the poor thing and won't know 'till someone opens it up. A regular mechanic will have an awful time with it. Why not sell it to someone who wants a neat project and just buy a cheap-but-working gen II?
    Got any pics?
