I just acquired a new project vehicle
Discussion in 'Gen 2 Prius Main Forum' started by jelloslug, Jul 17, 2008.
  1. Patrick Wong
    18,204
    6,505
    Thanks for pointing out the two screws on top. Therefore, I assume the two pieces overlap (i.e., they form a lap joint, not a butt joint)?
  2. jelloslug
    jelloslug It buffed right out!
    813
    55
    Greenville, SC
    Correct. In that section there is another piece of the frame rail that is spot welded to the part I sectioned. I welded only where the line is, the lip at the top will be spot welded when I install the apron (like the factory did it). It's difficult to see from my pics but the part I was working with is not a complete tube, rather it shaped like a C with a flatish plate that is spot welded to the back of it to close it up.
  3. fcc
    fcc New Member
    245
    Nashua NH
    great thread. i really enjoyed it so far!
  4. jelloslug
    813
    55
    Greenville, SC
    OK Ijust finished with the next test fit of the body panels after I welded on the frame rail. They fit much better now.
    I installed the old broken headlights to keep from damaging my replacement ones. They also don't have the bumper bracket on them which makes removing the bumper much faster to make adjustments.
    The gap between the hood and the fender is still a little wide. That's not a big deal though since I have a lot of ways to adjust that out.
    It's looks almost normal except for the calico color scheme.
    Next order of business is to tear it all down again and weld the radiator support and fender aprons in.
  5. Godiva
    Godiva AmeriKan Citizen
    10,339
    Wowee. Can't wait to see it painted.
  6. Patrick Wong
    18,204
    6,505
    Looking good...after you install the radiator support and fender aprons, will you also install the radiator and air conditioning condenser so that the drivetrain can be tested? I'm wondering whether any undiscovered accident damage exists.
  7. jelloslug
    813
    55
    Greenville, SC
    Yep. I will paint the frame and radiator support first and then install all the mechanical stuff. I'm really hoping for no problems when I get the mechanical systems re-installed. I have a good feeling about it since I did drive it into the garage before I started working on it. I have gone over the drivetrain with a fine tooth comb looking for anything out of place or damaged. I also have changed all the fluids with exception of the brake fluid.
    Now for some shots of today's work:
    Here is a shot of me spot welding part of the radiator housing on.
    And here is my wife spot welding on part of the lower support.
    Here is were the upper radiator shell strut is spot welded to the fender apron.
    And here is where the apron is spot welded to the frame rail. I will have to tack weld it further since my spot welder only has about an 8" reach.
    And here are the welds on the lower support.
    All of the spot welds will be supplemented with tack welds from my MIG welder since the size of the spot welds are not the as big as the factory welds.
  8. Patrick Wong
    18,204
    6,505
    Thanks for the new photos!
    Regarding the photo of the upper radiator support welded to the fender apron, the label on that piece appears to indicate this is a non-Toyota part? I did not know that aftermarket collision parts were available.
    How did your wife develop her welding talent - is she an artist or does she apply this skill in an industrial context?
  9. jelloslug
    813
    55
    Greenville, SC
    Yes, the radiator shell along with my drivers side fender and the hood are all aftermarket parts. There are also aftermarket front and rear bumper covers and bumper reinforcement bars. The hood was not my first choice but it came with the car so I will try and use it. The only real issue I have with the hood is that it's steel rather than aluminium and I have not tried it out with the hood latch to make sure it pops up like the factory one does. The aftermarket fender seem to fit well enough and looks OK. It does not have the holes in it for the "HYBRID" emblem though so I will have to drill them myself. My wife has taken welding classes and she is an engineer involved with pipe welding. She has also done engineering with sheet metal fabrication also. I'm an engineer also and I design spot welding equipment.
  10. spitinuri
    spitinuri Member
    317
    I have seen several post throughout this forum on folks with front end damage having to replace the wiring harness due to damage. Replacement cost has been as much as $2500. Were you able to test that part? Can you assume that it works fine since you were able to drive it into the garage? Pardon any ignorance on my part. I am relatively new to all of this.
  11. jelloslug
    813
    55
    Greenville, SC
    I was able to examine the car before I purchased it (a VERY important step in purchasing a salvage car) and the car did run and drive. I knew before had that a harness is usually as expensive as an engine from a dealer so that was one of the things that I examined closely before I committed to the car. There was very minor damage to the harness but it only took about an hour to fix. There were 4 damaged connector housings and 2 cut wires, one of which was for one of the horns.
  12. OlsonBW
    OlsonBW New Member
    254
    I started reading this thread on Friday and finished up today (I take computer support calls and read this between calls or when I'm waiting for the computer to finish something.
    This is the most interesting thing I've read in quite awhile.
    BTW. Where is the fun and adventure if you label everything and know exactly how it all goes back together? lol
  13. Patrick Wong
    18,204
    6,505
    It is obvious that jelloslug knows how to do a first-class job... :D
    I want to know how many other vehicles he has rebuilt, and see some photos of those as well...
  14. jelloslug
    813
    55
    Greenville, SC
    Well, you have not seen my bucket-o-parts yet have you? :D
  15. jelloslug
    813
    55
    Greenville, SC
    Here is a link for my Taurus SHO that I cleaned up: Pictures of my SHO when I picked it up.
  16. Patrick Wong
    18,204
    6,505
    That transformation is astonishing. Do you still own that vehicle? This looks like the kind of project that an enthusiast magazine would feature on its cover...
    I can see that the Taurus project was excellent prep for the Prius project. Although you didn't need to weld sheet metal for that project, the interior renovation and body painting must have taken substantial time and $$...
    How reliable is the Ford digital display?
  17. jelloslug
    813
    55
    Greenville, SC
    The welding is a new thing for me on this project. I like to try new things whenever I can. The interior along with most of the other parts were quiet cheap. Old Taurus parts just don't fetch much on the open market... The paint ran about $500 when everything was all said and done. It took over 2 gallons of blue basecoat to turn that car from white to dark blue; it just would not cover. To put it in perspective the paint for the Prius was $118. The display worked fine this morning on my trip to work. ;)
  18. Godiva
    10,339
    Are you driving it already?
  19. pdhenry
    pdhenry It's HEEERE!
    406
    PA
    I thnk he's talking about the Taurus.
  20. jelloslug
    813
    55
    Greenville, SC
    No, I was referring to the Taurus. I do hope to have the Prius on the road soon though.
