I just acquired a new project vehicle
Discussion in 'Gen 2 Prius Main Forum' started by jelloslug, Jul 17, 2008.
  1. ekpolk
    ekpolk What could possibly...
    548
    176
    Pensacola & Vero Beach FL
    2018 Prius
    Two Eco
    That looks like a fun project. Nicely done so far.
    One trivial suggestion: since they're exposed and easily accessible, replace those foolish sounding horns. Horns are supposed to grab attention and command respect. The horns in a Prius sound like the protests of an angry runt chipmunk. They provide bonus amusement to the truck driver who's about to run you down. Seriously though, slap something in there that will actually perform the intended function of a horn. Best wishes on the rest of it!
  2. jelloslug
    jelloslug It buffed right out!
    813
    55
    Greenville, SC
    I was very happy to not see the master warning light. Her current car is a 2000 Dodge Neon. We bought it new and now it has 226k miles on it. It has actually been a very good car and up until last month the only non maintenance item that I have had to replace was a radiator at around 150k miles. Just last month I had to replace the PS pump and the belt tensioner. I have a feeling that because of the age of the car, the number of miles it has, and the fact that we have drastically changed the amount of miles we have to drive, that the Neon's days are numbered.
  3. jelloslug
    813
    55
    Greenville, SC
    Take a look, I swapped in a set of horns from a Lexus.;)
  4. ekpolk
    548
    176
    2018 Prius
    Two Eco
    Ahhh yes, missed that... You are, of course, many steps ahead of me, and in no danger of having me catch up to you. My hats off to you!
  5. dwdean
    dwdean Member
    377
    South Florida
    jelloslug,
    CONGRATULATIONS!!!!!!!!
    That's awesome!
  6. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    :D[/QUOTE]IT'S ALIVE!!!!
    Today was not without some issues though. I "forgot" to paint both sides of the lock support :eek:. The 2 nuts that are welded on the upper radiator support that are for the hood latch are no were near in the correct spot. I'm going to have to do some Dremel work on those. A few places that were suppose to have holes for wiring clips either have the wrong shape hole or no hole at all. I still need to fix one of the wires for the horns. When I was refilling the cooling system I discover that one of the inverter hoses had a hole in it. It was near the end and I was able to cut off the bad section and still use the hose though. When I powered up the car I had a dreaded airbag malfunction light. After reading the airbag section in the shop manual I found out how to extract the airbag codes without a scanner and I found out that I just forgot to hook up the passenger side pretensioner squib. I hooked up and and all was well. I really did not have any problems refilling the cooling system though. I rigged up a connection for the inverter pump motor and had the inverter section filled in about 5 minutes. The engine side took a little while longer, and I think I will have to keep an eye on it for a little while, but all together I was able to get over 2 gallons in the systems. I did take it out for a little test drive around the block and everything seems to work fine. :D[/QUOTE]
  7. Patrick Wong
    18,210
    6,513
    While the RF fender is off, could you please take a few photos of the air intake resonator and other parts in the RF corner of the vehicle, so that we can see what is involved? The repair manual doesn't have good exploded parts diagrams covering that area and I don't have access to the collision manual.
    Regarding the issues noted at the end of your post 119, would you attribute that to use of aftermarket body parts vs. Toyota parts?
    Regarding the engine coolant refill, did you run the engine sufficiently so that the radiator fans came on? I suspect you'll find that after the engine cools down, substantial coolant will be sucked down from the overflow container into the system.
    Congratulations again on your excellent success. Further, congratulations on picking the right accident vehicle - one that you could repair without requiring outside assistance, and one with very low miles so that your wife can enjoy many miles of service from it. This is so exciting!
  8. ronhowell
    681
    32
    Cypress, CA.
    Something went haywire with my last post attempt, but just wanted to send my congrats too JS, adding to the many others attached to this thread. You have provided a great set of photos and commentary of what is really under the hood of the Prius in your detailing of this ambitious project.
    I was particularly intrigued by the last photo in your post #23, showing the starter block-off plate installed upside down. Since my Prius too is a 2008 model, purchased in September 28, 2007, with some 6400 miles on the ODO, I decided it was worth investigating whether or not the starter block-off plate on my vehicle was in a similar position to yours.
    Sure enough IT WAS!
    Like you, I thought this error had been corrected back in 2006 or thereabouts. But it seems to be continuing. Luckily there appears to be sufficient clearance (~0.5") from the wire bundle that no chafing is evident, but one would have thought that Toyota would have corrected this by now.
    Any idea anyone why the plate has the peculiar edge shape that it does?
    Ron.
  9. jelloslug
    813
    55
    Greenville, SC
    I would say that is it because of the aftermarket part. The nut location is an error but the hole placement may not be. I have my suspicions that these parts were made in the same factory as the factory parts. Other body shop guys have said this and I have seen that same "RDOT" logo on factory Toyota parts before. The missing and changed hole may be to officially make the part different than the Toyota branded part thus giving it a different part number and making it so they are not selling Toyota's part themselves. I did you suggestion of the heat on max (that's fun on a 92 degree day) with the car in inspection mode and I think it's full now. I'm not getting any more gurgling in the heater core. I have gotten a total of 9 quarts between the inverter side and the engine side. I have no idea how much came out but I do know that there was still some in the engine and the transaxle/motor/generator because I did not drain those sections of the cooling system. I got kind of lucky on picking the right car. I knew what I wanted in general but now I know many more Prius specific thing to look for on a salvage vehicle. I could have ended up spending a lot more money if the same damage would have been on the drivers side rather than the passenger side. Here are the pics you asked for:
    There is not much over there. There is the resonator, the air intake flex tube, the air intake cold air diverter, the washer bottle, some ground connections, the passenger side airbag sensor (on the inboard side of the frame rail), and what appears to be some kind of vibration dampener or a weight of some kind.
  10. ronhowell
    681
    32
    Cypress, CA.
    What exactly is the air intake resonator Patrick! Under what conditions does the resonance occur, and for what reason(s)? I assume it has something to do with the airflow dynamics.
  11. Patrick Wong
    18,210
    6,513
    Hi Ron,
    See the first two photos from jelloslug's post 129. The first photo shows the black plastic snorkel that goes down, curves around, then goes back up and attaches to the air cleaner housing. The second photo shows the white resonator attached to the black plastic snorkel assembly.
    The point of all this is to reduce engine air intake noise. Exactly how it works is beyond me.
    For those who have rodent infestation problems, note that the result of all this is a very nice mouse condominium, so a wire screen at the snorkel intake would be a good idea...
    Hi jelloslug,
    Thanks very much for providing the additional photos. Regarding the RDOT label, I thought that this is a way to show that the part in question is a replacement part and not an original part from the vehicle. If the part was original, it would have a label with the vehicle's VIN.
    My 2004 incurred accident damage in the LR, so the LR fender was replaced. I subsequently had occasion to be back there while I was replacing the rear shocks, and noted the RDOT label on the inside of the replacement sheet metal (the body shop did not bother to paint the inside of the fender, so the interior surface is protected only by the paint applied by the factory).
  12. jelloslug
    813
    55
    Greenville, SC
    I think "RDOT" is the manufacturer. The VIN sticker is only applied to parts on a vehicle at the factory. As far as I know there is no way to get more of those VIN stickers. Also, in your case, I think the part was replaced with a factory part as I don't think that there are aftermarket rear quarters available as of right now.
  13. ronhowell
    681
    32
    Cypress, CA.
    Thanks Patrick. I was finally able to identify the same area as shown in JS' photos on my own vehicle, by looking under the hood on the passenger side.
    Interesting that the actual air intake faces toward the rear, just ahead of the window-washer fluid container. The Helmholtz resonator attached to the "U" shaped intake tube is invisible from above, being attached via a hole through the forward body structure. You are correct in that it significantly reduces the engine air intake noise by acting in concert with the airflow dynamics. Apparently this is a common device used in modern IC engines to reduce noise.
    I suspect it is only tuned to a particular engine speed; which is probably why engine noise increases significantly at high RPMs.
  14. jelloslug
    813
    55
    Greenville, SC
    Only a minor update today.
    I installed the side air diverters and the bumper reinforcement. I also did some more tweaking and troubleshooting. I found another leaky hose; this time it was the hose to the inverter bleeder valve. I saw some fluid there yesterday but I just attributed it to the fluid that came out of the bleeder itself. Fortunately it was very close to the end and I was able to snip off the end and save the hose. Also, when I tried to install the passenger side air diverter I discovered that I installed the lower A/C line completely wrong. I was able to pull it back around and install it correctly though. I also painted the lock support black to hid the lack of blue paint on one side. I also painted the horns, fixed the holes for the upper hood latch bolts and took care of a few other odds and ends. I also to a ride out to the dealer that I bought the car from. He had 5 wrecked Priuses, one of which was a parts car. I was able to snag a bunch of odd and ends I needed and I will probably being going back out to get more bits and pieces as needed.
  15. drees
    drees Senior Member
    1,782
    247
    Great job jelloslug, looks like the car will be back on the road at 100% very soon now. :)
    So when does the next project start? ;) It's been fun following this one.
  16. Jack66
    Jack66 Kinda Jovial Member
    766
    Stafford, Virginia
    Looks and sounds like the same devices on the plumbing in our homes meant to cushion dynamic fluid flow -- preventing "water hammer" noises.
  17. ronhowell
    681
    32
    Cypress, CA.
    Interesting number - leading me to wonder just how many Prius' have been wrecked or parted out here in the US since the NHW 20 model was introduced in 2004. For that matter what average percentage of any specific typical car type ends up prematurely in the wrecking yard these days?
    It seems that with the increasing use of unitized vehicle assembly, together with increasing labor costs, insurance companies are increasingly inclined to write off cars after accidents, rather than pay for repairs as in the past.
    Or is that a misconception on my part?
    Incidentally Jelloslug, I believe I have learned more about what-is-where under the hood of the Prius as a result of following your work on this thread than I have from any other thread on Priuschat. Looking forward to your final photos.
  18. Patrick Wong
    18,210
    6,513
    • What is the purpose of the side air diverters? I'm not familiar with those parts.
    • Have you had a chance to recharge the A/C yet? I'm wondering if that system is working OK.
    • Now that you are approaching the end of your project, I am wondering whether you can identify your parts sources (assuming you were happy with their pricing and service.)
    Thanks!
  19. jelloslug
    813
    55
    Greenville, SC
    They make the air that comes through the grill go through the condenser/radiator rather than around the sides of the radiator support.
    Nope, I will probably vacuum it down this week and charge it up.
    My best suppliers for new parts were Parts.com and toyotaoemparts.com . Parts.com was usually cheaper though. I also ordered some things form xvipers.com. He parts out and rebuilds Vipers and Priuses of all things. I cannot recommend him as it took him 3 tries and around a month to ship me my interior parts. He also was very difficult to communicate with and when I spoke with him on the phone he talked a lot of crap about the other Prius vendors. He sells lots of stuff on eBay and most of the time is asking list prices for used parts. I bought some items from Steve at Autobeyours. Steve is a good guy and was very helpful. He had some oddball stuff that I was looking for and his prices were better. If he would have had all the stuff I was looking for I would have bought more things from him. I bought some things from Hybrid Auto Parts also. There prices OK at best and list price at worse. They have a good selection of stuff and if you call them you can haggle with them a bit. They only problem I had was that several of the parts were not as advertised and they had to send me some replacements. I would by from them again if I had to. My local Toyota dealer, Toyota of Greenville, SUCKS! I knew that I would pay more there but they mark the prices UP from list. Combine that with the fact that the few times I went there it took no less than 45 minuets even though there were no other customers. I ordered a total of 6 parts from them and they only managed to get one part correct. I will not be going back there anymore...
  20. Patrick Wong
    18,210
    6,513
    Thanks for providing your vendor list, looks very comprehensive.
    My local Toyota dealer also has a silly policy establishing parts prices above MSRP. Since I don't like to feel stupid (or taken) when buying parts, I buy most parts in bulk from Champion Toyota (Houston) which prices at 25% off list. UPS ground shipping service from Houston to southern CA is excellent.
    Toyotaworld.com - Toyota Parts, Genuine Toyota Parts, Toyota Accessories,TRD Performance Parts, Champion Toyota Gulf Freeway, Houston, Texas
    When I have to buy parts locally based upon freight cost considerations (i.e., a battery or fluids), I will buy from Tustin Toyota. Their pricing is at MSRP, which I don't mind paying for a small qty retail purchase.
