I just got a Prius! (And now I have to work on it!)
Discussion in 'Gen 2 Prius Main Forum' started by Isaac Zachary, Jul 16, 2020.
  1. Isaac Zachary
    Isaac Zachary Senior Member
    2,548
    1,292
    Well, I got the back all put back together and then the Misses and I test drove the Prius a little today with a few short trips here and there around town. We didn't go far or fast, but I do think we did enough to prove the HV battery works.
    Interestingly, even though I drove enough to get the engine up to running temps and we did a few different trips, the CEL did not come on at all for the fouled catalytic converter. I'm sure it will though one of these next times I drive it.
    The next thing to do on the list is to figure out that lower frequency whining sound it makes that corresponds to vehicle speed. My first thought was that the bumper cover was rubbing on the tire. But I got that screwed down so they won't touch each other. I went to check transaxle fluid levels but didn't find the right sized Allen wrench, plus it's getting dark. I'll look at it tomorrow. I wonder if it uses the same Toyota ATF my Avalon HV uses. Hopefully it's not the transaxle and may be a wheel bearing.
    I don't remember if I mentioned it, but I found a U-Pull-&-Pay junkyard with the same color gen 2 Prius in Colorado Springs that was wrecked from the rear apparently, because the pics show the front in tact. I'll see if they still have the hood, bumper cover, fender and head lamp assembly, and if they do I'll hook up the trailer to the Avalon and try to go get the parts Monday.
  2. Calimobber
    Calimobber Member
    94
    83
    Death Valley
    I think everyone who has every removed the prius battery has forgot to lock the orange plug at some point and gotten code and beep.
    Isaac Zachary likes this.
  3. Sonic_TH
    Sonic_TH Active Member
    573
    96
    Puerto Rico
    2016 Prius c
    Maybe that sounds is a wheel bearing issue, you can lift the car and try to move the wheels from side to sides, if they move the bearing is damaged. Check the brakes too just in case, maybe there is some metal residues on the wheels and disks, who knows.
  4. Isaac Zachary
    2,548
    1,292
    Ya. I tried moving the front wheels, which is where the sound seems to come from. I couldn't get them to move side to side or up and down. But the sound seems to be coming from the frontlfront one. I even road my bicycle asking the outside as my wife drove. I'm not 100% sure that's it's the left front wheel bearing though.
    Transaxle fluid was full.
  5. Sonic_TH
    573
    96
    Puerto Rico
    2016 Prius c
    Well then, you might try and replace it and see if the noise continues.
    Also did you take a look at the brake pads?
  6. Isaac Zachary
    2,548
    1,292
    Pads, not yet. But I will. CV joint boots are in tact. And the rotor discs look good from the outside through the rims.
    I have had a wheel bearing go out on a previous car that caused the pads and rotors to wear badly. Thankfully I may have caught the problem early enough. I'll order a wheel bearing and go from there.
    Hopefully this week I'll have some body parts too.
    Sonic_TH likes this.
  7. Isaac Zachary
    2,548
    1,292
    This reminds me of my 1985 VW Golf. I was replacing a CV axle about once every year. I think the problem was the aftermarket boots couldn't handle the cold here and would crack open every winter.
  8. Isaac Zachary
    2,548
    1,292
    I drove it around even more today and filled the tank for the first time after it started beeping from low fuel level. So far no DTC's using a Torque Pro app, and of course no CEL. The acceleration and deceleration feels much better than with the red triangle battery. Of course I've never driven a Prius with a good battery before.
    I've got a friend with a pickup truck who also needs to go to the same junk yard as I do. I just need to make sure I have enough money for those and the wheel bearing. Otherwise I might get just the parts for now and get the wheel bearing in a week or two when I have more money.
  9. Sonic_TH
    573
    96
    Puerto Rico
    2016 Prius c
    Nice, may i ask for what price you got that Prius?
    Also (you probably did already) don't forget to check the oil, air cabin filter, A/C air blower and the hybrid battery cooling fan.
  10. Isaac Zachary
    2,548
    1,292
    I paid $300 dollars (USA). And another $100 in modules. Oh, and $40 in module charging and discharging tools.
    But adding this car to my insurance policy drops the monthly premiums by about $15 or more a month. So I'm actually saving money on insurance by owning two cars.
    I cleaned out the battery cooling ducts and fan. The fan looked like it was caked in mud. Now it's nice and clean. The battery was also full of pet hair.
    A/C blows nice and cold. But I probably won't be needing it much from now on until next summer. It's getting cold even during the day. I best be installing an engine block heater soon.
    Engine oil level is good, but I want to change it soon. I'll be doing this a bit more often than usual since the previous owner said the engine burns oil at highway speeds, which could be a sign of build up on the oil control rings. I also want to change the transaxle fluid, coolant (both engine and inverter) and brake fluid, along with all the filters: intake, cabin, oil and fuel.
    That is, unless I find a receipt that one of those had been done recently in the folder the previous owner owner gave me. I know he had changed the inverter pump early last year.
    Brakes will need to be checked. Tires look good, but I'm afraid their below the 3/8 inch minimum. I'll be on the lookout for another set of rims to put studded snow tires on.
  11. Sonic_TH
    573
    96
    Puerto Rico
    2016 Prius c
    That's a very good buy actually. And will you be using this car as your daily driver? Update us when you get everything done please.
  12. 8AAGen2
    8AAGen2 New Member
    29
    Maryland
    I
    Congratulations on getting the HV battery working again. Some time ago you mentioned that you had nursed your12V battery back, but you were planning on possibly getting a new one. You said that you wanted to get the largest one that you could for cold winter starting. I'm surprised that no one mentioned it then, but my understanding is that the primary purpose of the 12V battery is to run the lights and boot up the computers. When it's time for the ICE to start, the car uses the HV battery and the MG sets. I think it also might power the ABS, but it's not used to start the ICE. I do think that Toyota recommends an AGM battery instead of a standard wet cell. Might be because of the cycling, but might also be because the battery is in the hatch area instead of under the hood like most cars.
  13. Isaac Zachary
    2,548
    1,292
    Ya, I might be just going off of experience in other non-hybrid cars with my overkill reasoning. We get -40ºF (-40ºC) temps here on occasion and cranking an ICE at those temps can be a pain. (Especially when I owned a 1985 diesel). That and I'm the kind of guy that forgets to turn off his lights. Thankfully I found out the other day that the headlights turn off automatically on the Prius!
    I am planning on going with a Panasonic battery from the dealer. I'm not sure if th3 Panasonic battery in this 2006 Prius is the original (which if it is would be amazing). But I do know that the Panasonic battery in my 2013 Avalon Hybrid is original and still works after 7 years. It seems like most other batteries give out after only 3 to 5 years.
  14. 8AAGen2
    8AAGen2 New Member
    29
    Maryland
    I
    I had a similar experience with the original battery, it lasted about 7 years. For some reason I decided to try the Optima and it lasted a little more than 7 years. I just replaced it with another Optima since I had good luck with the other one.
  15. Prodigyplace
    12,563
    11,778
    Central Virginia
    The 12 volt battery does not start the engine in the Prius. The large HV battery does that. The 13 volt battery is a vented AGM battery for safety reasons since ti is in the passenger compartment. Do not use a regular lead acid battery. You do not want hydrogen gas in the passenger compartment.
    #95 Prodigyplace, Oct 1, 2020
  16. Isaac Zachary
    2,548
    1,292
    I went to the Junk Yard in the Avalon this weekend and was able to find a hood, fender and belly pan. But no headlight or bumper cover.
    Just a question on the headlight. I keep seeing ads for Halogen, Xenon, HID and LED headlights. What is the one that I'm trying to replace? Did Toyota make different headlights for the Prius? How do I tell which one is it that I have? PXL_20201005_164501862.jpg PXL_20201005_164515091.jpg PXL_20201005_164523922.jpg
  17. dolj
    dolj Senior Member
    8,446
    4,291
    Wellington, New Zealand
    Yes, HID (high intensity discharge) and halogen.
    Either by knowing the package number you have and/or running the VIN through the Toyota Owner's portal. Apparently, some say that if you have fog lights, you also have HID, and if you don't have fog lights you have halogen.
    Those look like halogen, but I'm not sure what the bulb cap looks like on an HID assembly, but it looks very similar to mine which is halogen.
  18. Isaac Zachary
    2,548
    1,292
    Oddly, when I plug my VIN into Parts.Toyota.com and go to the headlamp section I get both types of bulbs in the list. o_O
    I briefly tried to get the bulb out to look at it, but in the tight space and short amount of time I only got a small glimpse of it. The bulb appears to be halogen, but it's also oddly blue in color, so must be some sort of aftermarket blue bulb.
    So I followed your advice and looked up the Toyota Owner's portal and was able to confirm they are halogen. Yoohoo! It's also a 2006 Prius STD, by the way, according to the Toyota site. :)
  19. Prodigyplace
    12,563
    11,778
    Central Virginia
    How do you cure THAT disease???
  20. 8AAGen2
    8AAGen2 New Member
    29
    Maryland
    I
    I have a 2004 with HID and I wish that they were halogen. The HIDs are not particularly bright, or the optics are not that great. My Subaru Forester with halogens does a much better job of lighting the road.
    I'm not sure about the Prius halogens, but if they have the same type of cap on the back of the housing, you may have trouble getting them off. They have a bayonet type closure, but to keep water out, they put a big o-ring on the opening. The problem is that while it should be relatively easy to open, it will probably be more like opening a tight jar. You'll probably be able to find some postings here with various ways that people got them loose. When you do get them apart to replace your bulbs, think about putting a thin coating of silicon grease on the o-ring. That should make them much easier to get off again in the future.
