I just had a software update and this is happening
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Taxi/Limo, Feb 15, 2019.
  1. Taxi/Limo
    Taxi/Limo Active Member
    509
    107
    I brought my 2010 in for a software update to the dealer
    Now my little tire pressure warning light is on solid
    also
    It blinks for a little while and then becomes solid
    This has never happened before
    I am wondering if they are going to believe me when I call
    Has this happened to any of you if so what did you do?
    Thanks
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Are the tire pressures good?
    It could be that one of the sensors was on its way out and needs replaced and it is ironic timing.
    If pressures are good, that’s what I’d say;).
    Good luck and keep us posted (y).
    SFO, Mendel Leisk and jerrymildred like this.
  3. Taxi/Limo
    509
    107
    I will check tire pressure
    I don't think it's coincidence They did an over all inspection including tire pressure so I think something else happened there
    I spoke to the dealer and they want to charge me to do check it out
    Note
    I see there is a procedure to initialize tire pressure monitoring system so I wonder if they changed the pressure so much that I have to do that
    #3 Taxi/Limo, Feb 15, 2019
  4. PosauneGuy
    PosauneGuy Member
    117
    88
    California, here I come...
    Maybe the software update cleared out the TPMS sensor IDs? (It takes 20 minutes for the TPMS light to go on if the sensors are not recognized.)
  5. Mendel Leisk
    38,720
    Were you running higher pressures? If so, and you had done the TPMS reset at that higher, and they set them lower (especially if they did it soon after you arrived, tire pressures elevated due to driving), that might have triggered the TPMS.
    Yes, first step, get that out of the way.
    jerrymildred likes this.
  6. Taxi/Limo
    509
    107
    That is interesting and it seems about right the light did not go on immediately but shortly after I picked up the car
    How do you fix that ?
    Mendel
    I was running higher tire pressure for gas economy I think 36 psi
  7. Mendel Leisk
    38,720
    Those sound like a defective/missing sensor. But again: check pressures first. Or even just visually check, very first, lol.
  8. Taxi/Limo
    509
    107
    Pressure is 31 pounds all around I set it at 36 about a year ago so the tech changed it I think
    Do dealerships sometimes create malfunctions to generate income?
    Is is possible to disable the TMPS?
    Where is the TMPS computer module located?
    What does a new sensor cost and can I install it myself ?
    Thanks
  9. Lightning Racer
    Lightning Racer Active Member
    239
    320
    Anchorage, Alaska
    Did you try resetting the TPMS?
    If that doesn't work, you can disable the system by using the trick in this post. Read beyond that post until the end, because you’ll probably jumper the wrong holes. The diagram is showing the backside of the connector.
    Idea to fool the tire pressure sensors | Page 3 | PriusChat
  10. Mendel Leisk
    38,720
    Just to ask the stupid question: you raised the pressures, and light did not go out?
  11. Taxi/Limo
    509
    107
    I adjusted the pressure according to the door markings
    35 in the front and 33 in the back I used a guage to check and I think it was pretty close
    The light did not go out
    Then I tried to reset the TPMS the light did not go out
    I don't now what the problem is
    I am wondering
    if the tech who checked my cabin filter which is behind the glove box also where the (TPMS computer is located )
    did something to the TMPS computer like knocked it or disconnected something when he was in there
    just speculating
  12. Salamander_King
    Salamander_King Senior Member
    10,975
    8,864
    New England
    As others have chimed in, the blinking TPMS light that stays solid means one or more of TPMS inside tires are bad. It is just a coincidence, software update or cabin filter change has nothing to do with it. Your car is 9 years old, and battery in TPMS sensors are rated to last ~7 years. If you really want to fix it, take your car to any tire shop and ask for an aftermarket TPMS sensor. It should be about $50 labor included for one TPMS if only one dead battery. If you take your car back to a dealer and use OEM TPMS the same procedure will cost you upward of $200. However, even if only one dead battery, it may be prudent to change all four TPMS preemptively to save your time and money later. How are your tires on your car? If they are due to replacing soon, I would just wait until you are ready to buy a new set of tires and install a new set of 4 TPMS at that time to save even more time and cost on installation. Or, you can simply ignore TPMS warning light altogether and buy one of external TPMS monitor (~$40 at Amazon) or practice due diligence on monitoring tire pressure on a regular base with your handheld pressure gauge.
    88skisupreme, orenji and RMB like this.
  13. orenji
    orenji Senior Member
    5,884
    3,486
    As the above poster stated. You have one or more TPS with a dead battery. Need to replace one or more.
  14. Taxi/Limo
    509
    107
    Here is an update on this thread the TPMS problem corrected itself as far as I can tell
    The light on the dash does not come on anymore
    I did not replace anything
    Mendel Leisk and bisco like this.
  15. davecook89t
    davecook89t Senior Member
    1,057
    789
    Washington State, Florida
    Four Touring
    The TPMS light in our 2007 was doing the same thing as the OP's several months ago. When I went into Techstream, I saw that one of the sensors was not reporting. I thought I would replace that one sensor when I put on new tires, but after clearing the code a couple of times, the light has stayed off. (Actually, it has come on solid a couple of times since, but when I checked the tire pressures, I have found one of them to be low, whenever the light has been lit). Someone mentioned that although the batteries will eventually die, they can sometimes be brought back to life, through some unknown process. I'm wondering if the act of trying to poll them through Techstream or possibly resetting them several times using the under dash button might have temporarily resurrected the one that was giving us problems. (Of course, now that I've said something, it is sure to start acting up again.):eek:
    Taxi/Limo likes this.
  16. Taxi/Limo
    509
    107
    I still think my problem had something do to with the dealer visit but I do not have enough knowledge to prove or disprove this
    ice9 likes this.
