I just looked on Ebay for after market catalytic converters
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Dec 20, 2020.
  1. ski.dive
    ski.dive Active Member
    899
    232
    Hutchinson Island,FL. Mt. Snow,VT
    I just looked on Ebay for an after market catalytic converter
    Are these Ebay catalytic converters the same quality?
    =Prices vary from $115.00 to $200.00
  2. alftoy
    alftoy Senior Member
    1,132
    510
    Saskatchewan, Canada
  3. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    Another good one is the Walker 93251.
  4. alftoy
    1,132
    510
  5. alftoy
    1,132
    510
    Duplicate
  6. Paul Schenck
    Paul Schenck Active Member
    523
    306
    Fresno, California
    I got a magna-flow in California for my 2005 in 2019 it didn’t pass the inspection because nothing but $2000 OEM is acceptable. I did test it and it does perform a little bit better than the OEM. I found this out because I ran both. The magnaflow has more titanium and a larger surface area and heat shield. Allowing a thorough burn of any uncombusted hydrocarbons.
    So I keep a mid section OEM in the garage just for inspections (I rent it out too $$), and I run the magnaflow. It is illegal to “modify” your exaust $12,000 per offense. So you won’t find anyone willing to install it in this state.
    iPhone ?
    Skibob and caliwaves like this.
  7. alftoy
    1,132
    510
    Ha, what will you do if the thieves happen to hit up your cat from the renter?
  8. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    One should be able to install the renter, drive to the smog shop, pass and change back in the same day. That would be the smart thing to do.
  9. Skibob
    2,912
    1,496
    Northern California
    565 vs. 2000, that's a big difference. Plus then the dirt bags get the cheap cat and you get the $$$ for a new one. How did you get one? I believe they wont ship to California? Also what did you use for the back half of the pipe, past the cats?
    #9 Skibob, Dec 21, 2020
  10. bisco
    49,558
    i looked on ebay, but didn't see anything (n)
  11. Paul Schenck
    523
    306
    Fresno, California
    Not likely, they come by I help them make the swap and pass their test and then we swap it back. And you know how a thief feels when they go to steel a $2k Cat and find a $200 one instead!!! It’s cheaper than the Antitheft device too, isn’t it?
    iPhone ?
    Skibob likes this.
  12. Paul Schenck
    523
    306
    Fresno, California
    I have out of state friends. You can have it delivered to a Walgreens drop box over a nearby border and go get it.
    iPhone ?
    Skibob likes this.
  13. Paul Schenck
    523
    306
    Fresno, California
    I wonder if you could just call and make an appointment with an out of state mechanic and ship it to him?
    iPhone ?
  14. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Got my cat off Amazon $129. Works good no codes so far.
    As quiet as stock.
    Paul Schenck and Skibob like this.
  15. edthefox5
    10,096
    4,806
    Clearwater, Florida
    Like most after market cats the donut was half the size as the oem and unusable the bolts were wrong too. So if they stole the donut too you will need a new one factory donut pic of the part number.
    $86.
    You may need an o2 sensor too as they take that also. Don't have the part number for that.
