I just switched the motor and engine on my 2008 prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Miguel Olivares, Jan 15, 2017.
  1. Miguel Olivares
    Miguel Olivares Junior Member
    56
    Oakland
    Dad and I switched the motor and engine.
    The red trinangle and check shone light show up.
    Is there anyway tech stream can reset them?
  2. JC91006
    16,496
    8,406
    You can simply unplug the 12v battery to reset or clear codes with techstream.
    If there's an error, those lights will return
  3. jerrymildred
    jerrymildred Senior Member
    11,518
    14,124
    Tampa, FL
    It can reset any code, afaik. Obviously, the code will pop right back up if the problem isn't fixed, but I'm pretty sure it will reset.
    BTW, the car only has one engine, so that's easy to decipher. But it has two motors. Did you replace MG1 or MG2? Must have been some serious problems!
  4. Miguel Olivares
    56
    Oakland
    We replaced the engine/tranny component.
    How does one reset the code within the program?
  5. Miguel Olivares
    56
    Oakland
    So all I do is unplug the 12v battery for 10 seconds and reconnect it to clear the codes?
    jerrymildred likes this.
  6. jerrymildred
    11,518
    14,124
    Tampa, FL
    That should do it, too.
  7. bisco
    49,722
    congrats on a difficult job miguel!(y)
  8. Miguel Olivares
    56
    Oakland
    The light still turns on. As a matter of fact, the red triangle and the check engine light is on AND the car won't go into drive or reverse at all now haha.
    Anyway to at least get it into drive or reverse? I remember we had this error once with another vehicle and we had apparently reconnected some cabled in a wrong order.
  9. JC91006
    16,496
    8,406
    Check your 12v battery voltage, make sure it's over 12.5-volts
  10. Miguel Olivares
    56
    Oakland
    Using tech stream right? Check the 12v battery using tech stream? If so, what the do I click to check this?
  11. bisco
    49,722
    not sure, but a volt meter when the battery is cold should read at least 12.4 v.
  12. edthefox5
    edthefox5 Senior Member
    10,096
    4,810
    Clearwater, Florida
    Probably the orange hybrid battery safety interlock is not installed or the handle has not been locked down,
    I assume you removed it when u swapped the tranny?
  13. Miguel Olivares
    56
    Oakland
    in the rear right?
  14. edthefox5
    10,096
    4,810
    Clearwater, Florida
    It's in the drivers side of the hybrid battery pack. It's orange.
    Did u remove it before the trans swap?
    If u did and replaced it everyone always messes up the last step which is to slide the handle up then down to lock it in place.
    Car is disabled if that safety swx is not installed right.
  15. Miguel Olivares
    56
    Oakland
    Too late, we ended up putting the old tranny back and the car works now. Weird.
  16. JC91006
    16,496
    8,406
    You put the old one back? No way!!!
  17. Miguel Olivares
    56
    Oakland
    Yeah my dad'a a beast, did it in less than 3 hours.
    I guess the new tranny we bought with 70k had some problems. Oh well, maybe next time it'll work.
    SFO and donbright like this.
  18. JC91006
    16,496
    8,406
    But the reason you replaced it was because it's bad? Now you stuck it back in? Your dad must love working on cars
  19. edthefox5
    10,096
    4,810
    Clearwater, Florida
    Damn he's a beast!!!!
    donbright likes this.
