I keep having to replace the halogen headlight bulbs due to lowbeam failure
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by prius8654, Aug 17, 2017.
  1. ChapmanF
    19,025
    I think it might be the white plug. If it's anything like the Gen 1, 3, and 4 (and it would be weird for Gen 2 to be different), it's a screw with a big wide "head" that has teeth facing forward, and you can turn it like a bevel gear by using a long Phillips screwdriver from straight up above. Easy peasy, once you know what you're looking for.
    Here's the post where I finally figured it out for my Gen 1. You can see how they even molded little guides into the housing to help your screwdriver straight down to the adjuster. I can see what look like the same sort of guides molded into your picture.
    Looking around a Gen 4 in the showroom, I noticed they finally mentioned the adjuster right in the owner's manual in the glove box, and even had the location labeled under the hood. Only took them sixteen years....
    -Chap
    edthefox5 likes this.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Oh I see what you mean with slant guide hole. Tomorrow I will look at them and see how hard it is to adjust them.
    Thanks.
  3. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    I had this very issue with my Yaris. Not sure what was going on, but during one of the remove/install I damaged the rubber grommet that was around the plug the bulb was installed in. So I bought a new grommet.
    I never had to replace another bulb. coincidence, iono. But thought it worth a mention, especially since that grommet was less than $20.00. Well for a Yaris anyways.
    prius8654 likes this.
  4. prius8654
    prius8654 Junior Member
    That's helpful, thank you. Next time I'm in there I'll inspect the grommets
  5. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Are you talking about the black rubber cover that goes over the bulb? That's a real pain to get off the first time its really stuck on there. It just comes off by turning it CCW to the 10 o'clock position using the 2 big squares as a lever. Its keyed. You put it on about 10 oclock and then turn it CW until its straight up in the picture.
    Its a weather boot. After the bulb install the boot goes over everything.
  6. V Paki
    V Paki Junior Member
    Pacific Paliisasez
    Interesting, what is the Toyota Enhancement warranty and how does one avail of it? Thanks!
  7. prius8654
    The enhancement warranty is only for the HID (xenon) bulbs not for halogens. The issue I was having was specifically with halogen bulbs, my car was not equipped with HIDs.
  8. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
  9. V Paki
    Pacific Paliisasez
    Thanks. My 2005 has Halogens and one is going out. Do you have any specific docs re the enhancement warranty?
  10. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    Halogen bulbs tend not to last >10 years.
  11. prius8654
    I think you may want to reread the entire thread, the enhancement warranty does not apply to halogens.
  12. V Paki
    Pacific Paliisasez
    I think I keep saying Halogens when I mean HIDs and I cannot blame my keyboard this time. My prius has HIDs!
