I left my Prius c on all night ??
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Manny koutalides, Dec 27, 2012.
  1. UberLyftDriver
    UberLyftDriver New Member
    The Earth
    Fauxnight: You actually CAN
    Lock your PRIUS's door with the engine running, Here's how: look at your SKS Magic key case. On the side there actually is a toggle-like switch press the one side of it and pull and seperate the key ring, This releases a generic looking key-like object this can be inserted into your door lock just like a key turn it to the left to lock and right to unlock your car. Slide that key back into that case and it clicks back into place. When you return to your prius it will not open in the usual way unless the manual key is inserted again amd turned to the right. - this keyhole only exists on the driver side door. I use this all the time since I run dash Cams inside the car and
    Don't want them to have to reset and run the risk of someone stealing the car while it is running.
