I love my job yesterday!!! EGR Cooler and EGR pipe cleaning
Discussion in 'Gen 3 Prius Main Forum' started by htcmember, Jun 12, 2022.
  1. htcmember
    htcmember Junior Member
    56
    17
    At almost 200k miles and i decided to clean it before a check-engine light come up (P0401)
    Look at how dirty it was and shiny that I could clean, work every single minutes of my weekeend
    And i saw that the previous owner does not installed gasket on the end of EGR cooler, Is it a must to install the EGR Cooler gasket?
    I've tried to order it from an nearby autoparts store but it took me by around evening time of Sunday (today) to have it available in store to pick up
    Sir, @Mendel Leisk , do you have idea if it's a must to install it back? Because when I took it apart, I did not see the gasket. Thank you Sir for advises!
    And nice Sunday to you all
    Riley
    #1 htcmember, Jun 12, 2022
    mikey_t likes this.
  2. xliderider
    xliderider Senior Member
    8,056
    3,223
    Honolulu, HI
    How many miles on the odometer? You should have a gasket, and it should be available at Toyota parts department(s).
    htcmember likes this.
  3. htcmember
    56
    17
    thanks for your advise, it's almost 200k miles this week. and from when i've took it apart, seem no one touch on this before, it's mostly lucky that it's not blown my head gaskets on my trips :)
  4. ChapmanF
    17,349
    If you had posted the flow numbers from before and after cleaning at that mileage, it would have given us a good data point.
    Had you seen a check-engine light or P0401 yet?
  5. htcmember
    56
    17
    No, i don't have an check engine light for P0401 until now. and do you know how to get the flow numbers w/o using Techstream? i don't have one right now to test, a have wifi OBD2 that i've using to monitor my battery, coolant...
  6. ChapmanF
    17,349
    It's a standard OBD "Mode 6" monitor test result; various scan tools and phone apps can bring it up. There are some examples in that linked thread.
  7. htcmember
    56
    17
    Can you share me a little bit more on that, i will try to capture today when i assembly them all back and give it a test too with OBD2 and torque pro if possible. thank a lot in advance and i appreciate your help and advise!
  8. ChapmanF
    17,349
    Try looking at this post and the few after it in that thread I linked. Part way down on page 3 of the thread, the page I linked to.
  9. Mendel Leisk
    40,586
    It might have been there, and dropped when you pulled the cooler. That’s what happened to me. Have a look: mine dropped a little ways, not all the way through.
  10. htcmember
    56
    17
    Let me try to find again, weird thing that I can not find it all evening yesterday
  11. htcmember
    56
    17
    Here are my test value after test drive today
    MID:$21 TID:$a9
    - Catalyst Monitor Bank 1
    Max: 9.99393 Min: 0.24979
    Test result value: 0.25894
    PASS
    MID:$31 TID:$bd
    - EGR Monitor Bank 1
    Max: 655.34998kPa Min: 0.87kPa
    Test result value: 20.03kPa
    PASS
    But during tonight ride, i suddently heard a sound from torque app that made me heart attack "inverter coolant overheat" and it pops up the screenshot as below with inv coolant = 170oC ????? OMG
    Hope that's only a faulty issue with my OBD2 tool Screenshot_20220614-214959_Torque.jpg
  12. ASRDogman
    ASRDogman Senior Member
    7,243
    3,781
    Maybe the invertor pump is bad? And if you know the "obd tool" is bad, why trust it with
    any other reading?
  13. ChapmanF
    17,349
    That's right in the ballpark of results we've been seeing after full cleaning.
    What would have been really interesting would be your number at almost 200k before cleaning.
  14. htcmember
    56
    17
    yes, my bad that not thinking about that before doing my job so that we can have a clear before and after with a great 200k experience :)
    Btw, do you have any suggest on how to test the inverter pump to make sure i'm ok on the inverter coolant overheat issue that shared above?
    Loop Sir @Mendel Leisk in as well to advise :)
    thank you,
  15. ChapmanF
    17,349
    The typical check is to go look in the inverter coolant reservoir while the car is IG ON, and see if the coolant is turbulent.
    In Gen 1 and Gen 2, the pump was just on or off, and ran whenever the car was IG ON, so that was easy.
    In Gen 3 it's a variable-speed pump, and the ECU is more hands-on in controlling it, so the same check might not be quite as foolproof. On the other hand, the Gen 3 inverter pump has a tachometer, and if your scan tool shows you that PID ("Inverter W/P Revolution" is what it's called in Techstream), you can look at that. It's in the Hybrid Control data list.
  16. htcmember
    56
    17
    in this case, i would like to buy a Techstream clone device from ebay/amazon to deeply investigate my issue, do you have any suggestion on a good tool as your experience? i see a lot of one selling on ebay now but not sure which one is good enough for Techstream testing?
  17. ChapmanF
    17,349
    I would suggest a forum search; you'll find a lot of those kinds of reports here, running from recent to years old. With older ones, some of the information may have gone out of date, but they can still be worth looking at. I don't really have anything to speak of that I could add myself to what's already here about that.
  18. htcmember
    56
    17
    Sure and thanks for your advises as always, i really appreciate these help!
  19. Tande
    Tande Active Member
    525
    310
    Mich.
    FWIW .......I sorta like the idea, that if "Toyota" thinks it should be there......it's OK with me! ........
  20. htcmember
    56
    17
    Hi @ChapmanF,
    I've tried to check and test with Torque.
    It's actually turbulent and the inverter pump also showed as attached pics.
    And i have a camp trip on my prius this weekend, really concern about that but can not deeply check the issue w/o TechStream OBD2 cable? Hope that we have other way to double check so that i can have peace of mind for my trip :)
    Thank you,
