I melted my car (with picture)! Help!
Discussion in 'Gen 4 Prius Main Forum' started by The Professor, Sep 20, 2018.
  1. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    So I found this really pleasant smelling coconut air freshener, in a tiny little bottle, and it hangs on something a bit like a length of paracord that is threaded through a wooden screw top. The wood is meant to diffuse the scent. I hate things hanging off the mirror, so instead I looped the paracord over the gear selector. Great! Car smelt amazing.
    When I went to replace it today, I realised the strings had wicked up the liquid (it was damp) and this liquid had literally melted into the plastic surround! Check out the picture! There are two groves at the bottom of the white plastic bit where the laces were touching, and further damage on the left hand side where it was touching there also.
    Won't be using that again!
    Can anyone help me find the part number of this white plastic surround so I can order one? I assume it all just clips together?
    MrMischief likes this.
  2. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    Woops. That must be strong solvent. People have installed black shifter applique over the white shifter, but I don't know white applique exists. Not sure if you can easily take it off the OEM part. Search for "shifter applique for Prius".
    DLC82SV likes this.
  3. The Professor
    598
    809
    UK
    Excel
    Would rather have black anyway to be honest
  4. Salamander_King
    11,024
    8,980
    New England
  5. davecook89t
    davecook89t Senior Member
    1,093
    832
    Washington State, Florida
    Strong solvent or very cheesy plastic panel?:eek: I thought the reviewers called that "hard plastic". Apparently not.
  6. The Professor
    598
    809
    UK
    Excel
    Ingredients don't list anything super obvious that will melt plastic (e.g. Acetone). Anyway - this is the little bastard! Smelled really amazing and very subtle... so disappointed.
  7. davecook89t
    1,093
    832
    Thanks for the warning. From the packaging, it seems innocuous enough. The warning verbiage is something you could expect to find on any product containing chemicals. We've all used those pine scented cardboard Christmas tree cutouts, and including an image of that on the front would lead one to believe their product is perfectly harmless. I'm sure you were as shocked to see what kind of damage it did as any of us would have been.
    DLC82SV likes this.
  8. The Professor
    598
    809
    UK
    Excel
    Yep - bought it in Asda in the UK (same company as Walmart in the US). It's reasonably reputable. Certainly didn't expect that kind of damage. I could see it doing the same to plastics used in on the mirror that they recommend hanging it from.
    DLC82SV likes this.
  9. MichelleStone
    MichelleStone Senior Member
    549
    819
    Mariposa, CA
    That's so disappointing. Bad product and it messed up your car. I'm such a boob when it comes to damage to my car. I feel for you.
    DLC82SV and The Professor like this.
  10. ChapmanF
    19,047
    I accomplished the same thing a few years ago by letting a small bottle of DEET bug repellent sit on the plastic top of my washing machine.
    -Chap
    DLC82SV and fuzzy1 like this.
  11. fuzzy1
    10,722
    I've had similar damage to the plastic bag containment around a DEET bottle that leaked inside checked luggage during a flight.
    The original plastic bottle was properly resistant, but its top didn't adequately seal against air pressure changes, and the plastic bags I put around it were not properly resistant to the stuff.
    Back to the OP, that first active ingredient, "(R)-p-mentha-1,8-diene", is a hydrocarbon, the major component in the oil of citrus fruit peels, and a renewables-based solvent. Here is more about it than I understand:
    Limonene - Wikipedia
    (R)-p-mentha-1,8-diene - Substance Information - ECHA
    DLC82SV, RCO, iplug and 2 others like this.
  12. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    The first ingredient is I believe Limonene. It is "fake citrus" smell so used in lots of cheap fragrances but more notably it is a paint stripper and plastic solvent. It is really good at eating away bio-plastics, aka almost the entire Prius. I use it with my 3D printer when I print a dual extrusion with HIPS plastic for support and ABS for structure. The HIPS just turns to goo and melts away. Used in lots of cleaning products because it smells mildly nice and also kills things chemically. How fun.
    Acetone does the same thing to ABS as you say but won't do anything to HIPS.
    The coumarin just makes it smell like fake cinnamon (cassia). The citronellol is actually more of a flower garden smell, like a rose or lemongrass. It's another very cheap scent chemical and in high enough quantities even the mosquitos will hate you.
    That little bottle is a swirl of evil spirits. Everything in it is toxic in some way and can cause anything from irritation if it gets on your skin to blindness if you touch your eyeballs. Some of the stuff is thought to cause various forms of kidney tumours even. But it's not proven... yet.
    Also, none of that is coconut lol. You have "cinnamon-lemon-orange-garden-bed" smell. I would not put that anywhere near me let alone hang it in a car where it would splash all over me in an accident. Not to mention most of those chemicals are super flammable...
    DLC82SV, DonD, RCO and 4 others like this.
  13. fuzzy1
    10,722
    Apparently the D-isomer is a major component of the oil in citrus peels, is part of the fragrance of oranges, and is used as a food flavoring agent. So it can't be too toxic, at least in those more natural doses.
    As for flammable yes. As an officemate once demonstrated that, the spray coming out of squeezed orange peel is itself flammable.
    #13 fuzzy1, Sep 20, 2018
    DLC82SV and RCO like this.
  14. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    #14 alanclarkeau, Sep 20, 2018
    DLC82SV likes this.
  15. alanwagen
    alanwagen Member
    122
    79
    FORT WORTH
    2018 Prius
    So if it does that to plastic. What is it doing to your lungs? I hate a fake fragrances. Most of them are unsafe.
    DLC82SV and alanclarkeau like this.
  16. alanclarkeau
    7,045
    7,593
    I'm only a mild asthmatic, but they get me short of breath. Never put one in my car, but one car I bought had one in, I tossed it straight away, but the residual stench of it mixed with stale smoke came back every summer. Despite scrubbing the car thoroughly, it never went.
    I became transport provider for Mum & Dad after Dad wasn't able to drive any more - Mum would spray some perfume on herself just as she left the house to get in the car - which would leave me breathless in the closed car. And often, I'd still be wheezy later in the day/night, as though it had an ongoing effect. I had to finally ask her, if she was going to put it on, to do so well before I got there ("like a couple of days" I muttered under my breath!!).
    padroo and DLC82SV like this.
  17. fuzzy1
    10,722
    DLC82SV likes this.
  18. Elektroingenieur
    2,515
    3,288
    Three Touring
    Toyota calls this part the shift lever hole cover, and for right-hand drive cars, it has part number 58841-47050.
    Yes; the cover is secured with five orange plastic clips, part number 90467-05171. The Repair Manual (available by subscription to toyota-tech.eu) says to use a molding remover to disengage these.
    The pattern select (EV MODE, DRIVE MODE) and transmission shift main (P) switch assemblies are sold separately, and each has an electrical connector.
  19. alanclarkeau
    7,045
    7,593
    o_O - I thought it was unrelated to real citrus - but some GOOGLE searches indicate that Citrus skin does contain the same chemical. I'll be more cautious - though I tend not to eat the skin. I remember quite a few years ago that they started selling a washing detergent which was "lemon fresh" which supposedly had real lemon in it.
    I hope citrus doesn't get "banned" - I've got an early and a late orange tree, and an early and a late mandarin keeping me in fruit for almost 6 months.
    DLC82SV and Prodigyplace like this.
  20. fuzzy1
    10,722
    ... which is what I've been trying to point out with and since my link to Wikipedia at post #11.
    DLC82SV likes this.
