I need a steering Rack for 2001 Prius
Discussion in 'Generation 1 Prius Discussion' started by GinnyV, Jun 25, 2024.
  1. GinnyV
    GinnyV New Member
    2001 Prius
    Hi. The steering rack has failed though it was replaced once at 37,000 miles. Now it has 128,000. I think the car is in good shape otherwise. The hybrid battery was replaced and only has 50,000 on it. New inverter pump last June and brand new 12 volt battery (which keeps draining-could be related to the bad steering rack). The recall work was done in 2011. I’ve been driving the car since 2020 when it had 85,000 miles on it. Got it from a friend who bought it new.
    I called Toyota America to get some assistance (discount) on OEM steering rack. They won’t do anything because of the age of the car despite low mileage so HELP I NEED A STEERING RACK and PINION is what the dealership told me.
    I’m in California near San Jose. Someone named Ron on this thread said he was parting out all his cars. Any help greatly appreciated. Been without my car for a couple of months now.
  2. Tombukt2
    Tombukt2 Senior Member
    13,868
    2,520
    Durham NC
    Yeah there's a place here in North Carolina that's probably got two or three of them at one point they were trying to get them back on the road but I think they've given up as the screens and the plastics inside on the dash and whatnot are all failing like they do so you could probably get it It's a place called reliable towing in Fayetteville North Carolina and he would be agreeable to shipping The guy's name is King yeah no kidding but he's a good guy I know him pretty well he's very reasonable human being very nice fella I've done some work for him I should know his number by heart but I don't But you want to call reliable towing in Fayetteville North Carolina where fort Bragg is the army base and ask for King if his brother answers he's kind of goofy You want to speak to King leave your number he will call directly. I am sure he can help you out You are prohibitively far away but you got to do what you got to do I would be shocked that somewhere in California some breaker yard can't provide you with that piece but then again. I've never really looked at these I would think some other cars would be pretty much identical like an early Yaris I would think the rack would be almost identical The tie rod ends may be different measuring and seeing what that is just changing the outers usually but I'm not certain about that model the steering power and all that is above your knees and most of these so you're just connecting to a pretty basic manual type rack and then the part above your knees is taking over the feedback and the power steering portion of it and all of that. We've changed racks and other vehicles with racks from other vehicles with similar here before when we couldn't find we were looking but for a manual rack like this that's powered up stream without a power steering pump and all that I would think that should be reasonably not too hard to source You do know for a fact that A1 cardone does not or cannot do anything?
  3. Tombukt2
    13,868
    2,520
    Durham NC
    It does look like to me in the master catalog A1 cardone has you covered at about $136 should not be an issue I see them on eBay parts geek and a few other places so I don't think they're really that special to be honest with you everything that deals with the steering and power is above the flex joint on the rack inside the car so if the rack will bolt to the firewall and reach the steering knuckles in the straight ahead position and bolt up should be good to go I'm just being funny here but still looks like they're covered pretty well that rack there's not much to it it's not a very expensive rack You should be able to fix it pretty easily I would think in that year model much newer not so much doesn't yours have an adjustment ring around the big end down there where the flex joint slides on the spleen shaft that should be completely able to be broken down and dealt with which is what A1 cardone is doing for you so why bother
  4. ChapmanF
    19,041
    Yeah, the gen 1 rack was kind of not like other cars, because the power steering electric motor and torque sensor are built right into it. Later gens moved that stuff farther up the steering column so they could use a more standard manual rack instead.
    I do remember seeing an A1 Cardone product listed, at least at one time.
  5. ronlewis
    ronlewis Active Member
    1,061
    206
    texas
    2001 Prius
    I'd be interested to know how they diagnosed that. Not saying it's not accurate, did they tell you the codes? And the P/S symbol lit up?
    I wonder whether simply unplugging it's harness connector at the ECM behind the glove box might allow her to drive it, even if it's hard to steer.
    I do have a couple of cars with complete steering/suspensions - it's just a PITA to remove them. I see you're in San Jose - most of the first gen Prii left in America are in California. probably 70% of these at auction are in CA. And that's because most were sold there, and now, no one there wants them because they require CARB cats, and all the thieves are stealing the cats. The dismantlers should be overflowing with these parts in CA.
    Be nice to know why yours keep going out, if they're really going out. The symptom you described - real hard to turn all the time - makes me suspect an electrical issue first, or at least, that'd be the first thing to check.
  6. ronlewis
    1,061
    206
    texas
    2001 Prius
    SYK, if you have this car covered by comp and collision insurance in CA, the slightest scratch will make your insurer total the car. You probably only have the coverage because you're a long-time customer. They look for reasons to cancel these policies because odds are it's a matter of time before the cats are stolen and they're paying out the nose for CARB replacements. And, as soon as they do repair the car, the cats just get stolen again. It's only in CARB states because they have to have high-dollar cats. Not that I'd suggest getting a scratch.
  7. GinnyV
    GinnyV New Member
    2001 Prius
    Thank you, There are used parts available in Cali and Oregon. But I will call King on Monday or maybe even tomorrow and see if he has any advice for me. I have no car mechanic skills so like Blanche DuBois in the movie “A Streetcar Named Desire" I’m relying on the kindness of others...
    I called Autozone near me and for a Cardone rack and pinion they wanted $875 so I’m not sure where you saw that price. Also a shop I went to today told me they won’t install Cardone parts they are not any good. So I’ don’t know...
    #7 GinnyV, Jun 28, 2024
  8. ChapmanF
    19,041
    Would one be better than the one you've got?
    What's wrong with the one you've got?
  9. ronlewis
    1,061
    206
    texas
    2001 Prius
    Hey, guys - I was talking to Ginny about disconnecting the power steering harness as a long-term temp fix to allow her to drive the car. I have no idea what's wrong with her steering, but this seems so easy that it's worth a try. Still, she's doesn't work on cars at all, so I'm thinking - couldn't she just pull a fuse or relay to accomplish the same thing? Or maybe just to test, and if it does allow the car to revert to manual, non-power steering, then go forward with disconnecting the harness.
  10. GinnyV
    GinnyV New Member
    2001 Prius
    Here’s a pic of the fuse box on the left column near the steering wheel? Is one of these involved? I jumped my car today and it started. I tried turning the wheel in either direction. Worse on left but both bad. Really feels like the problem is in the steering column…but Toyota said it was the steering rack. After a couple of attempts to turn (with the car in neutral in the driveway) the PS light came on. I jumped it again and now I’m charging the 12V. It’s a NEW NAPA battery and it keeps discharging so something is drawing on it and the car is also sitting and not being driven. I was going to try Ron’s idea above but I’m a little nervous about that since I’m not a car geek at all…I wish I were. Thanks for Ron’s help so far.
  11. GinnyV
    GinnyV New Member
    2001 Prius
    I wish I knew. The steering in my 2001 prius with 128,000 got bad over time and now it’s terrible. The rack has been replaced once. When I try to turn the wheel there is alot of resistance and noise (like rubbiing/grinding) in the steering column. No noise otherwise. No codes. PS light comes on if you keep trying to turn the wheel and car becomes undrivable. I took it into Toyota and they said the grounds and electrical were good and the mechanical failed. I have no confidence that they did any diagnostic on it beyond trying to turn the wheel. They want me to replace the steering rack and pinion to the tune of $2500 to 3500 depending on how I secure the part.
  12. GinnyV
    GinnyV New Member
    2001 Prius
    An independent toyota shop told me they don’t like Cardone and wont install them. They also cost 875 which is 500 more than Detroit Axle who claim to have one for $300. I know nothing about either.
  13. ronlewis
    1,061
    206
    texas
    2001 Prius
    I had hoped someone else could confirm that pulling a fuse would work for that test. I can't see how it could hurt anything, but just don't know that, if nothing changes, it means its a mechanical part broke. Of course, if you pull the fuse or relay and it does power off the electronic steering systems, and it does change the way it steers you know it did something. I was just trying to have a controlled experiment, lol, since I'm not there and you're a newbie.
    The fuses are under the under the dash. They're part of the "EMPS" circuit. Here's pics of the fuse box location and the location of the EMPS fuse and relay. Pull both, I guess, and see what it does. Note: the fuse diagram is turned 90d from its orientation under the hood.
  14. ChapmanF
    19,041
    One thing that used to go wrong with those racks was the pinion nut coming loose (there was a recall). The symptom would be really hard turning the wheel in one direction especially (left, if I remember right).
  15. ronlewis
    1,061
    206
    texas
    2001 Prius
    She said that she'd taken it in for the recall. IDK the steering system, but just thought it was worth cutting the power to see what that changes. I've read of others pulling the harness under the glove box and keep driving the car. Would pulling those fuses do the same thing? Ginny is not confident of pulling the harness connector.
  16. Trombone
    Trombone Active Member
    389
    130
    Allentown, Pennsylvania
    2002 Prius
    That recall was many years ago, IIRC within the first 2-3 years of the Classic's history. I wonder whether a dealer would, or could, perform the recall service at this late date!? I had it done to my '02 at the time, and have never had any steering problems, knock wood.
  17. ronlewis
    1,061
    206
    texas
    2001 Prius
    Yeah, she took it to a dealer and they wouldn't help her. Dang, she's been waiting for the answer about the fuses. Sounds like no one knows. Ginny, I say just pull them and see what happens. It can't hurt anything.
  18. GinnyV
    GinnyV New Member
    2001 Prius
    Hi everyone, regarding the recall. That work was done in 2011 by the dealership here. But the symptom I’m still having is very similar to that although not limited to one direction of turn. I’m wondering if that damn bolt has gotten loose again. Toyota just wants me to replace the whole thing to the tune of $3000. I’ve been driving the car for the last week again. For the most part I’ve not gotten into any trouble. I have to avoid parallel parking or parking in between parked cars and give myself ample space when making a tight turn but beyond that at speeds over 15 or so miles an hour the car turns and performs normally. This problem is only at low speeds. And it seems to be improving the more I drive it? Not really but it’s not getting worse yet. I took it to a shop where they test drove it yesterday and they guy just scratched his head and said he hadn’t had this before and he thought I should take it to the dealership…well NO. I’m not giving up yet.
    I did get a new 12 volt battery and I want to see whether the battery is slowly degrading..or whether the battery is fine and that a bad battery might have made the problem steering worse (back in May when I stopped driving). I’m not going on long road trips yet…but I’m going to have a mechanic come to my house hopefully and try the things that Ron Lew is said to try. Has anybody just replaced the electrical motor on the shaft? Could that be the problem. Why does it only act up at low speeds and tight turns????
  19. GinnyV
    GinnyV New Member
    2001 Prius
    Did the recall fail? How can I get toyota to look at that? I already brought it in and I’m sure they did zip. They told me what I told them when I dropped off the car.
  20. GinnyV
    GinnyV New Member
    2001 Prius
    Thanks Ron. I was hoping the shop I went to would do that but they weren’t that interested in just said go back to the dealership. Not going to do that. Now I’m waiting for this mobile mechanic my daughter connected me to to come by and do some more trouble shooting so whatever info I get here I will relay to him. In the meantime I am having an almost normal life though I haven’t taken off on any road trips yet…and he’s going to work on my 78 westphalia too! So halleluliah!
    ronlewis likes this.
