I need Prius driving lessons
Discussion in 'Gen 3 Prius Main Forum' started by dbacksfan, Jun 4, 2009.
  1. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    dont worry about it. check out the specs more to know what you got than to adjust. pump a bit of air in the tires if you want... i would start at 42/40... this should help you get a few extra miles on the life of the tires and boost your mileage.
    check the oil to make sure its not overfilled although i think that Toyota probably put the word out to the mechanics to double check that... lot of words on that subject here.
    and most of all, its probably your driving. 70 mph with A/C can do it especially if you have to hit the brakes AT ALL. if in heavy traffic, you are probably gonna see a big improvement in mileage if you drop it down to 65 and increase your following distance.
  2. fuzzy1
    10,706
    One-way trips, even 50 miles, don't count when there is a noticeable elevation change, even after you become practiced. There are a number of downhill stretches where even my Subaru FSP can get 40+, even up to 48 mpg, over that distance. Your Prius mpg will be very disappointing on the uphill legs of those stretches, but you should be much happier with the round trips.
    In case you haven't read similar material, I'd recommend a couple articles on CleanMPG: Beating the EPA for the basics, later followed by ...Warp Stealth in the Prius II for more advanced Prius-specific material. Save the P part of P&G for last.
  3. Steve Cebu
    Steve Cebu New Member
    523
    59
    Concord, NH
    I averaged about 48mpg today but there were a lot of hills to go up and down. This is also the first 50-70 miles or so. Plus I tried out every mode and used POWER mode as well as coasting, tried out the cruise control, the works. I should have gotten less. The first tank doesn't count. You don't know how much gas the dealer put in or if it's really full etc...
    Power mode works very well in traffic at the lights. If no cars I'd probably use Eco mode, but a lot of traffic today.
  4. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    I assume the Prius is no different than the Camry Hybrid, but my understanding is that when you put the selector in neutral you are not charging the battery. That defeats the advantages of the hybrid system.
  5. Steve Cebu
    523
    59
    Concord, NH
    Well on my car it doesn't seem to charge the battery very much if you are coasting even with the car in D, but it sure slows it down fairly quickly for a Prius.
  6. Lottamoxie
    Lottamoxie Member
    435
    64
    Southeast US
    Mang, so much work when you have a car that will give you good gas mileage just using it without thinking about it. I think it's easy to get obsessed with MPG but think about the averages over the lifetime, how much less pollution you are spewing out, and just use the car as a car and drive. That's my plan. When I get my Prius I'm not going to obsess over the mpg. I drive like a reasonable person and I assume Toyota built this car for folks who drive reasonably. Yes?
  7. Blauer Glimmer
    Blauer Glimmer Active Member
    448
    169
    NY (Southern Tier)
    Yes, they did, but it is amazing how one can become hooked on the mpg thing. It's all that instant feedback in your face. It has changed my driving style for the better, and I am more aware of how my former habits wasted fuel.
  8. Lottamoxie
    Lottamoxie Member
    435
    64
    Southeast US
    I figure just going from my current 19/20 mpg now ('98 Saab 900) to a car that on a 'bad' day will get about 40mpg is a huge win. And anything above that is appreciated (gravy). Hence my experience when I do purchase a Prius will automatically be a good one since I'll already be way ahead of where I am now (mpg-wise). That said, my current car has 6 way power seats and the car is going on 12 yrs old! C'mon Toyota.
  9. Argyle
    Argyle New Member
    87
    22
    Rochester, NY
    I drive a 2001 Prizm with a manual 5 speed transmission. Essentially a Corolla. The radiator says 'Toyota' on it. Tanked up yesterday and got 34.9 MPG. So when my Prius arrives, I will have to work towards 70 MPG to save as much as you will. :eek:
  10. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    The best part of a lot of this advice guys is that once you practice it for a while, you don't even think about it. I've been driving a Prius of one form or another for over 7 years. Braking early and anticipating stops comes natural. In fact, I get quite nervous when I'm with others who are on the gas within 150-200' of a stop sign. :lol:
  11. dbacksfan
    dbacksfan Member
    258
    22
    Scottsdale, Arizona
    2014 Prius v wagon
    Okay, first of all, I hope that those who are considering a Prius would NOT take my low mpg as indicative of the type of mileage that they are likely to achieve. In other words, I was poking fun at myself -- making light of my dismal results.
    Here are a few more details. There were 10 miles on it before I took my test drive. I suspect the previous driver(s) pushed the car during their test drives. Even though I consiously practice gas-saving driving techniques such as anticipation of stoplights and looking far ahead, I have a long way to go in terms of getting close to the best out of my Prius.
    Regarding the upgrade, from the south part of the valley to my destination at the north end, there is approximately a 1500 foot elevation change. The speed limit varies between 55 and 65. Conditions permitting, as I did on this day, I limited my speed to +5 in order to stay CLOSE to the flow of traffic. By the way, if you ever visit Arizona, be aware that it is one of the most rigidly enforced traffic states in the union. Traffic cameras and speed traps are quite common. On community wanted to install cameras in fake cacti. :rolleyes: Despite this situation, people still routinely go +15 over the limit on our freeways.
    I'll report back after I have a chance to learn the operation and drive in a number of different situations.
    Most of all, thanks to all of you for taking the time to contribute to this thread!
  12. Husker4theSpurs
    Husker4theSpurs Active Member
    656
    128
    Papillion, Nebraska
    The elevation change is what did that to your fuel economy then. On another note, I find one gets really good gas mileage overall when driving in the mountains ... as long as you're coming out of them on the other side. Tough on MPG on the way up, but getting infinity MPG for the ride down makes up for it and then some.
  13. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    MPG for 10 miles level and steady will be higher than 5 miles up and 5 miles down, other things being equal. You cannot lift against gravity for free. But the 5 miles down sure helps more than just letting a non-hybrid idle.
  14. bruceha_2000
    bruceha_2000 Senior Member
    3,057
    302
    Northwest VT
    2018 Prius Prime
    Or my wife who likes to sit on it in a 30 MPH zone until she is about 50' from a stop. And she wonders why her mileage is worse than mine. :)
    Every little thing counts - tire pressure, acceleration, not slowing any more than necessary, never stopping if possible, using CC on the Interstate, combining short trips so you don't do 5 trips on a cold engine. Do you REALLY need that cup of whatever necessitating a 2 mile drive to the grocery store NOW?
    To the OP, if your 8 miles were all short trips and on a cold engine, you could have dropped the MPG from the Interstate driving substantially. It takes a lot of 70 MPG miles to recover the 35 MPG miles back to an average of 50 or 55. The 'city' miles can be quite low (OK, not low compared to other cars) if there are a lot of stops or you jump on the Interstate for a mile.
  15. Indyking
    Indyking Happy Hyundai owner...
    1,280
    I don't know... Indy, Chicago, Madison (WI)... it
    Your frustration with the initial MPG likely proves what I have been suspecting... the Prius will take a big hit in the MPG when challenged, more so compared to nonhybrids in terms of percentage.
    Most people get impressive MPG with hybrids because they are adapting their driving style to maximize MPG. So if this is your first hybrid and you drive it just like you were driving your previous nonhybrid, the difference in fuel economy between the 2 will be disappointing most of the time.
  16. bruceha_2000
    3,057
    302
    Northwest VT
    2018 Prius Prime
    Um, didn't you just contradict your self? If it really IS rigidly enforced, no one would be going even +5 let alone +15. Clearly the chance of getting caught or the financial pain if you do get caught are not high enough to convince people the MAXIMUM speed limit on the sign is the MPH you aren't supposed to exceed.
  17. bruceha_2000
    3,057
    302
    Northwest VT
    2018 Prius Prime
    Ah, no Prius YET. You will drink the Kool-aid my friend. Just you see if once you are routinely getting 50, 55 MPG on a tank you still think 40 MPG is OK. You will be crying when you see 40 MPG! :)
  18. Lottamoxie
    Lottamoxie Member
    435
    64
    Southeast US
    You missed my point. A doubling of my gas mileage at the very *worst* is still good (than what I can get today in my current car). I expect to get better than that, on average, over the life of the car, without having to become an expert in hypermiling, P&G, etc.
    Now, might I *want* to learn how to do those things? Yes, perhaps I will when the time comes. But I'm not going to drive myself crazy (pun intended) over it either. Frankly I don't want to spend every ride in my car analyzing the mpg. Sure it's nice for those who feel inclined to do just that, but I'm expecting to get decent (perhaps even great) mpg without having to obsess over it or go to special Prius P&G school.
  19. Jay C
    Jay C Member
    72
    36
    TN
    Oh yeah you will :D It's like a mobile video game and it's just as addictive as your old Atari favorites too ;)
  20. bruceha_2000
    3,057
    302
    Northwest VT
    2018 Prius Prime
    No I didn't :) The '95 Odyssey that my '04 Prius replaced got mileage similar to your Saab. In 91K miles, I have saved over $6K in gas alone. I don't P&G but I do make use of Glide and EV and *I* didn't intend to get all caught up in 'how low (or is it high?) can you go either.
    We'll see. I agree, some spend more effort than others. I have NO idea how people can average 60+ MPG in a Gen II, I can't get close to that. But I feel pain when winter comes and the 'always over 50 MPG' tanks become rare and it is more like 'can I hold 45?'.
    And congratulations on cutting your future fuel use in half! We all benefit.
