I need to be prepared to be screwed by the dealer?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by marblekit, Oct 6, 2011.
  1. bisco
    51,747
    they are more difficult than 100 level.;)
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    38
    Santa Fe, NM
    This is what a slow leak in the water pump looks like. I had to add coolant just once the past 10,000 miles, and there was still plenty left in the overflow.
    3 people like this.
  3. The Critic
    The Critic Resident Critic
    3,193
    2,330
    CA
    Yelp reviews should be taken with a grain of salt because people who usually go on there to write about dealerships are the ones who were very dissatisfied. Therefore, it is not a good indicator of the overall customer satisfaction.
  4. EffinRed
    EffinRed Junior Member
    32
    Boston, MA
    This is true for the most part and I have had a few experiences where the reviews and the service I received were not in line (in both directions).
    I found a great local dealer asking here and at work.
  5. marblekit
    marblekit Junior Member
    Orange County CA
    I checked my water pump and there is a very small amount of that pink crud on the outside. It doesn't appear to be very much and my overflow tank is full. I assume this is nothing to be too concerned about?
  6. The Critic
    3,193
    2,330
    CA
    That is enough of a leak for the dealer to try and upsell a water pump replacement. And yes, I would replace the pump.
  7. seilerts
    3,326
    1,518
    38
    Santa Fe, NM
    Once it starts leaking past the seal, there is a risk of bearing failure. It is always better to replace it as soon as possible. But you have time to call around and find a good deal, or research the procedure here and do it yourself. On mine, I tolerated it far longer that I should have, just to see if it would eventually suffer a catastrophic failure
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Its dicey to watch a water pump for failure that you know is weeping because our car does not have a temp gauge so unless you have a scangauge like alot of us you will never know if it has sprung a leak and the engine is overheating.
    You do not know the engine temp and won't know you have a problem till it throws a check engine light and that is why past when you need to know.
    I would replace a pump that is weeping. Its trying to get your attention.
  9. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    If it were me, I'd buy a pump now from the cheapest internet source I could find. Then I'd put the pump in the trunk and wait for something more exciting. Until the system starts losing enough fluid that you have to top it off, I say let it weep.
