I need to plug the OEM camera back into the OEM stereo
Discussion in 'Gen 3 Prius Audio and Electronics' started by gattaiolo, Oct 1, 2018.
  1. gattaiolo
    gattaiolo Junior Member
    22
    Belgium
    Hi folks, following the total failure of the 4.4 Android stereo bought from Auto Pumpkin 3 years ago, I have put the original nav/stereo system back in place.
    Everything works fine, except the rear camera, because in order to connect it to the Android stereo, I had to unplug its 3 wires from behind the glovebox.
    One black, one red and one white.
    Can anybody tell me where to re-plug those 3 wires? Can't find any scheme on Google!
    See picture.
  2. gattaiolo
    22
    Belgium
    Hello, is anybody willing to help me ? I would really need to gey this work done. Either with a wiring scheme or simply a picture showing the same wires (located behind the glove box, which is really easy to unmount). Thanks!
  3. RRxing
    RRxing Senior Member
    2,563
    1,842
    NEPA
    See Page 4...
    gattaiolo and frodoz737 like this.
  4. gattaiolo
    22
    Belgium
    Great thanks!
    Which row of numbers should I take into consideration? There are four rows, from top to bottom, with different numbers
  5. RRxing
    2,563
    1,842
    NEPA
    All of the referenced connectors are shown at the end of the file with their associated numbers.
  6. gattaiolo
    22
    Belgium
    thank you for your help.
    Unfortunately, I tried to follow what is indicated in the file you posted, but it still does not work.
    May I ask you a big favour? Could indicate the good slots on the picture I posted at the beginning of this thread?
    You would save me!
    Thanks!
  7. RRxing
    2,563
    1,842
    NEPA
    Unfortunately, I don't see any connectors in your photo matching the ones in the electrical diagram. Are you sure you posted a photo of the Nav/Stereo system connectors?
  8. RRxing
    2,563
    1,842
    NEPA
    Any updates???
