I notice they got rid of the white console tray on 2017 Prius!
Discussion in 'Gen 4 Prius Main Forum' started by Jim in NC, Nov 18, 2016.
  1. Tideland Prius
    16,557
    Well it was the last year of that generation. I thought it was fine when it came out in 2003 but yeah by the end of the decade, fake wood trim really was on its way out for the non-luxury cars. (Yeah I know the Camry XLE and Accord EX-L models still used them).
    But at that time, Toyota's aluminium trim wasn't particularly convincing. The Echo/Yaris had it as a dealer-installed accessory and while it did have some pattern to give it a liquid look, it clearly looked plastic. The silver trim pieces on the Gen 10 Corolla's centre stack were ok. The Gen 2 Prius had satin silver trim so it looked a bit darker. That was changed to bright silver plastic for Gen 2.5. I prefer the more subtle satin silver than the bright silver. The "metallic-tech" trim on the Gen 2 TCH was cool too. It matched the Ash interior.
    RCO likes this.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    I checked that - it's definitely OFF. Somehow the file system for MP3s has it's own sort order. I understand that you can edit MP3 files to sort it out, but that would be for every time I saved files to a USB stick.
    I'll stick to RW-CD for things which should be in a set order until I can afford a new phone which might be able to do it differently.
    RCO likes this.
  3. MichelleStone
    MichelleStone Senior Member
    549
    818
    Mariposa, CA
    Yeah.... I too tried a memory stick and the functionality seemed too limited for me. I ended up purchasing an iPod touch and put all my music and other audio files on it. I like to listen to podcasts and audio books as well so the iPod interface works nicely. I do have an Android phone and the functionality through the bluetooth interface isn't up to par with the iPod USB connection.
    RCO and alanclarkeau like this.
  4. alanclarkeau
    7,045
    7,592
    I've got a couple of MP3 Players I use when walking or working around the house - resisted the iPod so far - maybe I need to go have a look at one. Will a simple iPod Shuffle work on it the same?
  5. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I'd have thought so. Basically the same apple tech. :)
    #65 RCO, Nov 29, 2016
    alanclarkeau likes this.
  6. Tideland Prius
    16,557
    As far as I know, they have to use the AUX jack (which has fewer functions). You could try plugging it into the USB port and see if the system recognises it as a USB device.
    Prodigyplace and alanclarkeau like this.
  7. grape808
    grape808 Active Member
    150
    153
    Hawaii
    Not sure about the Shuffle. The Nano software links up and you will have your playlists. The Sansa clip won't even read as a flash drive and will only work as an aux source, in my experience.
