I officially hate my prius and toyota
Discussion in 'Gen 2 Prius Main Forum' started by BROOK SIDE, Feb 5, 2011.
Thread Status:
Not open for further replies.
  1. BROOK SIDE
    BROOK SIDE New Member
    81
    canada
    Really? You've missed the part I've repeated over and over that the car has s brand new optima battery that is in spec for the vehicle ? Trying to insult me and baiting me is really uncalled for
  2. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    ... and still, refuses to actually run the test on the battery. *sigh*
    it's like a train wreck.
  3. Bob64
    1,540
    93
    Virginia
    I've had bought BRAND NEW batteries with DEFECTIVE cells before that appear to be within spec - until you do a load test to get rid of the surface charge.
  4. BROOK SIDE
    81
    canada
    Ive run the tests - I've told all of you the battery is fine. You are all in denial. I am on vacation. Unless you are a real Toyota technician with real advice please save yourself the time and don't respond
  5. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    SO, putting your toe under the gas pedal ( could ) stop the engine. :cheer2:
  6. Rae Vynn
    6,038
    707
    Tumwater, WA USA
    Oh, you have? What numbers did you get?
  7. BROOK SIDE
    81
    canada
    Apparently higher than your iq if you can't figure it out by now lol!
    Im off to the playa - adios!
  8. bisco
    51,904
    playa del carmen?
  9. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    Will somebody close this thread already?
  10. Bob64
    1,540
    93
    Virginia
    Obviously the OP has got readings of 0 volts.
  11. mike lipke
    mike lipke New Member
    89
    MN
    "You can lead a horse to water, but you can't make him float" -Yogi Berra
  12. mikesus
    mikesus New Member
    Greensboro
    Actually what make sense is that he has a stuck brake pad.
    Note that when he puts it into B the engine shuts off (In BRAKE mode that makes sense)
    With a a dragging pad or possibly E Brake, it would cause enough drag to keep the load high enough to keep the ICE going.
    Jack up the car and see if the brakes are binding...
  13. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    Please don't close it. I want to find out what the problem is when/if it finally does get resolved. Personally I think it's something to do with the leak, as was speculated early on in the thread.
  14. SW03ES
    2,480
    176
    Gaithersburg, MD
    He's never going to discover his problem...he doesn't really want to, and he's such an a-hole to everybody nobody's going to take him seriously or try to help him.
  15. a_gray_prius
    2,927
    783
    IL
    I am also interested in seeing a resolution.
    Also, OP: did you happen to change the tires around the time you had the issue (if so, to what)?
  16. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    Removed, too aggressive
  17. sub3marathonman
    sub3marathonman Active Member
    557
    75
    Removed, not aggressive enough.
  18. evpv
    evpv Active Member
    691
    338
    West Coast
    2019 Prius Prime
    Removed, Unintended Aggression
  19. evpv
    evpv Active Member
    691
    338
    West Coast
    2019 Prius Prime
  20. patsparks
    10,664
    567
    Adelaide South Australia
    Thank you, your opinion has been noted. I have been here long enough to see people called trolls who aren't. Don't ignore the OP, just ignore the thread if you don't like it.
    I hope the OP can resolve the problem but I do take offence at his abuse of my friends. Rene' is a very smart lady and didn't deserve the spray. I really do not understand what is so hard about posting a number between 10 and 15 to 1 decimal place but it could be tough for some. Maybe it's a religious thing, religion is to blame for most of life's woes.
    3 people like this.
Thread Status:
