I own a 2013 prius.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tonya 05 Owner, Nov 8, 2019.
  1. bisco
    52,804
    zakily
  2. Mendel Leisk
    42,298
    Guess I'm completely lacking in mechanical skills, cus it always takes me a solid 2 hours, start to finish.
    I'd second watching the @NutzAboutBolts , what is it, about 30 minutes? :oops:
    #22 Mendel Leisk, Nov 9, 2019
  3. ASRDogman
    ASRDogman Senior Member
    8,052
    4,083
    Well, you are not in a hurry. So it doesn't matter how long it takes.
    If I was getting flat rate to do the job, I could do it in 20 minutes.
    But since I'm not, it would take about 45 minutes, maybe an hour.
    Depends on chance of rain, heat, my mood.. :)
    Tonya 05 Owner and Mendel Leisk like this.
    52,804
    he probably did his first one after quoting you, and discovered his mistake
  5. Mendel Leisk
    42,298
    I can spend 10 minutes trying to get the little black trim piece at the lower corner of windshield to fit properly. Another 10 minutes for some of the conduit clips, getting them to release without busting them.
    And admittedly, I might get out an old paint brush an' start dustin' a bit. :whistle:
    What ticks me is that Toyota's brightest bulbs couldn't manage to get just an inch or so more clearance, between the cowl and top of engine, enough that all of this cowl removal BS was not necessary.
    I wonder if 4th gen manages it? Anyone know?
    #25 Mendel Leisk, Nov 9, 2019
    Tonya 05 Owner and mikey_t like this.
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    There's another assumption I make in threads "like" these.- And sometimes I'm wrong.
    But I kind of assume if an OP is asking whether a mechanic or service department is ripping them off? Or about the specifics of a certain diagnosis? That translates to me that the person is NOT a big DIY'er or home mechanic. My assumption is that if they were? They wouldn't be asking the question, because they'ed already know the answer.
    This sometimes is a false assumption.
    But it is why, in a thread like this, with a Original Post like this one, I don't start by recommending a DIY approach. Until it's determined FROM the OP, how much they may or may not want to go in that direction.
  7. The Electric Me
    9,083
    5,801
    AMEN.
    That's what I took from watching the video.
    Really subversive design to require that much work and removal just to reach sparks plugs that are literally right on top of the engine. It is what it is, but you'd think Toyota could of made it much easier.
    Cynic's will conclude it's just part of a plan to drive more people to dealership service departments.
    Tonya 05 Owner likes this.
  8. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,788
    Bay Area
    Mines at 203k miles as of right now.
    trans fluid was a dirty red color, hasn’t been changed for about 170k miles? lol and it was a second change.
  9. bisco
    52,804
    otoh, once every 120k saves a ton of money
  10. ASRDogman
    8,052
    4,083
    NO company wants you to take there product to anyone else for service.
    They are in the business of making money. They don't make money if you take it somewhere else.
    Of course, usually it costs more.
    EVERY engineer should have to actually WORK on everything they design. Then MAYBE, they would
    do a better job. They could have just as easily put the plug on the front half of the engine.
  11. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Good points. Early this year the wife took her Gen 4 in to get her free oil change while I was at work. Her car has 22k miles and I want to prevent oil burning so we do 5k oil changes. I came home to find the "new" oil was almost Black with a potent fuel smell. Also the tire pressure light was still on and tires werent rotated. I called the manager and told him they were fixing it before they closed. We watched them do the work this time and saw a large piece of charcoal fall out of the car as they swapped out the oil filter. There were other incidents at this dealership and that was the last straw. They received a few long reviews on the internet...
    I'm resolved to doing oil changes to our Prii at home. Won't step foot in that dealership again.
    Pixel XL ?
    #31 mjoo, Nov 9, 2019
    RMB, Tonya 05 Owner, mikey_t and 2 others like this.
  12. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    That didn’t deter you away from them in first place? o_O
  13. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    They were from me. Now that Toyotacare is used up we have no excuse to go back.
    Pixel XL ?
    #33 mjoo, Nov 9, 2019
  14. Mendel Leisk
    42,298
    No "free" service up here. If I was in the States I still wouldn't use it, not worth the aggravation. If I'd done the first few years of service through dealership, I think our engine underpanel would be knackered, the door hinges would be great greasy blobs, and the rims would be chewed up.
    #34 Mendel Leisk, Nov 9, 2019
    Tande and Tonya 05 Owner like this.
  15. The Electric Me
    9,083
    5,801
    Thanks.
    I would like to take some credit for just intrinsic cleverness but the truth is I've been watching a lot of "The Great British Baking Show" on Netflix.
    Which leaves me realizing that unless they ever have a Microwave Burrito week, or Boxed Macaroni and Cheese technical challenge, I'm never going to be standing in that tent as a baker.
  16. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    Charcoal??? Why??
  17. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    This is the way they dirty up your clean filter instantly in their hands when youre not watching, 'stealership' :cool:
  18. Tonya 05 Owner
    Tonya 05 Owner Junior Member
    Tenn.
    Thank you for the vote of confidence. I'll let you all know how it gies!
  19. Tonya 05 Owner
    Tenn.
    goes! Yeah this is second time. I took it to another mechanic shop and had the guy ride with me and he could feel the stuttering in the ride I actually have a video showing the car rattling when the hood is up and I'll post it.
    Yeah I get regular oil and fluids replaced . See what you think about the video I took. It's the knocking and stuttering
  20. Tonya 05 Owner
    Tenn.
    Well I cant get the video to load because its too big and I cant trim it anymore or it wont show what I'm talking about.
