I own a 2013 prius.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tonya 05 Owner, Nov 8, 2019.
  1. Tonya 05 Owner
    Tonya 05 Owner Junior Member
    Tenn.
    I'm a novice but my husband isn't. Good catch on me not being a car DIY lol
  2. Tonya 05 Owner
    Tenn.
    goes! Yeah this is second time. I took it to another mechanic shop and had the guy ride with me and he could feel the stuttering in the ride I actually have a video showing the car rattling when the hood is up and I'll post it.
    Yeah I get regular oil and fluids replaced . See what you think about the video I took. It's the knocking and stuttering
  3. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    So this is some old scammer mechanic trick?
  4. Tonya 05 Owner
    Tenn.
    I think I've got a plug that's not gapped correctly. The new mechanic said it could be the plugs ,coils, or the plug gaps,or bad plugs
  5. Mendel Leisk
    42,228
    If professional mechanics have the cowl off, take photos before if possible, and inspect everything before leaving. One time when the dealership did ours (for brake booster recall IIRC), they managed to put the wipers face down on rough concrete, then stack everything else on top of them, scraped the black paint. Not bad, I just touched it up, but yeah.
    I did call them on it when I noticed, they apologized, the mechanic actually recounted how it had happened. They offered to repair, but by then I'd touch-up painted them, and it was minor.
    Also, the knurled bolts that the wipers push onto: they start to look a little chewed up after the umpteenth removal/install.
  6. Mendel Leisk
    42,228
    Apologies if this is obvious, anyway: You're trying to upload it to Youtube? That's the way to do it. Then post a link here.
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Oh...regretfully true today.
    But I still remember cars built in the 50's, 60's, 70's and into the 80's even. And oil filters were accessible, spark plugs ripe fruit and engines seemed designed to be worked on.
    Pop the hood on an engine today and you are met a facade of plastic. Tolerances and clearances seemed designed to discourage maintenance. Everything screams....find another hobby because this isn't user friendly.
    You have to go back a ways, but it wasn't always so.
    It use to be youth, enjoyed working on their engines, it was a common thing to see.
    Now? If they are parked in the driveway working on their vehicle, the best bet is they are installing a sound system, lowering the suspension, or bolting on some purely cosmetic aftermarket parts.
    Non-familiarity with anything automotive that requires a tool is a huge reason more and more automakers don't even bother providing spare tires.
    Maybe it balances out...cars are more reliable, require less maintenance, but the flip side is, we lose our familiarity.
    Mendel Leisk and ASRDogman like this.
  8. ASRDogman
    ASRDogman Senior Member
    8,014
    4,071
    I like working on the easy stuff!
    But the Prius isn't THAT bad. But everyone is making things smaller and tighter....
    SOMEONE has to suffer!
    The wiper cowl was super easy. The egr cooler and system was super easy.
    The intake manifold was super easy.... At least for me.
    I am hoping to NOT have to do the head gasket on MY Prius. I'd like to help someone else,
    just as long as it's not mine! :)
    So far NO coolant loss. It's exactly where I filled it last year....
    #48 ASRDogman, Nov 12, 2019
  9. Tonya 05 Owner
    Tenn.
    THANK YOU !!! I had no idea youtube had to be involved lol.
    ASRDogman and Mendel Leisk like this.
  10. Tonya 05 Owner
    Tenn.
    Thanks to one persons help I learned my video has to be on youtube first and then send it here and post. Ok so here is what I took the day I had a second mechanic look at my vehicle
  11. bisco
    52,746
    i thought this thread was about the expense of plug replacement (n)
    idk though, that is a very intermittent and unusual stutter
    #51 bisco, Nov 13, 2019
    Grit likes this.
  12. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    How many miles on the 2013 again?
    If you have no dashboards lights illuminated, then we could assume that the misfire count is fairly low.
    The shuddering and knocking could be entirely something else.
    Are either of the mechanics hybrid compatible?
    (didn't watch the video)
    #52 SFO, Nov 13, 2019
    Grit likes this.
  13. Tonya 05 Owner
    Tenn.
    It's about the issues I'm having with my 2013 model. I make sure all upkeep is done since this is my only vehicle and I drive my son to and from school in it. I'm trying to figure out what's causing the shaking stuttering and the lag when I press the gas
  14. bisco
    52,746
    ah, okay. i must have misread your o/p
    there are certainly a lot of things it could be. or it just might be plum worn out. tough to say without lights.
    might be worth putting tech stream on it just to be sure.
    is this the 120k plug change?
  15. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,784
    Bay Area
    Have you tried cleaning the throttle body? Could be a sticky plate. Does the shake only happens when you step on the gas or also during idle when the ice is running?
    What maintenance has been done to it?
  16. bisco
    52,746
    <sigh>
    mikey_t and SFO like this.
