I put a 27" monitor in passenger side, and other radical mods!
Discussion in 'Gen 4 Prius Accessories and Modifications' started by The Big Sleaze, Feb 7, 2022.
  1. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    You could be right - unless they don't have them installed for the test?
  2. MalachyNG
    MalachyNG Active Member
    304
    225
    Northern NY
    2022 Prius Prime
    Airbag may not go off but in an accident that pvc and whatever is holding it together will likely snap and your TV is going to be a big heavy object shattering apart ricocheting around shedding glass, plastic, and metal chunks all over the passenger compartment right at head and chest level. You are not going to have a good time.
    For some CAD work is a TV that useful? Why not a larger laptop with a higher resolution screen and higher refresh rate? I've used 1080p TV's as a 2nd monitor for my PC at home and it's bigger but a tv is not a great monitor other than watching video. A laptop you can pull out and put away and it'll fit on a laptop tray
    #22 MalachyNG, Feb 9, 2022
    alanclarkeau likes this.
