I put the wrong oil filter but it works!
Discussion in 'Gen 2 Prius Main Forum' started by mlibanio, Jul 24, 2009.
  1. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Um .... that isn't what I meant. For reference, the excellent documentary/educational film "Deliverance" may be viewed. Although filmed in Georgia, close enough for discussion purposes
    Yes, I'm referring to obvious inbreeding, human isolates, various birth defects, etc. I trust you've never had to "squeal like a pig?"
    Move at once. Today if possible!
    Yes, most vehicles with spin-on oil filters can take a wide variety of oil filters. Not sure what advantage there is to using a different filter, perhaps cost savings or perceived better filtering
    Of course, with the 2010 Prius and Corolla, you need a cartridge filter. This appears to be Toyota-only, at the moment
  2. nthach
    nthach New Member
    174
    I use the taller Scion/Corolla filter with no issues.
  3. danl
    danl New Member
    231
    Boston, MA
    Just to add about Fram filters. I've been using fram on my '92 camry since I took delivery of it 17 years ago. 17 years later, the car still runs fantastic.
  4. sorka
    sorka Active Member
    1,034
    199
    Merced, CA
    2019 Prius
    In most states, you cannot pass smog with the engine check light on so I'd say your friend was limited at most to 2 years of this.
  5. sorka
    sorka Active Member
    1,034
    199
    Merced, CA
    2019 Prius
    I bought a box of ten of the taller filters from a mail order Toyota dealer. Shipped was a little over $30, so about $3 / filter.
    I don't use Fram anymore. I had used one on my SC400 in a pinch a few years ago. The rubber check valve wasn't sealing which resulted in the engine oil draining back into the oil pan slowly over a day or so. If left unstarted for more than a day, the valve train made a horrible clattering sound. Finally figured out it was the filter. Replaced it wih a Toyota filter. Problem hasn't been back.
