I ran in ev mode going 53mph
Discussion in 'Gen 2 Prius Main Forum' started by windstrings, Feb 11, 2006.
  1. windstrings
    windstrings Certified Prius Breeder
    6,278
    373
    Central Texas
    I experienced a first for me... after going down a big hill, the battery was full green all the way to the top..... and I was now in the flat lands and I found I could run on ev only going 53 mph...
    Apparently when the battery is that charged, it will let you run ev mode without the ICE running at all until the battery gets in the blue.. then it goes back to normal and won't let you do it unless your under 42mph.
    anyone else notice this?.. if this just a new 06 thing or has it always been?
    Note, none of this done by activating an ev mod switch...just the normal factory behavior.
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    I've been able to cruise around in the 45 to 50 in normal traffic after doing a good breaking session... if you're in blue, you can get green when stopping from about 50mph. if you don't get caught off guard, you can keep your battery in the green and achieve about 75 mpg for the trip. :) it's fun.. but i have a lead foot.. hehe. doesn't always happen
  3. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    Economy is awesome at highway speeds when the battery is in the green. I was getting 3.5L/100km (67MPG) for about 40 km on the freeway with an average speed of 105km/h (65mph) . There were hills, but it was still doing great on the hills.
  4. Tideland Prius
    16,081
    Yeah I had 8 bars one cold evening after class and managed to do the 4km highway out of the university in EV mode at 80km/h
  5. ken1784
    ken1784 SuperMID designer
    2,940
    1,359
    67
    Yokohama, JAPAN
    How did you know that you're on EV only mode?
    If you say seeing the MFD screen, the MFD lies.
    Ken@Japan
  6. The Tramp
    The Tramp Italian Prius Expert
    350
    31
    Turin, Italy
    2020 Prius PHV
    Can you be more precise? :)
    I too noticed that I was in EV mode way above the famous 42 mph (70 km/h due to European cumpulsory margin) [108 km/h down the St. Gottard] that is, just yellow arrows, 0.0 l*100 Km (metric is better than MPG in this case).
    But the engine was turning, slowly (900 rpm) but turning along.
  7. ken1784
    2,940
    1,359
    67
    Yokohama, JAPAN
    If you say it's EV mode but ICE is spinning, I'm fine.
    However, I don't want to say it an EV mode.
    We need some energey to spin the engine.
    Ken@Japan
  8. windstrings
    6,278
    373
    Central Texas
    It maybe was lying.. but it showed the ICE as not being on.. but maybe it was free spinning... but still I normally can't do that at those speeds.
  9. windstrings
    6,278
    373
    Central Texas
    You must have a canview or something.. I cannot see rpm
  10. ken1784
    2,940
    1,359
    67
    Yokohama, JAPAN
    The MFD shows the ICE running when the ICE supplys power.
    Sometimes, we can't see the ICE spinning when the ICE is on warming up and the vehicle is above 42mph, the MFD lies.
    There is no such FREE spinning. We need a certain energy to spin the ICE.
    Ken@Japan
  11. jamarimutt
    jamarimutt New Member
    985
    The original post suggested that it's possible to cruise along at speeds over 42 mph with the screen showing no ICE activity and 99 mpgs. I do this every day, at speeds over 60 mph, after descending a long, steep hill.
  12. windstrings
    6,278
    373
    Central Texas
    Right.... 99mpg is all that matters.. the question to Ken is,
    If its lying, is it lying about the engine freespinning, or is the 99.9mpg a lie too?
    If its just the freespinning... its no big deal.
  13. ken1784
    2,940
    1,359
    67
    Yokohama, JAPAN
    The 99.9(more than 99.9 or infinity) mpg is correct.
    Sometimes, it is about 75 km/L(about 175MPG) or no fuel consuming.
    What I would like to say is we need to consume some battery power to spin the ICE when the vehicle is coasting above 42mph even if no fuel injection.
    Ken@Japan
  14. habel
    habel New Member
    230
    Oslo, Norway
    How can you tell the RPMs of the engine?
  15. daniel
    14,487
    1,518
    Spokane, WA
    Windstrings: What you saw is what some folks call "superstealth" mode. Personally I dislike the term. Above 42 mph the ICE must spin, due to the geometry of the PSD and the rpm limitations of MG1. And it does require some (very) small amount of energy (probably gasoline, I think) to turn it because the engine cannot spin freely. But in this mode the gas burned is negligible and the car is essentially running in electric, as you (correctly) presumed. It does not happen often, but it has been seen and documented. You saw it longer than normal due to the high SOC, but I've seen it for a brief moment now and then on the highway.
  16. daniel
    14,487
    1,518
    Spokane, WA
    Some folks have an aftermarket device that plugs into the CAN bus and provides information about a bunch of stuff we don't get to see on our stock Priuses.
  17. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    wtg windy...not uncommon at all. but you were just "barely" full green on the battery, because if you werent, the ICE would run to bleed off excessive power
    no...not lying. just the limitation of the display. if you had CANVIEW you would know that reading in the 100 to 200 mph range is common
  18. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    yes we do need some energy, but that energy is not provided by the car. its kinetic energy and unless on a steep hill, it will immediately begin to lose velocity unless the car starts to contribute. so tru, not EV mode... i call this "soap box derby" mode.
    actually i dont call it anything. (would never cheapen my Prius) i just let my passengers thoughts run wild on the subject
  19. ken1784
    2,940
    1,359
    67
    Yokohama, JAPAN
    I see the CANVIEW is also telling a lie. :)
    My SuperMID T-1 tells me the truth.
    Ken@Japan
    http://priusdiy.fc2web.com/
  20. ken1784
    2,940
    1,359
    67
    Yokohama, JAPAN
    OK. Assume you are telling us the technical truth.
    One...
    You are wasting the kinetic energy to spin the ICE, it's not free-spinning.
    Two...
    The PSD or power split device is a torque spliter.
    Your MG2 is spun by the kinetic energy torque and we need some torque to spin the ICE.
    We have to apply some torque to MG1 to spin the ICE which consumes some battery energy to MG1.
    Ken@Japan
