I ran in ev mode going 53mph
Discussion in 'Gen 2 Prius Main Forum' started by windstrings, Feb 11, 2006.
  1. EricGo
    EricGo New Member
    1,805
    Albuquerque, NM (SouthWest US)
    Hi Ken,
    Do you know how much energy in kW is used to spin the ICE when the car is travelling over 42 mph, and no arrows on the MFD ? Is there a power drain from the HV ?
    Dave, I drive a 3 - 4 mile decline a couple times a week, and so experience this often. The MFD always shows ICE off; depending on how much I push the gas pedal, I can see arrow to the HV, from the HV, or no arrows at all.
    The HV -> PSD state would seem to contradict the notion of kinetic energy to M/G, because some of that energy would be split and sent to the battery, and energy flow to and from the HV at the same time does not make sense.
    Make sense ?
  2. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    actually i base my conclusions on
    amperage being -1 to -2 amps... this is the normal range of vehicle when on and NOT moving.
    ICE RPM's at zero. does happen at times...usually though, its at its "idle" position of around 900 RPM.
    zero gasoline consumption
    instaneous mpg reading infinite
    also, if you put the car in neutral and coast down a hill you will see the same reading on the energy screen... now what is making the car go then?
  3. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    No, I have no specific data now.
    Have you ever spun a crank shaft by hand?
    We can't keep the crank shaft at 1,000rpm by hand.
    Ken@Japan
  4. EricGo
    EricGo New Member
    1,805
    Never have. I do not understand your point. Please explain for slow people.
  5. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    I have not noticed it yet, but I could see going over 42 is possible with 0 rpm.
    This is because I can coast over 34 mph in EV mode and still stay in EV if I don't accelerate and I coast back down under 34 before using power.
    And you can definitely coast with no gas flow over 42 with engine spinning. Just means the energy is coming from the battery for MG1 and you may not see it because the hills energy is feeding power back into the battery. You are still wasting energy over driving under 42 with engine at 0 rpm.
    Hopefully the next Prius will allow engine at 0 rpm for speeds up to about 55 mph.
    We have very few roads here we can drive at only 42 mph.
  6. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    We need some energy to spin the ICE.
    Let's assume we have a plugin Prius-B.
    The Prius-B has no limitation of EV mode speed and we can drive at any speed in EV mode, but the ICE should be spun above 42MPH.
    Now, we start the Prius-B and it's speed is increasing.
    Below 42MPH, the ICE is at 0 rpm and we enjoy the EV driving.
    Now, passing to the 42MPH boundary, we have to spin the ICE.
    I think it is wasting some energy to spin the ICE and it's not a pure EV mode.
    How do you, everybody, think?
    Ken@Japan
  7. eflier
    eflier Silver Business Sponsor
    164
    Fraser Valley BC
    Ken has brought up a very interesting point here: just what is there about this 'magic' 42 mph limit?
    Without access to Toyota's design criteria, I have to fall back on the power-split basics:
    I guess by now nobody disputes the power split equation
    MG1 rpm = (ICE rpm x 3.6) - (MG2 rpm x 2.6)
    At the 'magic' 42 mph, MG2 is doing about 2860 rpm +/- few % for tire variations.
    So MG1 = ICE rpm x 3.6 - about 7436
    So if ICE is stopped then MG1 = -7436 rpm.
    Now as MG1 is rated at 10,000 rpm, this obviously isn't the reason to stop EV mode at 42mph.
    Conversely, if we drove MG1 to -10,000 rpm, just like it goes to +10,000 rpm under initial acceleration, then if ICE was held stopped, we would get MG2=3846rpm and so road speed of ~67 mph. So again, no obvious reason to limit EV to 42 mph.
    I am going to suggest one possible reason for technically limiting zero engine rpm to 42mph max. (No doubt someone will think of others) MG1 certainly reaches +10,000 rpm during acceleration from standstill, but this is only temporary because as road speed rises, MG1 rpms drop down again. So what if MG1s rpm limit is a transient one, ok for 10 seconds of full power but not rated continuously?
    Allowing it to run at 10,000 rpm at 67mph even assuming there was enough batetry power to do that and it was tail wind or slightly downhill, that would allow a continuous MG2 high rpm rather than a short burst. So maybe in the interests of reliability, Toyota
    chose 42mph and 7400 odd rpm as the maximum rpm it would allow MG1 to run continuously. Maybe it would still allow higher rpms for a short burst, which might explain some people seeing zero ICE rpm above 42mph, for short periods.
    Please point out the flaws in this!
  8. eflier
    164
    Fraser Valley BC
    quick revision: last post had typo of MG2 instead of MG1
    Allowing it to run at 10,000 rpm at 67mph even assuming there was enough battery power to do that and it was tail wind or slightly downhill, that would allow a continuous MG1 high rpm rather than a short burst. So maybe in the interests of reliability, Toyota
  9. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    I think you're basically right, but your maths is slightly off. By my calculations, 42mph with engine stationary corresponds to roughly 2400rpm on MG2 and -6200rpm on MG1. And 6500rpm has long been believed to be the MG1 rev limit, although HSD lifted it to 10000rpm, but apparently only forwards for bursts of acceleration.
  10. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    And I don't really understand Ken's point. Over 42mph, you're still running on electric only. Yes, it's less efficient than under 42mph because you're spinning the engine, but so what? It's just an extra load, just like air conditioning. Doesn't stop it being purely electric. Do you claim the new Honda Civic can't run on electric only because it spins its engine?
    And because that extra load makes it inefficient, it won't tend to bother attempting electric-only operation at that speed in most cases, unless it wants to drain a full battery, or is running downhill.
  11. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    Why is it that the battery needs to drain by spinning the ICE? to prevent overcharge from the coasting and braking regen?
    Also, What is still fuzzy in my head.. if the electric motor cannot provide power for EV over 42 mph to prevent too high of a rpms to the Elec motor, then how can it provide power when going 60 or 70 when you accelerate?.. Wouldn't that too be spinning too fast at that speed?
    In the first senario, I hear it protects itself, yet it operates far above that?
    In fact I hear the car limits itself to 115mph to preserve the electric motor also?
    Whats the difference between that high speed function verses the low speed "42mph" function?
  12. eflier
    164
    Fraser Valley BC
    Yup, you're right, MG2 2400 rpm at 42mph so MG1=-6240. Sorry.
    I have looked high and low in the past for MG1 specs and have never actually seen a number quoted by a Toyota source for the 2003-2005 MG1 limit. Just for the 2001 and its not clear if the assumption that no changes occurred for the newer model is reasonable.
    Anybody have any more info?
  13. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    My point is that it is a pure EV mode or not.
    The pure EV mode does not consume any extra energy.
    No, I don't recognize the '06 Honda Civic Hybrid runs on electric only mode.
    Ken@Japan
    PS. It's now 4AM my time. Good night every body. :)
  14. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    Okay, I'll leave Ken off in cloud-cuckoo land, and try to address Windstring's question...
    It's all to do with the 3-way power-split device. Roughly speaking (ignoring multipliers), the power split arranges that
    MG1 rpm = Engine rpm - Wheel/MG2 rpm
    The faster the car is travelling, the faster MG1 spins backwards. At around 42 mph, MG1 reaches its rev limit. This can be counteracted if the engine starts spinning forwards. 1000rpm on the engine is sufficient to keep MG1 below its rev limit at all speeds up to 106mph (the point at which MG2 reachs its rev limit).
    When you're accelerating, the engine spins faster, and MG1 spins faster, FORWARDS. So, depending on load, MG1 may either be going forwards or backwards. Its limit going forwards (when being driven by the engine) is 10000rpm.
    So, there are 3 restraining factors:
    1) to stop MG1 going too fast backwards, the engine has to start spinning above about 42mph.
    2) to stop MG1 going too fast forwards, the engine revs are kept lower at low speeds - it can't reach its maximum of 5000rpm until at 54mph or above.
    3) to stop MG2 going too fast, the car's speed has to stay below 106mph.
    This is all very hard to explain - it's clearer if you use one of those interactive animations that are around on the net.
  15. Frank Hudon
    Frank Hudon Senior Member
    4,147
    page 7 of the blurb that Toyota Canada gave the dealers. Not much else on it some stuff on the MG2 output and some black and white drawings of the magnet placement in the rotors. If your really interested I'll scan and email.
  16. tomdeimos
    995
    Lexington, MA
    I expect the 42 mph limit comes from two things:
    1 42 is the max speed that Toyota feels is economical to drive on battery power, on level ground. Coasting down hill probably was not considered important to make a special case for.
    2 If the engine did not spin above 42, there might be too much lag in getting the engine up to speed in case you needed to accelerate fast. The lag we already have bothers some people here. And at higher speeds the start up acceleration can't come from the electric power the way it does starting up from a stop.
    Maybe Toyota will give us a switch to keep engine off longer with a sw update someday?
    We could keep engine off longer where we were cruising and knew we would not need to floor it. It would be like a car with overdrive where you have to shift out of it to accelerate.
  17. windstrings
    6,280
    378
    Central Texas
    Ha!... funny!.. thats ok Ken.. I go there quite often myself! :blink:
    Yea.. I saw the antimation.. pretty cool.. but I'm sure cooler if you actually know what its doing!....
    I appreciate the explanation.. that seems to make sense although I don't have a full grasp yet.
    So how can Toyota make it to where we can go full EV at faster speeds?
    A. Make the max rpm of MG1 yet higher to go above 10000?
    So whats the ratio?.. does that mean if the MG1 could handle rpm's up to an extra 1000 "11000" rpms that you could go up to 116 mph in full EV?... Prob not.. I expect the ratio's are not 1:1.
    B. Make a bigger MG1 so it can do more work with less rpm's..
    Both of the above would require bigger battery capacity to make it worthwhile I suppose.
  18. daniel
    14,487
    1,519
    Spokane, WA
    It's all in the geometry of the PSD and the specs of the components. Remember that Toyota selected a design that they felt would be the best balance of price, performance, and efficiency for the normal mass-market consumer. And remember also that the normal Prius driver is not here on Prius Chat, because he/she does not care about any of this technical stuff. She/he just wants a reliable, efficient car that can be driven just as though it was a normal car, but consuming less gas and having less emissions.
    They're not likely to give us any special switches to tweak performance because there's not enough demand for it. However, if the price/benefit ratio becomes favorable, they may give us more battery capacity, because that would improve efficiency, as Wayne Brown has demonstrated. And/or, since the battery is severely limited in how fast it can receive or provide charge, they may incorporate capacitors as a buffer between the battery and the motor-generators, which would also improve efficiency.
    There's a big market for better gas mileage. There is very little market for gadgets that allow the driver to tweak the performance. (Which is why we had to install our own EV switches!)
  19. rogerSC
    rogerSC Member
    170
    Well, it's clear to me why 42 is the fastest you can drive in "pure EV" mode...After all, 42 is the answer to life, the universe and all.
    -Roger
  20. EricGo
    EricGo New Member
    1,805
    Ken asked if ICE spinning is not EV mode by definition. If no petrol is used, and all energy comes from the battery, then I say EV. Less efficient, yes.
    In the case of the Prius, the battery's energy has started in petrol, but does not define the argument, because the battery may in the future be charged from the grid.
    So perhaps a place to start is: Can the battery spin the ICE thorugh the PSD ? Not if it happens, but is it mechanically possible.
    Parenthetically, although this is a fascinating topic, I'm Aok with a Prius+ that uses 0.2 - 0.3 gallons of petrol/hour at highway speeds if that turns out to be the case in a plug-in augmentation.
