I ran in ev mode going 53mph
Discussion in 'Gen 2 Prius Main Forum' started by windstrings, Feb 11, 2006.
  1. darelldd
    6,059
    389
    Northern CA
    oops. Never mind. Didn't read the whole thread before responding.
    I *do* know what real/pure/full-bore EV mode is, however. I just don't expect to get much of it in a Prius! :)
  2. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    It turns out that the pulse-n-gliders were actually drawing up
    to 5 amps out of the battery to help push the car along -- just
    a little bit, but a little more motive power than just popping
    into "N" and truly coasting. So it appears that drawing a *little*
    bit out of the battery to help keep going isn't a bad thing, as
    long as you don't drain it all the way down to 2 bars on glides.
    Unless you're about to go down a huge hill, then that's a different
    situation. The marathoners were on flat or very gently-rolling
    terrain, which is sort of optimal.
    _H*
