I really don't need an oil change until 10K??
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by schiffy, Sep 13, 2014.
  1. bisco
    52,832
    yes, it's amazing how clear it stays. but i doubt you can tell much from observation. i think you're fine with 8500 hv miles.
  2. markabele
    5,084
    1,782
    Nebraska
    I plan to do 9-10k hv miles before my next oil change.
    52,832
    i'm thinking the same way, now that i have to pay for it.:D
  4. rxlawdude
    rxlawdude Active Member
    701
    220
    So Calif
    2015 Tesla Model S
    For synthetic oil, 10K miles, non-severe use.
  5. markabele
    5,084
    1,782
    Nebraska
    I paid a little over $60 for the oil change and tire rotation. Hopefully I didn't get taken too bad.
  6. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    I know this is a PiP thread about oil change anxiety, but I just got my 2nd oil change at 96,000 miles.
    I had planned to do it before leaving on my epic road trip from San Francisco to Ohio and back but ran out of time and ended up doing it in Indianapolis. I pulled the dipstick before leaving on the trip and the oil was a nice looking amber brown. The dealer said the engine air filter looked fine so I'm still running with the original. Total cost of both oil changes is under $100.
    With this trip almost over I'm down to a 62% EV ratio so I've driven a total of about 36,000 miles on the gas engine. I did the 1st change at the 2 year maximum interval. This time it's been 22 months and the Volt's computer indicated I had 1% oil life remaining.
    #26 Jeff N, Sep 23, 2014
    mmmodem and GregP507 like this.
  7. GregP507
    GregP507 Senior Member
    3,002
    481
    That's one of the most sensible posts in this thread. Endlessly erring on the side of spending money is very wasteful, and exactly what the industry wants.
    #27 GregP507, Sep 23, 2014
  8. Okinawa
    Okinawa Senior Member
    1,333
    320
    I think you did okay. You only have to do it every 10,000 miles. I have a new Avalon and I still have the 2 year free service. I usually buy the lifetime balancing and tire rotation, for the life of the tires that are on your car, from Discount Tire and just have the oil changes done at Toyota. I don't intend to take my car back to Toyota every 5,000 miles when the free stuff ends. That way I just go back to Toyota every 10,000 miles.
  9. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    Would be nice if there were an affordable home kit to check the oil status (including moisture). Could save a lot of unnecessary oil changes. Still would make a lot of people nervous because of warranty stipulations.
  10. jack520
    jack520 Member
    154
    40
    2014 Prius Plug-in
    Some say there is no harm doing oil changes at 5000 miles....
    Well, there is...you put an additional strain on the environment by having to recycle and reuse that oil.
    On top of that, you could be spending your time taking care of your health or other people.
    You guys owning PIP's are advent guard technology adopters...trust the engineers or do your own engineering...
    GrumpyCabbie and markabele like this.
  11. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    And why stop at every 5,000 miles? Why not turn the clock back further and do them every 3,000 or maybe turn it back further still and change the oil every 1,500 miles?
    Or maybe like you suggest, they could trust the very people who designed their car.
  12. Mike500
    Mike500 Senior Member
    2,593
    767
    The Prius engine holds a little over four quarts or four liters of oil.
    Toyota states that 1.1 liter for every 600 miles is within limits and is acceptable.
    At 2k miles, your engine could be down to one quart in the crankcase.
    If you don't change until 10k and don't check the level in the crankcase, you could be needing a NEW engine.
    Think the Toyota warranty will cover it? Don't think so.
    I'll keep on changing oil and 5k.
  13. Mendel Leisk
    42,331
    Well, Toyota Canada is telling me to change the oil every 8000 km or 6 months. The intervals, and the oil grades, seem to me to be somewhat arbitrary, going around the world. 8000 km's likely IS overkill, but a DIY oil change costs me about $25, the used oil is recycled, and most importantly, I need the hobby. ;)
  14. CharlesH
    2,798
    1,166
    Roseville, CA
    Isn't that why they want you to come in every 5K miles/6 months? "Check fluid levels." Of course, you can check the level yourself, but the point is not letting it get too low, not changing it that often.
    I would think that a car that losing one liter of oil every 600 miles has a problem.
  15. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    There's a big difference between an oil change and your own regular maintenance check.
    I agree with you, the owner should check their fluid levels. Can't believe the person you responded to thinks that it's Toyotas problem that people don't look after their own car. Always someone else's fault.
  16. bisco
    52,832
    funny thing is, none of my 3 pro have ever burnt any oil. granted, i haven't had one for more than 100,000 miles.
  17. bisco
    52,832
    so the question becomes, what if you don't put 10,000 miles per year?
  18. Mendel Leisk
    42,331
    When I went to the new owners open night at our local dealership, the service manager lead us around the service department, mentioned at one point: "you never need to pop the hood". Grrh.
  19. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    ROADTRIP!!!!!!!
    My590L likes this.
  20. bisco
    52,832
    that's what the hycam's for.(y)
