I really like the traction control
Discussion in 'Gen 3 Prius Main Forum' started by Rhino, Feb 8, 2010.
  1. Rhino
    Rhino New Member
    460
    U.S.A.
    Just a bit of good news to lift your spirits.
    I was driving on snow covered roads for 30 miles today and the car was extremely well behaved. Antilock brakes works fine.
    Starting from a standing stop is easy. Just step on the gas, traction control takes over. Sure is a lot easier to drive than my other cars. No need to be too concerned about throttle, traction control just takes over.
    Is it even possible to spin out on a Prius - I don't think so. It is great.
    Ground clearance could be better but it is a high performance car (I mean gas mileage performance) so some sacrifices have to be made.
    And after all of this, I got 48 miles per gallon according to the car computer. I know some of you calculate mpg independently. I am not concerned about actual mpg - I use the car's mpg calculation so it can be compared to other Priuse performance easily.
    I poured in a gallon of windshield wiper solution yesterday but it is not full. Does anyone know how much solution it takes? No big deal though, I get some more.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The windshield washer reservoir holds a bit over one gallon. The intention is that you can add a full gallon when the tank is low.
    Tom
  3. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    In some other traction control thread, which I can't find now, someone asked who had been able to get the VSC system to cut power to the wheels in Gen III.
    Well, I did tonight. It was really stupid, in my own yard.
    I managed to get the rear wheels in the mud, and the front wheels on some very loose gravel, uphill from the mud, and the traction control system cut power almost as soon as the front wheels started to spin.
    I had to back up, to get the whole car back on the road.
    I don't blame the car for this one; it was the stupid driver.
  4. CivicQc
    CivicQc The world needs more prius
    233
    99
    Planet Carbon
  5. hsiaolc
    hsiaolc New Member
    617
    46
    UK
    The traction control is good like I expected to work. Havn't really used it much since I drive very slow these days and hardly lose traction.
  6. qbee42
    18,058
    3,074
    Northern Michigan
    This is an example of traction control doing what it is supposed to do. In this situation, spinning the wheels would only dig a hole. I suspect the tires were slowly spinning, but the Prius is so smooth you can't tell without getting out and looking.
    It's always important to remember that traction control cannot create traction where there isn't any. All it can do is control wheel spin, which will help, but only up to the physical limits of the tires and the road surface.
    Tom
  7. kgall
    kgall Active Member
    984
    152
    I've noticed several times in the last few days that the traction control kicked on (triggered the sliding car icon) on my long gravel driveway, even when I didn't know I needed it, except that maybe I thought I was driving a bit faster than normal/faster than I should.
    This means either that
    1) it's really good at keeping the car acting normal and/or
    2) it starts to work even with small signs of slippage, that a human being might not notice.
    Both of these I think are good.
    Traction control is becoming more and more necessary--on all cars. For example, low rolling resistance tires may reduce traction in some circumstance. Got to get that traction back somehow, or you will have more accidents.
  8. LeadingEdgeBoomer
    289
    29
    New Mexico
    I think that RPM limiting in N, along with traction control, are necessary not only for safety but because way-excessive engine RPMs, whether trying to spin out of a snowbank, or otherwise screwing up, would damage the motor-generators and are thus prevented. On the road, the CV tranny has no need for excessive RPMs at any speed.
  9. cossie1600
    cossie1600 Active Member
    898
    92
    CT
