I really wish the dealer told/showed me...(post your wishes)
Discussion in 'Newbie Forum' started by Weirdo23, Jun 13, 2008.
  1. Lexie
    Lexie New Member
    North Florida
    I love my new BLACK Lexie. However, I wish I was given some good info/advice on remove the water spots. Will the Toyo Guard that came with it do the job? I looked on line at info regarding the care of Black cars and read Mother's cleaning wax did a good job.
    Any ideas?
  2. 3PriusMike
    3,097
    2,419
    Silicon Valley
    OK, depending on how paranoid you are, if someone steals your car they can find your home if you do this...so it might be a good idea to program in a place that is near your home but not actually your home.
    I forget all the choices but I went to a nearby shopping center and just pushed a button and it record the lat/long of where I was, not an actual address.
    Mike
    Ndj12, Txzookeepers and Tracy like this.
  3. Lars
    Lars New Member
    East Bay / CA
    - how to turn off the back-up beep
    - that CD slot was behind navigation panel
    - that I'd need to drill in the back to attach a cargo net
    Overall, had a very positive experience with Novato Toyota in CA
  4. RMulligan
    RMulligan Junior Member
    Hawthorne, CA
    Four Touring
    Nope, the bladder is still used on the 2010. I believe Toyota is using this design to help minimize gasoline vapor emissions. So I don't think they will change back to a hard tank.
  5. CenVal
    CenVal Member
    48
    Bladder has been removed and is not on 2010. This has been discussed on numerous threads in PC. Toyota has redesign the system to comply with emission standards.
    Ndj12 and alohabailey like this.
  6. DFWPrius2009
    DFWPrius2009 New Member
    32
    DFW
    We got the Toyota extended warranty for $1599 which I was told is the employee price.
  7. LRKingII
    LRKingII New Member
    679
    132
    Idaho
    You can get it here from the forum for 7yr 100k miles for $1055.
    Search for info
  8. rjv
    rjv New Member
    Ventura
    I wish the dealer told me how to disable the beeps when in reverse. There must be a way to disable this annoying feature.
  9. roadog03
    roadog03 New Member
    Arizona
    Hey rjv...I grew up in Ventura from 1952-1970....we disabled the reverse beep and when door unlocks changed it to unlocking all doors...and no beeping with drivers seat belt undone....search the forums here simple to do takes a few minutes and two hands with your fob.
  10. Bica2go
    Bica2go New Member
    321
    57
    Boston, MA
    To change the reverse beep in the 2010 you have to go to the dealership to have it reset (from constant to 1 beep). You could do it yourself in the G2's.
  11. donnaroberts
    donnaroberts New Member
    Montgomery Al.
    I wish the dealer had told me about the smart key system being dangerous for heart patients who have pacemakers or defibulaters. Does anyone have any info on this?
  12. ragman
    ragman New Member
    25
    Chichester, NH
    At the dealership I worked at a long time ago I saw a salesman sell an aftermarket 100k powertrain aftermarket warranty to a customer on a car with a factory 100k powertrain warranty...
  13. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    It depends where your defibulator was manufactured. I would suggest contacting your doctor to ensure where it was manufactured and check to be sure.
    Also check this link to see if may shed some light.
    Hope that helps...
    Knoxville woman returns car over 'Smart Key' warning
    I don't know that you have any serious issue from reading the article but double check to be sure.
  14. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    Good Luck!
  15. pdhenry
    pdhenry It's HEEERE!
    406
    PA
    You can turn off the smart key receivers in the car using the pushbutton under the steering wheel. Note that there's a receiver in the center console so staing 9-12 inches away from the recievers isn't practical..
    The fob will work fine if you stick it in the dash slot.
  16. EternityInBlack
    EternityInBlack Junior Member
    33
    How to reset the trip meter. I've been looking at the manual for quite a while on how to do this, even searching PriusChat, but somehow I can't find it :(
  17. DrJon
    DrJon New Member
    140
    16
    Pinetop, AZ
    Hold down the TRIP button on the steering wheel till it resets!
    ITBland and EternityInBlack like this.
  18. iancrawfs
    iancrawfs New Member
    Cambridge UK
    Hi. Reversing beeper is a dealer option to change to one beep rather than continuous. Seems i was first person at my dealer to ask for this in all the years they have been selling Prius here in the UK. First answer was "too difficult". Once this site was shown to them it was all okay. Thanks again.
    Ian
  19. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    While the selected Trip is displayed, HOLD down the DISP Button for a few seconds and it will reset the one you have active. You can reset either A or B, but have to have it displayed or active at the time....should work like a charm for you. Use the Steering wheel control.
  20. murrat1234
    murrat1234 New Member
    india
    Hi to every one
