I reconditioned my hybrid battery - by accident
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Matt98svt, Dec 3, 2024.
  1. johnHRP
    johnHRP Active Member
    644
    187
    KA, DE
    Excel
    I managed to overcharge or overheat the battery and trigger "Check hybrid battery cooling system" on the long downhill in the Alps. The battery level shows solid full but then I stop and monitor the temp with Dr. Prius. It was about 58C and no more warning after that. I should put to B mode or cruise so the car select automatically to B when it's full. The ECU is not smart enough in D mode not to overheat the battery
  2. ASRDogman
    ASRDogman Senior Member
    7,602
    3,915
    You should check the fan, and vents.
    I don't believe the Prius computers will allow the battery to be overcharged.
  3. johnHRP
    644
    187
    KA, DE
    Excel
    Probably it is just mildly overheated in summer long 20 minutes downhill. I also doubt it is overcharged too. I removed the add on filter (fiberglass like) that I made behind the clip on screen on the cooling intake. It was there for more than 1 year without issue until my Summer vacation in the Alps.
    I remember 3 years ago, with the old rusted brake disc I experienced vibration after long downhill. But after disc and pads replacement, it never happened anymore.
    I think in D mode the ECU still allow recuperative braking but not 100% as when the battery is not "full".
