I removed my inverter for unrelated repair access; now it's bad?
Discussion in 'Gen 2 Prius Main Forum' started by rooshio, Nov 17, 2021.
  1. rooshio
    rooshio Junior Member
    Salt Lake City
    When I replaced my ABS actuator assembly , I removed the inverter (all connections except the hose) and put it back when I was finished. But when I started the vehicle for the first time, I got all the dash lights (tire, VSC, ABS, triangle). No power steering, drive, or reverse.
    Eventually I learned the 12v auxiliary battery was low; I figured that since I didn't unplug the 12v system while doing the repair (dumb, I know), the fob handshake may have been engaging electrical systems while I had it apart.
    After a full-night's charge and several test laps around the block, things seemed normal. I should have tested the voltage again, because shortly after all the same lights came on, I lost steering/transmission control, and the engine threw a P0A08 code. Luckily I was able to limp it home with a Walmart battery connected in parallel.
    And whadduya know, P0A08 is an error code for the circuit responsible for recharging the 12v auxiliary battery. My question is this: is it more likely that my inverter broke during the repair process or that I have a bad wiring connection somewhere? All the wiring harnesses in/around the inverter seem to be securely-clipped. Maybe some brake fluid is shorting out a connection?
    Looking for any diagnostic suggestions before I replace the whole inverter.
    51,756
    make sure the 12v is fully charged, and that the connexions are clean and tight, especially neg to ground.
    2102
  3. Aegean
    Aegean Active Member
    461
    203
    Alexandria VA
    I suspect the problem was created during your inverter removal and installation. I would disconnect and connect again all the inverter electrical connectors including high voltage MG1 and MG2 bolts and the inverter coolant pump connector.
    If fine then maybe something shorted while the 12v was on. Measure the fusible link Ohms and check the fusible link electrical connectors for burnout.
    ydpplqbd likes this.
  4. SFO
    SFO Senior Member
    5,302
    4,247
    Northern California
    dolj and rooshio like this.
  5. rooshio
    Salt Lake City
    Thank you! that's exactly the kind of resource I'm looking for.
    I'll also reconnect all the things and see if that helps.
    SFO likes this.
  6. rooshio
    Salt Lake City
    Whelp, I found the plug I forgot to reattach! What a satisfying click :) Car's back in action, no lights, and I'm feeling confident on the road again!
    I'm thankful for your suggestions and for this forum that's saved me more times than I can count!
    -205k miles
    Raytheeagle, SFO and dolj like this.
  7. nancytheprius
    nancytheprius Active Member
    365
    156
    iowa
