I test the Prius V PCS system with video!
Discussion in 'Gen 3 Prius Main Forum' started by Radarguy, May 14, 2010.
  1. That_Prius_Car
    That_Prius_Car Austin Kinser
    1,282
    344
    Pittsburgh, PA
    :eek:
    This makes me want to go out in the country with my Twilight cardboard cutout and our 2010 Prius V w/ Advanced Technology and test this out! Thanks for the info!
  2. Radarguy
    Radarguy New Member
    42
    37
    Utah
    Sorry for the blurry video. To answer your question, it say BRAKE!
    I think its funny because at that point you should already know what to do.:eek:
  3. Radarguy
    Radarguy New Member
    42
    37
    Utah
    A bit off topic, but i am thinking of making a detailed video covering the capability, and limitations of the Park Assist System. I have spent a considerable amount of time playing with the PAS, and I think i can clear up any confusion.
  4. LeeB
    LeeB Junior Member
    99
    Henrico, VA
    I'd be very interested in seeing that. I've used IPA several times and it's worked flawlessly in each case. However, I'm curious about it's limitations and how fault tolerant it is. I've done some web searching since IPA has been around for several years on the Lexus and non-US Prius models, but there doesn't seem to be much technical info available. So anything you can provide is appreciated!
  5. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    You might want to call it IPA to keep consistent with the formal acronym.
    I was playing around with perpendicular parking and found that a supporting column (in a parking garage) adjacent to the free space between two cars gave a distance too short error message, even though there was plenty of space.
  6. Radarguy
    Radarguy New Member
    42
    37
    Utah
    Yes IPA it is. Thank you for the correction. :)
  7. Tideland Prius
    16,665
    I guess as things become more computerized you have to shift your trust from mechanics to electronics. The computers have access to the steering wheel on any 2010 Prius. They work in the form of "S-VSC". When the vehicle is sliding, it applies resistances to the wrong direction so that the driver won't make the slide worse. Any Toyota/Lexus with VDIM will also have steering-assisted VSC.
    It also says BRAKE! with DRCC if you're approaching a vehicle at a rapid pace (or in my case, switch lanes right behind another vehicle to test out the system). BRAKE! with DRCC would be the 2nd warning (the first being the flashing radar cruise screen... the one with the two cars and the bars)
    Also another thing to note is the flashing PCS light on the passenger side.
  8. Thai
    Thai Prius Neophyte
    1,197
    89
    Wonderful video...many thanks!! Subscribing!
  9. Radarguy
    Radarguy New Member
    42
    37
    Utah
    The Video is up! http://priuschat.com/forums/gen-iii-2010-prius-main-forum/80507-video-i-give-you-rundown-all-cool-things-intelligent-park-assist-can-do.html#post1124639:)
