I think I found the source of my moderate speed vibration.
Discussion in 'Gen 2 Prius Main Forum' started by jelloslug, Sep 16, 2008.
  1. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
    took me a couple of tries to get my cv axle out of the trans.
  2. jelloslug
    jelloslug It buffed right out!
    813
    55
    Greenville, SC
    Did you pull it or pry it out?
  3. statultra
    798
    31
    Edison,NJ
    2001 Prius
    i pulled it with slide thing. took a while.
    the problem was i didnt have that 30 mm socket for the axle nut in addition to the impact wrench taking years to bring the nut out.
    it was pretty hard to get it out, took like 10-20 tries of the slide hammer.
  4. Patrick Wong
    18,210
    6,510
    How about installing the new axleshaft. The manual suggests using a brass rod and a hammer to install. Thinking ahead to when I have to do this, I've got a small sledge hammer - but where do you get a brass rod?
  5. jelloslug
    813
    55
    Greenville, SC
    From my toolbox. :D
    You can buy brass drifts from most automotive tool suppliers or just type "brass drift" into google.
  6. jelloslug
    813
    55
    Greenville, SC
    I have a 30mm impact socket and an impact wrench so that won't be a problem. I'm not going to pull the axle until the replacement part arrives on Tuesday so we will have to wait until then to see how hard it's will be.
  7. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    the more powerful the impact wrench, the better :D
  8. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    I always found "the more powerful the mechanic, the better". ;)
  9. statultra
    798
    31
    Edison,NJ
    2001 Prius
    when i installed the new axle shaft, i didnt need the hammer, it slipped in pretty easy.
    i ordered a aftermarket axle shaft on ebay, it included both cv joints and stuff, it seemed to be made of different material than the OEM, and the axle nut was much stronger, when i took out my old axle nut my impact tool messed up the head of the nut.
  10. jelloslug
    813
    55
    Greenville, SC
    Well, my replacement axle came in today.
    It's a little rusty but that's OK. It from a low mileage car and has a lifetime warranty.
    First step is to drain the tranny.
    Then loosen the big 30mm nut BEFORE you remove the wheel.
    Next unbolt the caliper from the knuckle and remove the rotor.
    Now unhook the tie rod end and unbolt the ball joint.
    Next I removed the speed sensor, pulled the ball joint out of the lower control arm, and then pulled the knuckle off of the axle.
    Time to break out the big guns.
    And poof! the axle is out.
    There were tons of these needle bearings in the grease inside and outside of the inner boot.
    The replacement axle popped in with no problem.
    Here is the new axle in the hub with the ball joint reattached to the lower control arm.
    And the tie rod end reattached.
    I took it out for a quick drive and the vibration is gone. It seem that the damaged CV joint was all that was wrong.
  11. galaxee
    9,810
    471
    MD
    good news!
    there wasn't any rust on the transmission end of that axle, was there? that's not exactly the prettiest used part i've seen.
  12. jelloslug
    813
    55
    Greenville, SC
    Nope, the transmission end was squeaky clean. I wiped it down with ATF before I put it in the tranny. The threaded end was rust free also. I found it odd for the center section to be rusted but the threaded section to be so clean. It did come form a norther car so I guess rust is to be expected. My drivers side axle shaft is already starting to rust and it's been in the south all it's life.
  13. Godiva
    Godiva AmeriKan Citizen
    10,339
    Fascinating.
    How long did all of that take? The pictures make it look real fast.
  14. jelloslug
    813
    55
    Greenville, SC
    I would say an hour and a half or so. It was not really that bad at all.
  15. Qlara
    Qlara New Member
    488
    Just curious, what tool is that and how it was used to pull the axle?
  16. Patrick Wong
    18,210
    6,510
    Qlara, that is the slide hammer.
    JS, thanks for providing the detailed photos.
    There must be some piece missing from the slide hammer photo - how did you attach the slide hammer to the CV joint?
    When disassembling the front suspension, did you need to use a puller to remove the ball joints?
  17. jelloslug
    813
    55
    Greenville, SC
    There is a crow foot attachment that screws to the end of the slide hammer and goes over the end of the inner CV joint. It looks like this:
    I did not need to use a puller for the joints. The tie rod end popped out with minimal fuss and the ball joint only required unbolting from the lower control arm so I did not have to remove it from the knuckle. Your mileage may vary though since this is basically a new car and things really have not had time to "seize up" yet.
  18. acyberbug
    acyberbug Junior Member
    Midwest
    Forgive the newbie question - I just discovered your thread - I need to replace the passenger-side axle on my 2006 Prius - how do you get it out of the trans - isn't there a "clip" of some kind holding it in? (Please excuse my ignorance) :)
    Thanks! Acyberbug (Dan)
  19. Patrick Wong
    18,210
    6,510
    Pls see the slide hammer photo on post 35 and commentary on post 37.
