I think my 12 volt battery needs replacing
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by asalligo, Apr 30, 2021.
  1. asalligo
    asalligo New Member
    Good morning, I am new to the forum, but my daughters Prius which has been in storage while she is in Spain is no longer starting without a jump and not holding a charge after driven for an hour. I was starting it once a month, but no one was driving it.
    I have been searching the posts and I see that I should try a battery charger on repair first and get it a full charge. Assuming that the problem continues must I buy an OEM battery replacement or an Optima Yellowtop? please forgive my ignorance, but why do I need a $250 battery to start the car?
    The battery has been awesome so far though, this is a 2011 Prius and nothing has ever been replaced. Frankyl, it has never had an issue. Just oil changes and tires for 10 years.
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,963
    4,709
    Texas Hill Country
    A $180 battery is fine as long as it is an AGM with a vent port. This battery is a 7 year long life battery specifically designed to be in the interior with your daughter. Some have used a flooded lead acid battery that could gas to the interior, could be mistakenly hooked up wrong and does not respond to deep discharges as well as an AGM. Call your local auto supply.
  3. Mendel Leisk
    38,709
    Yeah once-a-month start is nowhere near enough. How old is it? Assuming it’s getting on in years, and the car will continue to be mothballed for significantly further time:
    1. Disconnect and isolate neg cable. This is shutting the barn door after the horses have bolted, but hey.
    2. Window shop new batteries, just be ready.
    3. Research smart chargers (3~4 amp range) and electronic load testers. The former run through a multi-stage charge session and then can be left on indefinitely, as maintainers, if that’s practical. The latter ask for some info about your battery, then test it’s actual Cold Cranking Amps, and give a verdict.
    #3 Mendel Leisk, Apr 30, 2021
    49,444
    if it is original, don't bother trying anything, just replace it. if it is not going to be driven regularly, hook it up to a maintainer.
    as for batteries, if you got 10 years out of the first, why change?
    Fred_H likes this.
  5. asalligo
    asalligo New Member
    Thanks everyone, I ordered the new battery, even with the charger attached the old battery will not start although that does make the doors work. Is there a process I need to complete when a new battery is installed?
  6. rjparker
    7,963
    4,709
    Texas Hill Country
    On my gen3 I have not had to reprogram the windows or the presets, although it will change channel to a default fm station after a battery disconnect.
  7. rjparker
    7,963
    4,709
    Texas Hill Country
    Sorry, I have been telling everyone a 2011 is a gen3. Now I know.
    Edit:
    I thought I was wrong once but I was mistaken.
    #7 rjparker, May 28, 2021
    jerrymildred likes this.
  8. jerrymildred
    jerrymildred Senior Member
    11,508
    14,110
    Tampa, FL
    Welcome, @asalligo. I hope the new battery is working OK for you. I'm curious. Why did you decide to buy a battery that will probably only last about 1/3 to 1/2 as long as the one that powered the car for over 10 years and only died from sitting in storage? The Florida heat is murder on batteries.
  9. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    You need to be positively sure that your new battery is fully charged before or soon after installation.
    You can't trust the car OR a shop to do that.
    Anything else that needs to be done should be obvious.......like radio pre-sets.
  10. Tideland Prius
    16,147
    2011 is a Gen 3. (2010-2015)
  11. jerrymildred
    11,508
    14,110
    Tampa, FL
    I'm pretty sure he was being sarcastic. :D I have that spiritual gift myself, so I tend to spot it more easily in others. I often have to restrain myself. :ROFLMAO:
    #11 jerrymildred, May 29, 2021
    Tideland Prius likes this.
  12. rjparker
    7,963
    4,709
    Texas Hill Country
    The context is missing but I took the high road of sorts. A member had crucified me for bringing up a gen3 function in a gen2 forum. Even though the OP had specified the car was 2011. I did not quote the member on purpose and he ran for cover by editing the comment to a "."
    Then the mod apparently moved this thread to gen3 and deleted the post with the "." erasing all context.
