I think we're going solar
Discussion in 'Environmental Discussion' started by jerrymildred, Feb 5, 2021.
  1. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    I don't have a specific fee labeled on my bill for just having the house tied to the grid. All charges on my bill are rate multiplied by the kWh usage from the meter. Supply, Conservation Charge, Transmission, Distribution, Green Power surcharge, and tax. I have never had a month that we did not use any electricity (or minus use by net metering), so I don't know if they would bill me some basic charge or not. I think if I have no electric use at all for a billing period, I would just receive a $0 bill, but I think such basic connection fees if existed, are very fair. After all, maintenance of the grid is very hard and expensive. Unless I am 100% off-grid, I am glad to pay my share of the cost.
    R-P, Trollbait and jerrymildred like this.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    I concur, Doctor. ;)
    alanclarkeau and Salamander_King like this.
  3. fuzzy1
    10,707
    The article indicates that 20% of customers there have solar. That is vastly higher than here, and reaching a point where battery storage, at home or elsewhere, becomes necessary for grid stability and management. The rate structures should reflect that.
    That was implemented here long ago. My utility currently charges just over $75/year as a connection-account fee, separate from energy use, and this is going to rise over time.
    Some other places just charge this as a minimum, crediting it against energy use.
    A sibling who bought a couple small farms adjoining dad's place, pays a regular connection charge for the electric service to both. The house on one burned long ago, the other still has an abandoned farmhouse. But both still have electric service for seasonal water pumping for the livestock pastured there. They have zero usage most of the year, but still must pay a connection charge each month, keeping the lines up.
    jerrymildred likes this.
  4. jerrymildred
    11,517
    14,167
    Tampa, FL
    Talk about your mixed feelings. They finally got the permit on Friday. Said they would be here today (Wednesday) to start. But I had a stress test also scheduled for this morning. I really wanted to be home for the whole project. But I got home and found that most of what I'd missed was just unloading and getting things onto the roof. They are screwing down the mounting system now. More pix to follow, but for now, here's what it looked like after I got out of the car.
    BTW, the stress test was great. They were duly impressed with both my heart rate and my recovery time. Saw no issues.
    #84 jerrymildred, Apr 21, 2021
  5. Prodigyplace
    12,713
    11,848
    Central Virginia
    I did not realize you were a bot o_O
  6. jerrymildred
    11,517
    14,167
    Tampa, FL
    Shhh! Don't tell people. :ROFLMAO:
    Now the late comers will wonder what you're talking about because I fixed it before the time limit. :whistle:
    BTW, an update. They got the rails in place and the inverters mostly done. Then they found that the supply house didn't give them ground wire and they were missing a couple connectors.
    They will be back in the morning and the electricians will come, too.
    #86 jerrymildred, Apr 21, 2021
    alanclarkeau likes this.
  7. R-P
    R-P Active Member
    808
    288
    Netherlands
    So micro-inverters? Brother-in-law just got a couple with micro-inverters. I may add some on the parts that get shadow. Right now I have two panels in the 'shadowy' part of the roof on a regular almost 20yr old 300W inverter (Maybe 15, the manufacturer replaced them after a few years due to a possible risk).
    Parents-in-lw have a Solar Edge with optimizers. Have had an optimizer fail within 2 years or so. Neighbors have the same system but always have trouble with it...
    I have a second-hand 15 year old 5.5kW inverter (that has error-lights burning on the front since I got it 10 years ago) works great!
    Glossary:
    Micro-inverters have one or two panels attached and are mounted close to the panels The output is 120VAC (or 230V~in Europe) and directly grid-tied.
    Pros: partial shadow from e.g. a tree will only affect one inverter, cons: they sit outside (heat cold moisture) and are more costly than a single big inverter.
    Optimizers: one or two panels on one optimizer. This manages this one (or two) panel and gets the most out of it. All optimizers talk to the inverter sitting inside and through comminucation they can all deliver their maximum power. One with shadow will report a decrease in powercapability and the rest will adapt. The output of all optimizers is 350VDC in Europe and this saves a step that is normally done in the inverter, so efficiency is on par with other systems. The inverter is grid-tied. Pro: shadow isn't a problem, Con: more electronics and even communication over the powerwires, so more components that can fail.
    (Good oldfashioned) Inverters get the DC inputvoltage directly from the solarpanels. This can sometimes be 45-135VDC (my 300W inverter) or 150-450VDC (my 5.5kW inverter) or sometimes even up to 800VDC input. This is again converted to the AC grid-voltage and is then grid-tied.
    Pro's fairly simple both in working and when mounted inside, no temperature or moisture danger. Con: when ONE panel out of a string of 10 has some shadow, the other 9 have to follow the one with the shadow in current.
    In numbers: 10 solarpanels of 100W each, so 1000W total power. One in the shadow limited to only 50W output.
    Micro-inverter for each panel: output 50W + (9x100W) = 950W
    Optimizer for each panel": output 50W + (9x100W) = 950W
    Inverter: output 50W (+9x50W) = 500W.
    Seems like a no brainer NOT to go for a regular inverter, but what if you virtually never have a shadow? Why pay twice as much for your grid-tied invertersetup?
    #87 R-P, Apr 21, 2021
  8. Leadfoot J. McCoalroller
    8,289
    7,802
    Pennsylvania
    2018 Prius c
    Anyone have any Pennsylvania advice or experience to relate?
    I have homebuilt small self-contained offgrid solar power systems before, but now I am interested in something bigger than I can build myself, so it's time to step back and invite pros.
    The basic proposition: I'd love to put in solar on my too-large lawn. After the energy benefits, it is less to mow, and possibly a useful sight/sound block vs. highway noise out front.
  9. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    My system is only 1.5kW. The inverter had its 10th birthday - and died a week later. Replaced it with a new, but "old-stock" 3kW which works better than the old one ever did.
    MMBH and jerrymildred like this.
  10. fuzzy1
    10,707
    Jerry's microinverters (I looked them up earlier), like mine and most others in the U.S., output to 240V. These particular units are also rated for 208V, and I suspect many competing products do the same.
    Using 240V, instead of 120V, reduces line losses and allows more power on a circuit branch.
    My installation has significant tree shading issues, some right now, but lots more during the six months of lowest sun angle.
    #90 fuzzy1, Apr 21, 2021
  11. jerrymildred
    11,517
    14,167
    Tampa, FL
    First, as @fuzzy1 says, the micro inverters here are 240V, so less line loss. Another thing is that if an inverter fails (they have a 25 year warranty, by the way), the system will still keep working.
    But my main reasoning has more to do with the reputation of the installing company for expertise and integrity. There are some pretty unscrupulous companies doing this stuff. It's important to me to connect with one that will deliver on their promises.
    The radio station I helped build in Africa had a 30kW system put in using two SMA TriPower - 15000TL-20 Inverters and three
    Sunny Island 8.0H Inverters. One of the SMA inverters recently failed after only three years of operation. With shipping, customs, taxes, etc, that's going to cost them about $6000 to get back that 15kW. I have 20 350W panels and 20 inverters. If one inverter fails, I only lose whatever that 350W panel can produce while waiting for the new inverter.
    Since we can't put it online till after inspection and approval by the electric company, I'm not sure how much I'll get to see of its operation immediately when the installers are done. But they should finish today and I hope to be able to get my first peek at what to expect as far as operating it.
    fuzzy1, alanclarkeau and Prodigyplace like this.
  12. jerrymildred
    11,517
    14,167
    Tampa, FL
    I obviously can't give you any help up in PA, but I can say that solar seems to be going crazy here. In the picture above, I pointed out the system going in down the street. A few weeks ago, another neighbor put in a system. Then on Tuesday this week, I found out that a coworker just went online with their solar power and I didn't even know they were getting it! Every few weeks someone knocks on my door wanting to "sell" me a solar power system. But they aren't selling, they are leasing. I wouldn't ever do that. They get the tax credit and I pay them almost as much per kWh as I pay the electric company.
  13. Leadfoot J. McCoalroller
    8,289
    7,802
    Pennsylvania
    2018 Prius c
    Thanks for the response anyway. We spent a lot of 2019 shoring up our finances. 2020 threw us all that curve. Now I want to get back on track.
    We used to have a bunch of those solarcity agents trying to lease gear, they were clogging up the entryways to the home improvement warehouses.
    Biggest thing holding me up now is finding information. Lots of resources on the internet dedicated to taking all of my info and selling it as a lead, but I don't feel like playing that game.
  14. alanclarkeau
    7,045
    7,593
    Mine I bought with a "Life Expectancy of 20 years" and warranty of 5 years. Panels were 20yrs, 10 yrs warranty. The Inverter made 10 years - just. The chap doing the replacement said that 10 years life isn't unusual. But the new one is running a lot cooler - probably because it is higher capacity. I'm on a super-special buy-back rate till 2028 - so plan on keeping it going as it is till then.
  15. R-P
    R-P Active Member
    808
    288
    Netherlands
    Sorry about the 120VAC 240VAC error. I thought normal voltage was 120VAC in the US and not even all houses have 240VAC, only if you have large appliances.
    Just had a discussion about power on a Dutch forum: we have either 230VAC 35A or 3x230VAC 25A home connections. The latter being a 3 phase system (three separately fused 230VAC lines with 120degree phase difference).
    Is it correct that 240VAC in the US is simply two 120VAC lines but 180degrees phase difference?
    Some chargers (Tesla?) can do 230VAC 30A. But this is no use for us, as we cannot use it: 230VAC is fused with 35A as a main fuse, but it is mandatory to use smaller fuses before hooking ANYTHING up to it, so highest is 25A (my current solar inverter, normal houses never use anything above 16A).
    (We can get 3x230V 50A and then use said 30A charger, but the fixed costs for that are like 1800$ a year instead of 300$ for a 1x35A or 3x25A connection)
  16. jerrymildred
    11,517
    14,167
    Tampa, FL
    Ours is warranted for 25 years for the panels and the inverters. They offer a 25 year loan at 1.99% or a 20 year loan at 0.99%. We took the shorter lower interest one since it saves in the long run and the payment is still a little less than our average electric bill.
    I don't think I've ever seen a US house that was only 120V. Normal is 240V split phase which is what you described below. Almost everyone has at least one 240V appliance. Mine include the stove, water heater, air conditioner compressor, air conditioner air handler, clothes dryer, and now my Prius Prime. Lights, fans, sewing machines, computers, vacuum cleaners, TVs, etc. etc. are 120V.
    Yup. What they do is take the incoming 240V and tap the center of the transformer to connect that to ground and neutral. Some people mistakenly call that two phase, but it's actually split phase.
    #96 jerrymildred, Apr 22, 2021
    R-P and alanclarkeau like this.
  17. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Most US houses are 240 VAC single phase, with 120 volt breakers both ways from neutral. Double pole breakers are 240 volts and are for large appliances. (Clothes Dryer, Oven. Water heater, Central HVAC, etc) I live in the deep South and some older homes are wired for 3 phase as the HVAC used to need that kind of power. Most commercial power is 3 phase.
    Yes, residential is almost all single phase 240 VAC with 120 VAC emulated by only using one hot wire and neutral.
    A large house may be 200 Amps, smaller is 100 Amps.
    While I only have one 240 VAC breaker in the House (Electric Oven, Natural Gas HVAC, Dryer, and Water heater, my Garage has 8 240 VAC outlets, two of which are 50 Amp 3 phase. (Some previous owner repaired vending machines and needed a welder) I feel bad not owning a plug in car, so none of my 240 VAC in the garage is in current use.
    NEMA is the organization that standardizes plugs and receptacles, pretty much the largest is 50 Amps. I frequently recommend a NEMA 14-50 receptacle as they are commonly found in RV Parks. One company in town manufactures ovens, they have 12 14-50 outlets in their show room.
    Viking Range - Wikipedia
    What Plugs are Available on EV Charging Stations?
    R-P and jerrymildred like this.
  18. R-P
    R-P Active Member
    808
    288
    Netherlands
    24kW or even 48kW. Wow... (ours is 8kW (single phase) or 17kW (3phase)) But I guess having natural gas supplied to your house isn't the norm.
    While our neighbors in Germany are promoting it, we (Netherlands) are trying to get rid of natural gas*. Which 95% of the houses use for cooking and heating. Our grid has to be beefed up significantly before we can go all electric. Normal connection is 6mm^2 per phase (somewhere between AWG 9 and 10) into residential houses, so anything beyond (230Vx35Ax3phase=)24kW needs digging out the old cables and upgrading, not to mention upgrading the HV-lines and pretty much all substations.
    Sorry, digressing... Carry on.
    * Germany has a lot of brown-coal (lignite?) plants for electricity generation so promoting natural gas reduces their CO2 and greenhouse emissions greatly whereas the Netherlands had a huge reserve of natural gas (which we squandered, but that's a different discussion) but we're seeing earthquakes where this was pulled out of the ground, so we are trying to stop pumping it and don't want to be dependant on the alternative, Russian gas, while our 'friend' Putin (or likeminded successors) is/are in power and can shut us off whenever something is not to his liking.
    Merkey, JimboPalmer and jerrymildred like this.
  19. jerrymildred
    11,517
    14,167
    Tampa, FL
    [preface: Somehow I managed last night to put this in the newbies, let's see some pictures thread. I guess I was half asleep. :oops: Then again, I am a newbie when it comes to solar power. :whistle: So, here's what I wanted to say in this thread last night.]
    It's installed and it works. Now to wait for the inspection. Then to wait for the electric company to make the meter change. It was almost dark when they finished, so I'll se how much it puts out tomorrow. Apparently it's OK to have it on while we wait for inspection and meter change. But I discovered that it actually consumes about 290 watts from the grid after dark so I turned it off for the night. That much consumption after dark seems high to me so I'll ask about that tomorrow.
    [copied & pasted from the post frorm last night, so "tomorrow" means "today" etc.]
    R-P, Merkey, John321 and 1 other person like this.
  20. Prodigyplace
    12,713
    11,848
    Central Virginia
    Some cities and towns in the US have natural gas piped to the house. Heating can be natural gas, fuel oil, propane gas, or electric. Electric heat is usually either baseboard resistive heating or more efficient heat pumps. Some of us in rural areas can still supplement heating with a wood burning stove.
