I used E85 today and......
Discussion in 'Gen 3 Prius Main Forum' started by douglasjre, Apr 29, 2018.
  1. douglasjre
    douglasjre Senior Member
    2,249
    751
    Null, NL
    It took 9.8 gallons to fill it up and I believe the tank holds 11.5. I had E15 in it previously I wasI was pulling thethe trailer that help to bikes and I had a dog and biking gear. The 85 miles per hour is getting 23 miles to the gallon on E15.
    When I stopped to fill the tank I put 9.8 gallons of E15. this was enough to make the tank false. I then drove the car in the same in the same fashion and got 18mpg. The car ran flawlessly and no hiccups. Of note it did seem to offer a little bit more power at 90 miles per hour and it did not have to run the engine to do 90, whereas to E15 I had to run the engine to redline to do 91 mph.
    Just looking at one gas station 87 octane fuel cost 2.65 a gallon and E85 cost 2.35. just doing Simple Math in my head I got 20% worse fuel economy with E85 as compared to E15 but it only saved me about 13% in the cost. To make them Russell equivalent E85 should have been should have been $0.50 less per gallon.
    Has anybody else here tried E85 and can you post your results? Please do not give me your opinion of how bad he 85 is for the car and how it's going to destroy everything in 2 months because we have all heard this before. I get it. Dont use E85, understood and thank you. Instead please give me only facts and findings.
  2. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    670
    269
    Dodge Co. Wisconsin
    2017 Prius v wagon
    All I know is on my motorcycle gets better mileage with real gas than ethanol (10-15%). I don't know about the Prius, but not all engines can run E85, and I found the more ethanol, the worse the mileage.
  3. n23
    n23 Junior Member
    28
    Tampa, FL
    The lower energy density of E85 will always turn the cost/efficiency equation against it.
    RRxing likes this.
  4. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    The Prius is not designed to run E85. RTFM. Maximum 15% alcohol is required by Toyota. Whether it causes a problem or not, why would you even consider something the engineers warn against?
  5. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    You seem to be looking for someone who knows that he will ruin his $30,000 investment but does not care, and tries anyway. This may be a very small pool of enthusiasts.
    My wife's anti-Prius (Chevy Tahoe) is E85 flex, but we have never used E85 as it has a 280 mile range on E10 and in theory would have a 220 mile range on E85, too frequent fill ups to contemplate. It is never 30% cheaper than regular E10 so there is no economics, either.
    Merkey and paprius4030 like this.
  6. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Yes the min. fuel required for the Prius is 87 octane. The less alcohol in the fuel, the better mpg's you get. This whole ethanol thing is a big scam by the oil companies to make you think their doing something good. Better to use the corn to help people in depressed countries.
    Tyfly, tpenny67 and Namurt like this.
  7. Rmay635703
    Rmay635703 Senior Member
    2,689
    1,725
    Somewhere in Wisconsin
    2013 Chevy Volt
    Objectively you will find most cars get the best dollars per mile somewhere between e20 and e40 (depending on outside temps)
    I have run e85 for years because it is many times up to a dollar a gallon cheaper. Looking out the door we’re at $2.65 and $1.85 respectively today.
    Usually when I do however I run a mix, on my particular cars e25 seems to get statistically the same fuel economy as e10 (aka the difference fits into the tank to tank variations)
    My guess is you will find the same and adjust your fueling appropriately .
    For me it’s rarely worthwhile to run pure e85 but it is often worth running a mix since FE isn’t much affected on lower blends
    Good Luck
  8. Erik Owens
    Erik Owens Member
    162
    60
    It will have a higher oxygen content in the fuel and your fuel trims with try and compensate for that. Which is why most E85 capable vehicles have a rationale to change/ calibrate when using E85. Come on man. You are supposed to ask before doing, like looking before leaping.
  9. Johnny Cakes
    Johnny Cakes Senior Member
    1,065
    789
    Virginia, USA
    I'm sure people will honor your request.
    Maybe not.
    OK, definitely not.
    energydude, Threej and paprius4030 like this.
  10. douglasjre
    2,249
    751
    Null, NL
    Update: Today the MIL turned on. Techstream reports code P0171 (The P0171 code means that, on the first bank of the engine, the fuel system is running weak or a vacuum leak exists near this side of the engine. A lean condition occurs when the engine either receives too little fuel or too much). Sounds like this fuel source is a bad economic choice as it costs me more, and the car can not run on it as well. That was a good experiment. Guess I'll be refilling with regular gas and going along my merry way, and clearing the codes....
  11. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    I almost gave up after the second paragraph. Deciphering was giving me a headache and I'm still not sure i understand the details.
    E15 @ 85mph = 23mpg.
    E85 @85 mph = 18mpg.
    Both times towing a trailer with some bikes and ROLLIN' along...
    Those mpg numbers stink, because I roll 85-95 quite often on Atlanta trips (and back) and the crappiest I've ever gotten was ~38mpg, not draggin a parachute, tho.
    facts only
    Apparently E85 sucks for vehicles not designed to operate on it, especially when towing, especially at high speed, for which no trailer is really designed, especially a trailer connected to a Prius............
    Hell, E85 probably sucks for vehicles designed for it too..
    I recommend trying diesel. Isn't diesel used in all those tow-type vehicles? Must work goood! Throw 9.8 gallons o' that in the ol tank and let us know how it goes!!!
    Just messin around.
    and havin' fun witchya.
    jerrymildred, Merkey and Threej like this.
  12. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    What's the motivation of using E85 when it'll cost more, or maybe you just save slightly
    Are you burning any oil? If not, your car would be in the plus column for 2010 models that can take a beating without burning oil.
  13. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    BUT, in all seriousness, the info below is available all over the net:
    The hazard associated with E85 in a non-FFV is the corrosive action of ethanol on certain components of the fuel-system, specifically any exposed magnesium, aluminum, or rubber.
    One exposure of E85 will not "instantly" melt all the magnesium, aluminum, or rubber it comes in contact with but over time, it can erode those surfaces and the resulting residue will be processed through the fuel system.
    E85 in a non-FFV may also cause a check-engine light because the O2 sensors might detect less emissions and interpret it as a "lean" condition and attempt to adjust the fuel-air mixture.
    jerrymildred and Merkey like this.
  14. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    What about the other post using premium fuel?
  15. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    I may be wrong but from what I understand, the corn used to produce ethanol is not human consumable. The corn byproduct from producing ethanol goes to make cow feeds. Cows are human consumable.
  16. paprius4030
    2,077
    296
    York,Pa.
    Lots of cows you see on the news in third world countries look underfed. Mooooooooooooooooo.
  17. Mendel Leisk
    42,309
    One thing that keeps rattling around in my brain, is that 10% ethanol is just fine, but an additional 5% more is terrible, damaging? I really wish they'd dump ethanol completely.
    VFerdman and paprius4030 like this.
  18. Rmay635703
    2,689
    1,725
    2013 Chevy Volt
    The reality is the information on the internet is very dated.
    Fuel components are either rated for ethanol or non-compliant, there is no such thing as compliant to e10 or other nonsense.
    ANY ethanol in the fuel will degrade components that aren’t ethanol compliant PERIOD.
    This degradation occurs at the same rate whether it’s 1% ethanol or 100% ethanol.
    This means fuel components that tolerate 10% ethanol must be able to tolerate 100% ethanol.
    So on something made this century the fuel delivery system will be ethanol rated.
    Most non flex fuel vehicles do not have enough trim to burn pure e85 at all throttle positions and will throw a CEL
    Even with a CEL your O2 sensor will keep the car at stoic.
    The only danger is at WOT because most cars follow a pre-defined table.
    There are work arounds for the above issues.
    That said scientifically ethanol blends around 20-40% provide better than expected fuel economy, there are scholarly papers on this fact.
    On most cars the BTU content of the fuel does not accurately predict fuel economy, this has to do with octane and vapor point inflection between gas ethanol mixes.
    On my cars I’ve found they will burn up to e50 without issue, my Insight is actually much more drivable with about 30% ethanol in the tank.
    My 98 Buick drove 100,000 miles on an Ethanol blend without issue.
    Adding Diesel to gasoline - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com
    As toward blending diesel into gas it’s been tested for many years,
    In the 80’s Flying J and other gas outlets sold gasoline that had diesel mixed in right at the pump to provide better FE.
    Many chemicals in modern gasoline are also in diesel, there is nothing new or amazing about this.
  19. douglasjre
    2,249
    751
    Null, NL
    It's disappointing to see that E85 cost so much. It was a fun experiment to see how the car would deal with it. I refilled the tank with E 10 when it was at 4 gallons remaining, I cleared the codes and the car runs just fine with no more check engine light. I guess I'll have to stick with E10 or whatever is available.
    BruceInOKC and Rmay635703 like this.
  20. BruceInOKC
    BruceInOKC Member
    190
    Oklahoma City, OK
    Excellent post, Rmay635703. The Internet is full of outdated information and scare tactics on ethanol. "Keep the car at stoic" refers to stochiometric mixture - the ideal ratio of air-to-fuel for clean combustion. Although the Prius cannot adjust to E85 fuel, the permitted E15 fuel might burn cleaner than E10 (much less pure gasoline), but the tradeoff is a slight mileage penalty.
    #20 BruceInOKC, May 1, 2018
    Merkey likes this.
