I Want to Determine How Much Fuel is Left With One Flashing Blin
Discussion in 'Gen 2 Prius Technical Discussion' started by ydpplqbd, Nov 4, 2019.
  1. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    115
    To the PC OP thread.... when you are aware of the first blink (low fuel) 1or maybe 2 gallons may remain in the Gen2 fuel tank likely driving range of 50-60 miles …. depending of variable factors of driving habits, ambient temps, vehicle condition, and etc....If you go complete out and set OBD DTC codes ….and you have entered a whole new threshold of issues....
    Skibob likes this.
  2. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    It took 5 pages before someone brought up the fact that a Prius gets lower mileage in cold temperatures. You guys are slipping.
    OP if you click on someone’s name, like say Sam Spade 2 there is an option to ignore that user. Just sayin. :whistle:
    NortTexSalv04Prius and ydpplqbd like this.
  3. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    Nice that the thread is back on topic, too. It veered off-topic somewhere on page 2, post 35.
    OCD, navigation systems, cell phones, cell phone plans, VW's, spare engines ...
    Perhaps one could ask a basic question, "Is this on topic?" before posting. And I note, not a newbie in sight, OP excluded. Even I got sucked into the OT vortex, so I'm talking to me too.
    VFerdman and ydpplqbd like this.
  4. ydpplqbd
    ydpplqbd Active Member
    551
    253
    Thanks for the heads-up. For now, let SS2 have his fun.
    Skibob likes this.
  5. ydpplqbd
    551
    253
    Thanks for the heads up.
    Please explain to me how we are going to be setting off DTC codes when the vehicle is off (likely with both batteries disconnected depending on the fuel extraction method). And the fuel being poured back into the tank immediately after extracting the last bit.
    #85 ydpplqbd, Nov 8, 2019
  6. bisco
    51,972
    if you run out of gas, the car continues to drive on the hybrid battery. it's not always easy to know, and i can't remember if dash lights came on in my gen2 when i ran out and kept driving, or not until the battery ran down and forward progress was halted
    NortTexSalv04Prius, Skibob and SFO like this.
  7. Skibob
    2,912
    1,505
    Northern California
    Just remember it’s harder on your fuel pump running so low as it’s cooled by the surrounding fuel. If your fuel pump goes out you have to replace the entire gas tank, you can replace just the pump or filter or sending unit. One thing goes entire tank has to be replaced.
    ydpplqbd likes this.
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Once the original question has been answered or more or less dealt with?
    It may not be the best of internet discussion forum protocol, but I often like it when a thread veers off and takes on a life of it's own.
    Some of the most dynamic, interesting discussions I've ever participated in, came in threads that started out talking about an Oil Change, but ended up talking about.....whatever you can imagine.
    That being said?
    Yes, we should pay attention to the original query.
    But I like it when within that agenda...you discover things like shared experiences with vintage VW bugs. Even if it does then bifurcate off the original path.
  9. John321
    John321 Senior Member
    1,457
    1,405
    Kentucky
    Some may have already mentioned that the Gen 2 tank has a bladder that holds the gas pumped into the tank. The amount the bladder holds depends on the outside temperatures. When it gets really cold outside my Gen 2 gas tank didn't hold much more than 7 gallons.
    The Gen 2 gas gauge is a percentage of the tank that is full.
    Your experiment may give you the amount of gas the tank holds at that exact time. Temperature conditions, the tank bladder pliability will all change with different conditions and so will the exact amount of gas that 1 flashing bar symbolizes.
    We owned a 2008 Gen 2 Prius. My normal routine was to never let it get below a 1/2 tank or the mid bar. The exception was when going on long trips.
    Most would agree that the Gen 2 Prius gas gauge is a rough approximation at best. Driving with only a flashing bar is an unnecessary risk for most people.
    However it is certainly your car and your prerogative to manage your fill ups in a way that works for you. Keep in mind as winter approaches you may have much less gas in your tank than you anticipate with a flashing bar.
    Skibob, srellim234 and Mendel Leisk like this.
  10. Mendel Leisk
    41,486
  11. bisco
    51,972
    have we determined the fuel quantity after 90 posts?
    Raytheeagle likes this.
  12. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Nope:rolleyes:.
    But what’s new(y).
  13. bisco
    51,972
    nothing
  14. VFerdman
    VFerdman Senior Member
    1,186
    1,215
    Western Massachusetts
    So much discouragement from the community may not make OP so eager to post results or even go through with the experiment.
    NortTexSalv04Prius likes this.
  15. Mendel Leisk
    41,486
    Our work is done. :whistle:
  16. dolj
    dolj Senior Member
    8,450
    4,291
    So, who makes this judgement?
    It is more than "not the best", it is downright disrespectful.
    You, maybe. Me, not so much. My bugbear with going off-topic, is more for the people who come after, maybe researching a problem having to read through pages and pages of irrelevant posts. Take this thread for example, almost 2/3 of it is irrelevant.
    We should show respect for the OP and their thread. We should not take it upon ourselves to decide the thread is done and then just shoot the breeze in their threads. Start a thread in FHOP to talk about vintage cars etc.
  17. NortTexSalv04Prius
    915
    115
    To the OP PC …. …. Not sure if you are going to drain the fuel bladder tank or driving the vehicle after last blink .. My response was based on driving... Not easy on vehicle either way …..
    Please consider the following
    fuel lubricates the fuel pump
    driving without fuel discharges aux battery and HV battery
    Scan Gauge 2 Toyota specific X Gauges has edit Gas Gauge 05AC...010582A40000 RXF that will give percent update
    » TOYOTA – LEXUS – SCION
  18. dolj
    dolj Senior Member
    8,450
    4,291
    I don't think it is the intention of the OP to drive the car or even run the ICE with no fuel in the tank. It was simply one idea he had to measure the remaining fuel. I understood that once the fuel was quantified, it would be put straight back into the tank.
