I want to know about led headlights
Discussion in 'Prius c Accessories and Modifications' started by zeeshan, Jul 14, 2016.
  1. zeeshan
    zeeshan New Member
    pakistan
    is there any difference between normal headlight and led head light or we can just use led bulb in any headlight? and this is led headlight or just led bulb in normal headlight? Toyota Aqua G LED Pearl Black 2013 57k J3_1.JPG Toyota Aqua G LED Pearl Black 2013 57k J1.JPG
  2. zeeshan
    zeeshan New Member
    pakistan
  3. DonDNH
    DonDNH Senior Member
    1,711
    654
    Nashua, NH
    Four Touring
    Installing LEDs into non-LED housing won't work well. The housings have different reflector shapes and focal lengths to maximize brightness in the required lit area. Also, in the Gen-3 package V, the LED headlights have 3 sections (2 low beam and 1 high beam) where the non-LEDs have only 2 (as in your pictures above).
  4. zeeshan
    zeeshan New Member
    pakistan
    sir this is aqua 2013 so thats means this is not proper led headlight ?
  5. zeeshan
    zeeshan New Member
    pakistan
    can u post the led headlight picture please
  6. DonDNH
    1,711
    654
    Nashua, NH
    Four Touring
    No. I don't believe that is an LED light. I think that is a projector using an HID bulb.
    Any Prius C owners active today that can confirm or deny?
  7. zeeshan
    zeeshan New Member
    pakistan
    Sir thanks for your reply, please prius c owners kindly confirm
  8. AliIzad
    AliIzad Member
    170
    72
    Southern California
    The headlights pictured above are projector beam units with H-11 halogen bulbs. Looking at the close-up photo, the projector beam is on the right and that is your low-beam, on the left is the standard H-11 that is not a projector beam which is used for day time running lights and high beams. LED bulbs will not work properly with these units. Your best option is to purchase a good quality H-11, high intensity discharge (HID) kit that includes the correct bulbs, wires, and ballasts. Xenon Supply and The Retrofit Source are just a couple of the reputable companies that are making quality kits. Personally, I have the H-11, 5000 HID kit from The Retrofit Source in my 2012 C, and could not be happier. I would stay away from after market LED kits as the quality and brightness is not quite good enough yet. If you have the budget, you can always purchase factory Toyota LED headlights, but I'm not sure if they would be plug and play with your 2012 C. As for the high beam bulbs, I would leave those alone. Hope this answers your question.
  9. TheTimob
    TheTimob Member
    120
    79
    Divide, CO
    Driving an H11 Halogen headlight Prius C, and a 2014 Corolla which all have factory LED headlights - the Prius C normal headlights are WAY better.
    That being said - the top model Prius V's LED headlights are some of the best and brightest headlights available on any car period.
  10. Squeakasaur
    Squeakasaur Member
    106
    35
    22
    Seattle
    2016 Prius c
    The 2016 has LED headlights.
    "This is style you can count on. Prius c stands out with standard single-LED projector low- and high-beam headlights and available LED fog lights set in an aggressively styled grille. Prius c helps you leave a small footprint while making a big impression."
  11. Christophers
    Christophers Active Member
    269
    104
    Honolulu
    2015 Prius c
    Led headlights started with the 2015 c
  12. priustexasbob
    priustexasbob Member
    356
    86
    arrakis
    2015 Prius c
    stupid question time. how can you tell? I have a 2015C
  13. Masterloc
    Masterloc Junior Member
    53
    New York
    2015 Prius c
    To be more exact, 2015 C3 & 4 uses LED lamps in projector housing. 1 & 2 were still Halo.
    djdawn and priustexasbob like this.
  14. priustexasbob
    356
    86
    arrakis
    2015 Prius c
    thanks for the reply, that cleared it up
  15. w2kpugsly
    w2kpugsly Junior Member
    97
    san diego
    I have a 2013 C3 and I have replaced my hid with led kit from opt-7. I did both low and high beams. They are noticeably brighter than the hids. One drawback is I can't run with daytime running lights because it's basically high beams. They definitely get your attention. So I just run with normal low beams when I get in the car because it helps other drivers are my car. But if I turn on both at night, it's plain awesome.
  16. priustexasbob
    356
    86
    arrakis
    2015 Prius c
    so could one plug and play a C3 or C4 LED headlight into a C1 or C2?
  17. w2kpugsly
    97
    san diego
    You will need an after market kit
  18. Masterloc
    53
    New York
    2015 Prius c
    I haven't check how the led bulbs on oem look like, I doubt it'll be like those led bulbs sold everywhere. Not sure if it's easily purchase. Maybe I'll check it next time I drive the car. Maybe someone can find out how much are replacement bulbs from toyota would cost.
