I want to make additions to the screen. screen number 57031
Discussion in 'Gen 3 Prius Audio and Electronics' started by amrah, Sep 21, 2020.
Tags:
  1. amrah
    amrah New Member
    baku
    Hi friends. How to add a map to this type of screen? Is there additional software for them?
    screen number 57031
    THANKS
  2. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    I don't know where you are located (Azerbaijan?) but the US-market Prius Two (II) did not come with navigation, so adding navigation would be a major upgrade. And even the cars equipped with navigation don't get free map updates: updates have to be done by the dealer and cost US$200 or more for each annual upgrade.
    If a navigation app such as Sygic has maps for your part of the world, you'd probably be better to just use a cell phone with that app, or perhaps replace your head unit with an Android-compatible one so that the navigation app's maps show on that larger screen. (There's probably an iPhone compatible setup too, if you've slammed that prison door behind you.)
    #2 NewHybridOwner, Sep 21, 2020
    amrah likes this.
  3. amrah
    amrah New Member
    baku
    Yes. Unfortunately, this screen does not have GPS. If you have GPS, it is possible to write a map outside the hard disk
  4. amrah
    amrah New Member
    baku
    It is possible to connect the phone screen to this screen but
  5. Majafamily
    Majafamily Member
    66
    Elk Grove, CA
    I'd get a new headunit with navigation or apple or Android car play
  6. bisco
    51,645
    ya, get the phone emulator, the toyota gps maps are pathetic
    amrah likes this.
  7. amrah
    amrah New Member
    baku
    Have you installed anything extra?
  8. Majafamily
    Majafamily Member
    66
    Elk Grove, CA
    No, factory headunit in my Prius. I have no need to upgrade. Phone mount good enough for my GPS needs.
    For do it yourself, I'd expect replacing headunit to be easy labor. Worst part would be cost.
  9. Attila Fekete
    Attila Fekete Member
    164
    59
    Budapest, Hungary
    As far as I understood, your head unit need additional GPS modul to be installed to have navigation, but I’m not sure it support that module at all.
  10. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    Prius gps is garbage. I used mine twice; before buying the car and testing it out in my city. Took me in zig zags instead of L-shapes through roads to destinations. It did take path of least distance but would have saved even more gas had it been L’s.
