I was rear ended - how long do you think average repair will take
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Asmyth14, May 18, 2021.
  1. Asmyth14
    Asmyth14 Junior Member
    Usa
    I was rear-ended by a car going 50 mph while I was at a stop at a red light. The insurance people do not think it is totaled even though the impound lot people do. They cant get it looked at until mid next week and it is kind of frustrating to not have a car. Based on the damage to the back of my car does anyone have a rough estimate on how long all the repair work would take? Thanks in advance :)
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,589
    near Brisbane, Australia
    You'd be better to ask a Crash repairer for an idea - but it will always depend on what hidden damage is "discovered" when they start disassembling the area.
    And how available parts and panels are.
    It must be close to being totaled, I'd have thought.
  3. Elektroingenieur
    2,515
    3,277
    Three Touring
    As @alanclarkeau kindly points out, it’s difficult to write a collision repair estimate just from photos.
    Besides disassembling the outer panels to check for damage underneath, a good body shop will also measure the distances between specified points on the body and compare these with the standard dimensions in the Collision Repair Manual (more info) or a similar resource, to determine how the body was deformed by the impact forces and which parts must be straightened or replaced.
    Once the true extent of the damage is known, assuming the car isn’t then declared a total loss, the repair time will depend on parts availability—if the shop could get a complete back door from a salvage yard, for example, that would save the time needed to get a door panel, glass, trim, and other parts from Toyota and build the assembly—and on the shop’s workload and the skill of its craftspeople.
    Time might also be required for so-called “mechanical” repairs to the car’s systems: some body shops do this work in-house, but others sublet it to a Toyota dealer or independent shop. Either way, be sure someone uses the Health Check feature of a Toyota Techstream diagnostic system to scan for diagnostic trouble codes (DTCs), as Toyota recommends in Collision Repair Information Bulletin 2016-191, “Scanning for Electrical System Faults” (PDF).
    I’d plan to be without this car for several weeks, at least—but that’s really just a guess.
    Valiant V and alanclarkeau like this.
  4. Valiant V
    Valiant V Member
    239
    161
    Winnsboro, TX
    Pictures of the sides of the car's sheet metal will be more diagnostic as far as serious damage go. Obviously, you'll need a rear bumper, hatch, window(s), etc.
    Seeing wrinkles or waves in the quarter panels would be a tip-off that you have some serious "frame" (unibody) damage and unless you have a REALLY good shop - you'd be better off if the car were totaled.
    Bent cars -can- be straightened, but most are never as straight as they were before the accident.
    From the pics, it honestly doesn't -look- too bad for a 50MpH hit.
    Do all four doors open and close properly? Are the gaps around the doors even? Do you see any wrinkles or ripples in the roof? Any of those things mean major unibody damage and could easily push repair cost into "totaled" territory.
  5. Mendel Leisk
    40,587
    I’m thinking the same; suspect it was more like 30 mph. What was the posted speed limit?
    Again, same thought.
    alanclarkeau likes this.
  6. Mambo Dave
    Mambo Dave Active Member
    641
    306
    2019 Prius
    L Eco
    Wow, that sucks!
    You all understand why I have a roof rack for my bicycles now, I'm sure.
  7. bisco
    51,157
    keep in mind, it was 7 months ago
