I will go down in Prius Trani History
Discussion in 'Prius v Technical Discussion' started by Tim Jones, Oct 31, 2019.
  1. Tim Jones
    Tim Jones Senior Member
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    My v makes zero noise going around corners......but it does grumble some morning when it seems to charge the battery at a increased rate when warming up. And once in a while it moves a bit when the ECE fires up.
  2. Gliderguy
    Gliderguy Junior Member
    46
    Prescott Valley, AZ
    My whine is ONLY speed dependent. braking, accelerating, turning left, turning right, cruising at steady speed, it is all the same. I only notice that it is quieter on a cold transmission, and gets a bit louder as everything gets up to temperature. i first hear it just about 57 or 58 mph, peaks out maybe at 63, and barely audible by 70. I agree it sounds like the differential section since it is strictly road speed dependent and not in any way engine RPM dependent. I considered the possibility of one of the half-shafts but think that would be at least a little load dependent and maybe curve vs straight dependent, and probably a much lower pitch sound. I am hoping to hold it together for 80 or 90k miles, that would be about 5 more semesters of commuting back and fourth to school. I have an IR thermometer and will try and do a bearing check right off the highway just to rule it out.
  3. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Same here....I have a trani with 67,000 miles standing by.
    And I have the brake booster accumulator problem with parts for that too..... I have several vehicles or would have replaced this stuff already....
    Whine starts at low 50, up to 70
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Sorry confused your post with the guy that hijacked your post. I hate when people do that it makes the thread confusing and is very rude to you the OP (original poster).
    I don't help hijackers.
    Raytheeagle and Tim Jones like this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    My thumb is out:p.
    Tim Jones and edthefox5 like this.
  6. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    I have 11,000 miles on the WS and the 10 w 30 walmart syn oil...... still the same......
    edthefox5 likes this.
  7. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Still running......
  8. edthefox5
    10,096
    4,840
    Clearwater, Florida
    You'll be fine. I would never change it again. Once you get all that initial wear stuff out this trans is super easy on its fluid.
  9. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    16,000 now............
    bisco and SFO like this.
  10. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    How's your trani doing?
  11. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Been eight months and trani still the same....
