I wish the Prius had....................
Discussion in 'Gen 3 Prius Main Forum' started by Gasitman, Nov 6, 2009.
  1. ozboy
    ozboy New Member
    Australia
    x2
    Did you know your car's speed can be limited via satellite/gps?
    Problem is governments would block it, as they would lose too much revenue from lack of speeding fines...:rolleyes:
  2. ozboy
    ozboy New Member
    Australia
    This would be the ultimate (short of the car steering as well)
    Already available on S & E Class Mercedes called 'Distronic Plus'
  3. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    I wish there were more user configurable options for MPG. I would like to be able to tell it to prioritize MPG over climate control when it comes to heating. If it is able to stop the ICE but it is running it solely to produce heat for the cabin, stop the ICE. I'm able to do this manually by turning off the climate control when I'm at a stoplight and the engine is on just because I have the heat on. Another potential setting would be to set the CC to be less aggressive in maintaining speed when it comes to hills by allowing a drop of x MPH while climbing a hill.
    2 people like this.
  4. patsparks
    10,664
    569
    Adelaide South Australia
    Lower curbs. I have never had this problem.
  5. Tideland Prius
    16,677
    Also available on the Toyota Crown and Lexus LS460/LS600h
  6. ozboy
    ozboy New Member
    Australia
    I didn't think the Lexus does full automatic braking like the Mercedes???
  7. Spectra
    Spectra Amphi-Prius
    3,123
    17
    S NJ
    2 doors
    5 speeds
    EV
    sunroof
    improved rear-view
    white walls. yup.:nod:
  8. bighouse
    bighouse Active Member
    822
    126
    Guerneville, CA
    ...a magic free ATM behind that NAV screen.
  9. Buffalonian
    Buffalonian New Member
    17
    Buffalo, NY
    * More clearance under the car - for those of us in the snow belt
    * Deliver car with all season tires, as other carmakers do.
    * All wheel drive
    * Power seats
    * Larger wipers on top rear window, and add wipers to the lower rear window as well
    * Better positioning of seat heater button. I cannot reach it safely while driving
  10. Tideland Prius
    16,677
    I thought it did. It has the Advanced PCS (the one with the rear mounted radar and a forward facing camera to supplement the forward facing radar).
    I checked the sites and they have no mention of it. I guess I can't say for sure. Sorry! I do know Toyota has the technology (search Toyota Safety Day on this site for a video of it) several years ago.
  11. Acre
    Acre New Member
    104
    Woodside, CA
    Cassette player. My tapes from the 90's still play just fine thank you very much, and I'm not about to have them all burned to CD's. These are tapes I recorded myself, with each one built around some sort of theme. By the 90's good quality cassette's (e.g. Maxell, BASF) could withstand nearly 200 degrees F without degradation of the audio or damage to the mechanism and could also withstand hundreds of playings. An old Sony Walkman with the headphone cord plugged into the audio jack combined with a AA battery charger using the accessory jack solved the problem and both fit nicely in the storage area next the driver's seat but it seems a hokey thing to have to do to listen to my tapes.
  12. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    sometimes you have to "let go" and move on with life.
    embrace the 0's and 1's the digital age
  13. Acre
    Acre New Member
    104
    Woodside, CA
    Never!
    80% of my music collection is still on vinyl :)
  14. bighouse
    822
    126
    Guerneville, CA
    ...a plastic Jesus on the dashboard...wearing a hula skirt.
  15. SlowTurd
    1,156
    333
    nj
    [​IMG][​IMG]
  16. fjpod
    fjpod Member
    419
    72
    New York
    I wish it had a connector plug in the cargo compartment where you could plug in "portable" batteries that would feed the OEM HV battery. This way, one could belt them down for constant use and charge them with a cord that has all the electronics outside the car...like a laptop computer has it's charger outside. This scenario would also allow the batteries to be removed and left in the garage if one knew they were going on a long trip and would not be able to plug them in. It would also allow for one to have 2 or 3 extra battery packs that could be swapped out for charging, or hooked up in parallel.
  17. sshaw10
    sshaw10 Member
    103
    West Los Angeles
    I would have a loved a record player, I have an extensive collection of records.
  18. AussieDave
    AussieDave New Member
    Melbourne Australia
    No wiper unit on the back window, can't see anything out of it anyway.
    A speed sentry, so quiet I cannot pick when I am at the speed limit around town. (yes I know that would be another beep) Currently I rely upon my TomTom GPS as the Toyota SatNav is so bad.
    I would rather have the remote AC button open the moonroof, or better still make the car SMS enabled so I can ring from my desk and open the moonroof and start the remote AC
    The Aux connector and 12V jack in the top glovebox rather than in the armrest.
    Cruise control box on the MID not block out most of the tripmeter info.
    A smartkey for my house as I find I get out of the car and walk to the door without getting my keys out to unlock the house.
    Aside from those few niggles the car is FANTASTIC.
    David
  19. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I wish there was a 'Prius-like' car that could tow about 1,000 lbs.
    I know that's sacriledge to a great many Prius-ites (because it would require a bigger gas engine), but I did say 'Prius-like' :D:D
  20. robnbill
    robnbill Junior Member
    Fairfax, Va
    A locking glove box. I hate to have to remove every valuable when I leave the car with a parking attendant.
    Electric Seats
