I wish the Prius had....................
Discussion in 'Gen 3 Prius Main Forum' started by Gasitman, Nov 6, 2009.
  1. bighouse
    bighouse Active Member
    822
    126
    Guerneville, CA
    Yeah-hey some clever designer should come up with a way to lock the glovebox or center console
  2. burnerx
    burnerx New Member
    32
    Built in 3G and uses Google Map as the main GPS apps.
  3. TalkingMuffin
    TalkingMuffin New Member
    26
    27
    Earth
    - side mirrors that automatically point down when car is put in reverse
    - auto headlamps
  4. Lewie
    Lewie Junior Member
    89
    San Diego CA
    I'd be happy with a 12V jack that stays hot when the ignition is off, to allow charging of cell phones while parked. Nissan does this.
    Also, the telescoping steering wheel should have greater range. It would fit me much better if it extended back an extra four inches, or so.
    Then, how about a curb sensor for the front bumper? I've scraped mine (where it shows) twice in the first week! I don't mind the bumper being low, it's probably part of the engineering to get low wind resistance.
    Other than these, I'm a happy camper.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    That's an easy modification if you want to do it. Just be aware that it is easy to drain the small 12V battery.
    Agreed. I wish my Gen II had any telescoping adjustment for the steering wheel. At least the Gen III has some adjustment.
    That *is* the curb sensor. When you hear that scraping sound you know that you are close enough. ;):D:p
    Tom
  6. lrawles
    lrawles New Member
    I have had the car all of three days, but my immediate thoughts are: I need more telescoping on the steering wheel, a better nav interface, and power seats.
    I also don't want the plug hot (unless it is an option) when the car is off as I would like to keep something plugged in that only gets power during the operation of the car.
  7. patsparks
    10,664
    569
    Adelaide South Australia
    2 outlets? One hot one not.
  8. Acre
    Acre New Member
    104
    Woodside, CA
    How about a switch? Or how about having those solar panels do something a little more useful than running a fan - like charge up cell phones, laptops, and other stuff.
  9. PriusCrazy
    PriusCrazy Blizzard Pearl for Me
    213
    28
    Triad, NC
  10. Lewie
    Lewie Junior Member
    89
    San Diego CA
    Actually, this is the way my Nissan Frontier pickup works. The outlet on the dash is switched off with the ignition, the one inside the center console stays on all the time. It does have an enormous 12-V battery compared to the Prius', however.
    BTW, my friend with a Gen-I just had to replace his traction battery to the tune of $3,000. He has 103,000 miles on it and, of course, the warranty ran out at 100,000. Life can be like that...
  11. raidbuck
    raidbuck New Member
    133
    Baltimore ,MD
    Many of these have been mentioned before, but here's my list:
    1. Hatch unlock that raises it.
    2. Larger rear upper hatch wiper
    3. Heated steering wheel (this seems so obvious, wonder why not included in PKG IV)
    4. "Off switch" for navigation display to shut it down (maybe I just don't know how).
    5. Toggle switch for satellite between last two channels. Although lots of presets are possible, if listening to a channel not on a preset, then switching to a preset you have to manually scroll to get to the non-preset which is a safety hazzard.
    6. Power seat with memory
    Rich N.
  12. Tideland Prius
    16,680
    4. You mean turning the screen off? Just press DISP --> SCREEN OFF.
  13. web1b
    web1b Active Member
    817
    52
    This is not of any real practical use unless you are driving to an address within a tunnel.
    You are in a tunnel. You know you are in a tunnel. The satellite will pick up again at the end of the tunnel and you will continue to your destination.
    I have driven through many tunnels with a portable GPS and never got lost inside the tunnel and the GPS signal picked up within seconds of getting outside the tunnel and sometimes even before reaching the end of the tunnel.
    However, I use automatic on/off headlights everyday and it is a great practical convenience. I wish it was standard or even an option for the new Prius.
  14. dogfriend
    7,512
    1,191
    Carmichael, CA
    Actually it is useful in other situations as well, like in downtown SF where the tall buildings block the signal, or within a forested area where the tree cover blocks the signal. The dead reckoning system in the Prius actually works very well. It is some of the other aspects of the system that could be improved, IMO.
  15. Philosophe
    Philosophe 2010 Prius owner
    437
    72
    Montréal, Québec (Canada)
    A feature that was standard on my half-the-price-of-a-Prius Echo:
    Washing fluid almost empty light. (No, giving me a plastic stick to check myself if there is still some isn't doing the job...)
    Another one I'm missing from the same old car:
    ICE temperature light (A blue temp icon was lit on the Echo until the ICE got hot, useful for manually controlling the heater in the winter). This would be nice to know when to turn the heater on or off in the winter to maximize efficiency.
  16. Tideland Prius
    16,680
    At least you get a stick for 2010. Our Gen 2 never got a stick. It was a true guessing game.
    No need for the Cold Coolant light. If the engine runs while you're stopped, turn off the heater.
  17. Croft
    Croft New Member
    55
    Dorset, UK
    Those seconds can be vital though - there's a tunnel in central London which splits as soon as you leave it. I don't drive into central London much so I'm always unsure which road to take. In Brussels there's a tunnel which has a crucial turn off in the middle - unless you know
    to take it you get yourself lost!
    As dogfriend says, urban canions can be a real issue to. Again, in the actual City of London (the CBD) the roads are narrow and buildings constructed from stone. It is a nightmare getting a GPS signal around there, and when you do it is bouncing all over the place!
    (Oh, and it is odd that the US don't get dusk sensing headlights - at least an option in many other countries)
  18. fjpod
    fjpod Member
    419
    72
    New York
    I'm sure this one has been said already, but user settings should be settable by the user.
  19. liskipper
    liskipper Member
    374
    79
    Long Island, NY
    DRL's - would save me $50.00/year on insurance.
  20. bighouse
    822
    126
    Guerneville, CA
    DRL? Daytime Running Lights?
    I'm wondering if anyone just leaves their headlights on all day and night and never shuts them off manually? Would there be any issues about why one would NOT want to do this (other than burning out your headlamps!)? Seems to me the car shuts them off automatically when you exit the vehicle so why not just leave them on?
