I wish the Prius had....................
Discussion in 'Gen 3 Prius Main Forum' started by Gasitman, Nov 6, 2009.
  1. Tideland Prius
    16,683
    Yeah the black plastic bumper. There was a photo of it somewhere but I forget where... (owner's pics?)
    Sorry how does that turn off the bluetooth? What which bluetooth? the phone or the audio streaming?
    It won't start in EV Drive Mode for emissions reasons. That and it's better to use your engine to accelerate than to use the battery. In normal mode, the battery is used to get the car moving initially anyway which saves fuel and wear & tear on the engine.
  2. Sneezy
    Sneezy Member
    185
    Upstate NY
    A sunroof without NAV option! in my area anyway.
  3. teeasal
    teeasal New Member
    420
    50
    ON, Canada
    Page 175 of the manual says that the bluetooth entenna is built into the display. I never use audio streaming but I gues it uses the same antenna, so if the antenna is turned off, it'll turn off audio streaming too. I don't mean it turns off bluetooth directly. It just make the bluetooth reception so bad it disconnects. My phone actually started to ring and then "bluetooth disconnected" message popped up.
    http://priuschat.com/forums/gen-iii...etooth-disconnects-if-display-turned-off.html
    Well, I like the gas paddle response of the PWR mode, maybe because I'm used to driving the Honda Civic for 15 years. It was touch and go for that little red demon.
    So I'd like the Prius to default to EV+PWR mode every time it stops so it mimics the startup of the standard mode where it uses EV for the first few mph before ICE kicks in. I don't mean to use EV for extended distances every time during start up from stand still.
  4. jr02ray
    jr02ray New Member
    Lincolnshire, UK
    DRL's and a deeper boot (trunk) for my dog!
  5. Coprius2010
    Coprius2010 Junior Member
    Littleton, CO
    ...a light under the hood.
  6. Zhe Wiz
    Zhe Wiz Member
    128
    Ithaca, NY
    All Wheel Drive!!
  7. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    DRL's/Auto on-off headlights/Auto lights (headlights & taillights) on with wipers/flashing 3rd brake light/When key fob gets more then 10' away from running (Ready) car....all doors lock/should anyone press on the brake pedal without key fob inside car, car shuts down as normally would./ICE & Inverter temp gages built into display/ICE fuel pump running light built into display./12 Volt battery meter built into display./Foot lamps (front) in all models/Aux Storage area lamp on all models (under bridge)/lamp in glove boxes/Different material used for interior plastics, one that does not scratch so easy/Auto touch door handle for passenger & hatch back door/In the event that the 12 volt battery goes below the threshold that is needed to start the car, the HV traction battery charges the 12 volt battery automatically, until the HV traction battery reaches the point where the ICE would need to start to recharge the system. Allow this on all models, as a owners preference if they so desire it to be in use. This would save many owners from being stranded at a airport or cruise port after returning from a long vacation to find a dead 12 volt battery, when the HV traction battery has plenty of power stored in it.
  8. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Paragraphs or a bulleted list would help.
    The first could be a safety issue. How does the car tell the difference between out range vs. some other communication loss that can happen besides a dead fob battery? What if the driver continues to use a fob w/marginal or dead battery?
    As for more SKS handles, there is 3-door SKS, but one needs to have model IV/four or above on the 3rd gen.
    As for the HV -> 12 volt, well, the NHW10 (which we never got in the US) had it. It shipped in 12/97 in Japan. Regrading the feature and its removal, see Boosting HV battery in NHW10 Prius - CleanMPG Forums and post 8 of Jump Starting a Prius II - CleanMPG Forums. The first we got in the US was the NHW11.
  9. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    Most of what I read in your links were of charging the traction battery. I want the traction battery to charge the 12 volt aux battery. Thus keeping it from going dead. Make it available where if so chosen by the owner that the ICE would keep all batteries fully charged. Regardless how long the owner was away....I'm guessing that if someone did this, with a full tank of gas, it would take quite some time before the car ran out of gas.
  10. fuzzy1
    10,723
    I'm still hoping my next Subaru will be have HSD, but news has been quite scarce. The only recent news was here.
  11. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Whoops... I misunderstood. :embarassed::redface:
  12. ETC(SS)
    7,576
    A metal (ignition) key.
    A 100 page owner's manual.
    The Honda Insight's MSRP.
    Basically I wish the Prius had a younger brother that was all about being green, and providing efficient, clean, relatively safe transportation, without all of the up-selling options and gollywog 'features'. Maybe a Yaris with HSD propulsion,
    Oh yes....and the ability to recharge the already on-board battery with a home charger.
    Zat too much to ask?
  13. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Make the Prius feel and look more like being in a hybridized type of Accord. Bring it into the same ballpark in driving dynamics. Toyota, study the Accord steering wheel shape, placement and adjustment range - whole car feels like more of a 'driver's car', but very civilized. But, yeah, it's had 8 gens.
    And put the darn 16" alloys with 205/55 tires to finish the look of Prius.
    TIA.
  14. noweyout
    noweyout Trying to get used to it
    24
    SoCal - SGV
    Cupholders that can hold a decent sized cup!
    +1 on the all LED lights all around
  15. ramdisk01
    ramdisk01 Junior Member
    Merritt Island, FL
    Vastly Extended Range for the remote A/C option! Drop the 20 second delay, and don't turn off A/C when door is opened....
    In hot weather climates the solar roof is a Godsend. The remote A/C is almost worthless because of limitations that really aren't necessary.
    Thanks,
    Ramdisk01:rolleyes:
  16. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Hands down the #1 wish for me would be an optional ..
    16" x 6.5" alloy wheel option in Prius III and IV. No wheelcovers!(doesn't have to be with solar) This size wheel is uncommon in aftermarket, but it is a common size wheel in cars same size as Prius - Corolla, Civic, Matrix, Elantra, you name it.
  17. skilbovia
    skilbovia Member
    400
    91
    Massachusetts
  18. zeke013
    zeke013 New Member
    Oregon
    At least for the mirrors . . .
  19. jbcarey
    jbcarey Junior Member
    45
    Poughquag, NY
    a traction control system that works like my old sonata with an on-off switch
  20. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Fewer squeaks and rattles. Seriously.
