I would love some louvers
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Godiva, Jul 23, 2006.
  1. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    I want louvers on the front. That is, temperature-controlled fully actuated grill-blocking louvers. When the temps drops below 50ºF the louvers close to effectively block the grill. At temps above 50ºF they open. Perhaps they could partially open/close for better heat control.
    I think of this because I have twice unblocked and reblocked my grill with the wildly fluctuating temps around here.
  2. Godiva
    Godiva AmeriKan Citizen
    10,339
    <div class='quotetop'>QUOTE(NoMoShocks @ Mar 29 2007, 06:06 PM) [snapback]414520[/snapback]</div>
    Oh, man. I still want them.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    <div class='quotetop'>QUOTE(TonyPSchaefer @ Mar 29 2007, 07:20 PM) [snapback]414531[/snapback]</div>
    Something like cowl flaps on an airplane. The amount of air flowing over the air cooled engine on an airplane varies widely with airspeed, so many airplanes incorporate exactly what you describe. Traditionally they are manually controlled by a lever in the cockpit, but they can be automatic.
    Tom
  4. rvancil
    rvancil New Member
    17
    <div class='quotetop'>QUOTE(qbee42 @ Mar 29 2007, 08:18 PM) [snapback]414641[/snapback]</div>
    The heat through the back window is certainly a problem, but I can honestly tell you from living here in sunny Southern CA that most of the heat problem comes in through the front windshield on the black dash board. In my car I have all of my side windows, as well as my rear AND front windshield tinted, its not exactly legal but I've had the same setup in my last 5 cars over the past 6 years out here and have had no legal troubles. The heat reduction is incredible to say the least, especially when the sun is shining from straight down on top of the car onto you're lap! The trick is to find a shop that can tint the front windshield in 1 piece of tint with absolutely NO air bubbles, on my windshield you can't tell at all that the front is tinted.
  5. Godiva
    10,339
    Yes, but have you ever had a car with louvers? I've had two with no tint on any other windows and the heat reduction was noticeable.
    I can't help it. I still want them.
  6. rvancil
    rvancil New Member
    17
    <div class='quotetop'>QUOTE(Godiva @ Apr 2 2007, 11:04 PM) [snapback]416893[/snapback]</div>
    yes, i had louvers on my old 87 IROC-Z back in the late 90's, but they would look like nice person on a prius in my opinion, the tint looks very sleek and clean, it also does a much better job of cutting down on the heat issue.
  7. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(TonyPSchaefer @ Mar 29 2007, 03:20 PM) [snapback]414531[/snapback]</div>
    This is the best use for louvers that I see. Rather than just OAT, temperature under the hood should be read as well. That way, variations in load could be compensated.
    Dave M.
  8. Tyrin
    Tyrin New Member
    272
    <div class='quotetop'>QUOTE(TonyPSchaefer @ Mar 29 2007, 06:20 PM) [snapback]414531[/snapback]</div>
    Hear Hear! Even manually controlled from within the cockpit---I mean from the driver's seat would be great.
  9. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(dmckinstry @ Apr 3 2007, 02:14 PM) [snapback]417159[/snapback]</div>
    That's a great idea and it shouldn't be that big of a deal. My '65 Corvair had this kind of a setup, flaps controlled by the engine heat to basically act as a thermostat.
