I would never buy any Toyota
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by house2013, Aug 2, 2014.
  1. Okinawa
    Okinawa Senior Member
    1,333
    320
    I think your opinion is 100 percent correct. Good explanation.
    phoenixgreg likes this.
  2. house2013
    house2013 Junior Member
    50
    las vegas nv
    The guy at service center told me took them 10 hrs because they took the dashboard out them put it back again only to find the noise still there when they test drive it and then took it out again and finally no solution
  3. house2013
    50
    las vegas nv
    Friend has 2014 prius 3 as well and I have driven it and no rattle at all
  4. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    Double check glove box ☺
    retired4999 likes this.
  5. Beachnut
    Beachnut Member
    185
    43
    Does it say the above on your work order? At least they actually heard the rattle to try and fix it. If you are happy with the shops work, and friendliness, ask them to try again. Take it to another shop and let them try, tell them what has been done, save all your work order paperwork. Sometimes another shop can be better "rattle detectors"... Another trick we used was use your cell phone to record the noise, (or for other issues, take pictures or video's of it occurring for proof it happens). Give Toyota ample opportunity to fix it, but remain firm in saying it must be fixed. As consumers, we should not "settle", or "put up with" something on a brand new car, (within reason). I can see a car rattle on occasion, on a real rough road, but if it is all the time, on smooth roads,, no way, you paid too much for it.
    Oh, also,, sometimes a dash rattle, is actually on the engine side! Possibly have them check the engine compartment, too!
  6. Mendel Leisk
    41,134
    We had a buzz happening, under light to moderate acceleration, from somewhere in behind the glove box zone. For maybe 10,000 km. Just recalled it now, because haven't heard it in some time.
    Moral of the story, with the myriad components fitting together, it's very easy for something to loosen up, start making a noise. It's a testament to thorough engineering that it's infrequent.
    Which doesn't help with your issue. What I'd say:
    Have you ever watched one of those home improvement shows, where they involve the owners, have them stripping the wallpaper, or pulling up the old carpeting. Where I'm going:
    The pros excel at the tough, mechanically intensive jobs. And they get paid to work fast. But something like this, chasing a rattle, is frustrating, time consuming, for all parties. Maybe talk with the shop, get their best ideas, then attempt to isolate the sound yourself, as much as possible. Maybe you'll find it and solve it yourself. Or give the info they need. The more legwork you can do, the better for everyone.
    I appreciate it's a near-new car, a warranty issue, but still, since you live with the car, hear the rattle all the time, I think you can help them get it solved. Or wait 10,000 miles. ;)
  7. Okinawa
    1,333
    320
    I think your idea is a very good one. I have a "sometimes" rattle that bothers me in my new Avalon. I had to go to the dealer for another problem and I told them about the rattle but not to spend a lot of time trying to find it because it could be very time consuming. It is just a "me thing", I do not like to impose on a dealer to spend a lot of time trying to find a rattle. They took the car for a drive and said they could not hear the rattle. I believe them. It just was not rattling at the time. I am about to think in my case that it just might be the hybrid vent fan that is causing the rattling noise and maybe that is normal. In my owners manual it says something to the effect that fan noise from the vent is normal. Your suggestion to maybe wait 10,000 miles is a good common sense suggestion. That is something that I very much like about Prius Chat. There are a lot of intelligent people like you that comes up with some very good common sense suggestions.
  8. windstrings
    6,280
    378
    Central Texas
    If the arm that holds the hood up comes loose, it will rattle at certain rpms and drive you nuts too.
    Had that several times on my G3
  9. abistro
    abistro Junior Member
    22
    Virginia
    Hah, is there any wood in the Prius to knock on ;)
  10. windstrings
    6,280
    378
    Central Texas
    I just use my head
    Mendel Leisk and SageBrush like this.
  11. bisco
    51,699
    when you reassemble the dash, put some felt between all hard surfaces.
  12. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I think it boils down to what are your priorities and why did you buy the Prius.
    I wanted a Hybrid for efficiency, and The Prius for also being a fully utilizable, IMO comfortable vehicle.
    It's delivered on those priorities in spades.
    Of course I spent a lot of time researching and a lot of time in Prius Chat, so I had some foreknowledge that rattles were a possibility, even perhaps a likely scenario with the Gen 3.
    Yeah, I've got some rattles. But on a vehicle built to be light, with a full plastic dash, and a full plastic flying buttress? I kind of expected it.
    I've balanced...living with the rattles, vs. complaining and having a dealership try to hunt them down, and at least at this point, the occasional rattle is easily something I can live with.
    I really wouldn't buy a Prius with the expectations of a luxury car quietness attached.
  13. windstrings
    6,280
    378
    Central Texas
    I would rather have a loud rattle I can hear with the radio on than a small intermittent one that drives me crazy at least it would be easy to find the loud one
  14. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    OP...
    FWIW- My 2012 Prius Five (bought brand new) was a rattle trap- and the low profile 17" tires didn't help. It was very disappointing. I traded it in for a 2012 PIP- that was much better, but still had occasional rattles I couldn't get rid of (except by finally trading it in).
    My 2014 Volt had an occasional buzz at the driver side B pillar- I was able to fix it and another in the glove box damper (which is fixed by removing it). I can't over emphasize how nice it is now to ride in a rattle free car in silent EV mode.
    It bothers some people more than others, I also get annoyed by motion jitter on some modern TV's and other people don't even notice it. I guess it's based on how critical you are.
    In any case- I think you'll get better results tracking it down yourself and with the help of people here rather than having the dealer pull your car apart which is bound to introduce even more rattles/noises over time.
    I can't even remember a post where the dealer successfully fixed a dash rattle that didn't come back eventually, and in most cases sooner rather than later...
  15. Okinawa
    1,333
    320
    I certainly agree with you concerning tracking down rattles yourself rather than having the dealer dismantle parts of your car trying to find them. Just the thoughts of that scares me. I think a person is looking for a lot more trouble going that route.
    windstrings likes this.
  16. house2013
    50
    las vegas nv
    dealer said antenna inside dashboard is rubbing against its wall, they put some "foam" (not exactly sure what its called).. as of this time, there is still rattle but not as bad as it was before
  17. Fore
    Fore Don't look back!
    494
    107
    (not exactly sure what its called).. as of this time, there is still rattle but not as bad as it was before[/QUOTE]
    Now that rattles me!
  18. house2013
    50
    las vegas nv
    i think its like a noise insulation ...
    Now that rattles me![/QUOTE]
  19. Okinawa
    1,333
    320
    At least you found out what is causing it. I think you are lucky to have discovered the problem. You must have a pretty decent dealer. I don't think some of them bother to look that far.
  20. house2013
    50
    las vegas nv
    took them hours... yep... the rattle is now at least tolerable
